2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 535d engine top cover removal
      09-05-2011, 07:13 AM   #1
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Does anyone know how to accomplish the above?
There are no visible fasteners, which leaves me presuming that it should simply pull off. Had a try at that whilst gently rocking it from side to side and back to front, but, although there's a good bit of movement, it doesn't want to shift. Maybe I'm not pulling hard enough, but I'm afraid to force it in case there's a hidden attachment.
Any suggestions welcome - thanks.
      09-05-2011, 01:56 PM   #2
Needsdecaf
Needsdecaf's Avatar
6586
Drives: 2024 G80 Comp xDrive
On the N55 (535i), it just pulls off. One side has a catch, the other a "hinge" of sorts. Look down underneath and see if you can figure out where they all are.
But don't be afraid to give a good yank.
      09-05-2011, 06:57 PM   #3
BimmerUKF10
Drives: F10 535d
It just pulls off! It rests on ball joint clips. Just give it a hard pull.
      09-05-2011, 08:07 PM   #4
Needsdecaf
Needsdecaf's Avatar
6586
I just pulled mine off tonight. There are two ball joints in the front and two hooks in the back. Just pull up on the front.
Not sure if the other engine is the same but....
      09-05-2011, 08:29 PM   #5
Goodchip
Drives: 2011 535i, Sport, Exec, Tech
Just wondering why one would want to accomplish the above?
      09-06-2011, 02:20 AM   #6
BimmerUKF10
Drives: F10 535d
It is designed to be removed. They can't get to the oil filter without removing it.
I take mine off to give easier access to the engine bay for cleaning.
      09-06-2011, 04:37 AM   #7
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Thanks everyone. As it happened I went back out to the car shortly after I'd posted my question and pulled a bit harder - job done.
Only problem is that you can't be totally sure that it's fully and correctly refitted as there's no latch or anything like a positive click to reassure you that the air filter box is completely sealed. I had a good look underneath with the aid of a mirror and it looks pretty even all round, so I guess that's as good as it gets.
      09-06-2011, 04:40 AM   #8
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
As 'bimmerUKF10' says - for cleaning.
I feel happier now that I hoovered up the surprisingly large quantity of insects, grit and other debris, which had accumulated in the filter box over 11K miles.
      09-07-2011, 08:07 AM   #9
vngooi
Drives: F10
Hey guys...can post pics on removal? thanks!
      09-07-2011, 01:17 PM   #10
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Sorry, too late, I've refitted it. However, the procedure wouldn't be helped by pictures - you simply pull it off. I just wish the refitting was a bit more positive as you can't be 100% sure that it's completely reseated on the seal.
