2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Carbon Fiber side skirts installed
      04-17-2017, 02:03 AM   #1
mikekilpatrick
mikekilpatrick's Avatar
Drives: 2013 BMW F10 550 Xdrive Msport
Finally got some warm weather so I got this project completed over weekend. Had to modify the front mudflats, but happy with the results. Dremel tools rock!
Sedoy680.00
gabypr150.00
      04-17-2017, 02:44 AM   #2
ItBloo
Fish Gill
ItBloo's Avatar
73
Drives: 2018 Accord Sport | 1995 540i
1995 BMW 540i  [0.00]
2012 BMW 535i  [0.00]
Looking forward to pics!
If you can post guides to any of the projects, that would be real awesome!
Bloo The Bimmer - 2012 BMW 535i (15%/5% Tint | Dual Slat Grillle | H&R Sports)
Bessie The Bimmer - 1995 BMW 540i
      04-17-2017, 08:18 AM   #3
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
after what 2 years you finally get them on! and than you don't post pictures! just like your brakes lol!
      04-17-2017, 09:58 AM   #4
mikekilpatrick
There you go, now quit your bitching! Bwah hahahahahah
      04-17-2017, 10:12 AM   #5
lsturbointeg
dude, those turned out great! what does it look like from underneath... is it the same width as the OEM skirt? simple screws and double sided tape to hold it in place? i really got to get these! looks like you had to modify your splash guards? i don't have em' so i thought something looked different from the pictures you posted
      04-17-2017, 10:54 AM   #6
mikekilpatrick
Yes, I had to pull the splash guards, remove double sided tape (thank you Goo Be Gone), clean everything with alcohol and new double sided tape. The side skirts are held on strictly by 3M industrial grade double sided tape. They line up right with the OEM skirts on the Msport, so there is no lowering of the car so to speak.
I will take some more ground level pics and post this week.
Hardest part is getting the body line right. What I did was use a Contractors white crayon marker (Home Depot/Lowes) and a 3 foot level, to mark the straight and sharp 5-10 degree angle along the factory side skirt (Back to front). You need the sun and a flashlight to mark that body line PERFECTLY from rear to front.
Once line is drawn, I went back and held the CF skirt in place with Painting tape and retraced line with CF skirt as template to ensure my level line was right.
Then, use two people, or hold the front of the CG skirt in place with painters tape so it is at least CLOSE to the level line you do with white Crayon marker. Remove 2-3 inches of backing on double sided tape, put the CF skirt JUST below marked line, press it in place to hold, remove 2-3 inches more tape backing, Press in place, repeat, repeat, repeat until done at front.
There is SOME flexibility in the CF skirt, so you can flex it a little bit, if you start going off course on your alignment. Trick is to make sure you dont PRESS HARD on the double sided tape until you are SURE you are right on the line the way you want it.
Now, the hard part is doing the SECOND side as you want this to be within a half a millimeter or less of body line, to match the first side.
I used the "M" in the Msport sticker on car and measured it on first side of 3 mm from bottom of "M" to white crayon line. After I marked the body line on second side, I test fit the CF skirt to see where my white marking would line up the CF Skirt in relation to the "M". You can then follow your white line Exactly, a little above or a little below, the whole length of car to make sure your are dead on.
6 hours first side, 3 hours second side, but Mudflap removal and modding takes a good hour plus to get done as it is Dremel, Test fit, Dremel, test fit, etc etc. If you take too much off, you just bought new splash guards.... lol
When done, you go back with Rubbing alcohol and erase any white lines still showing.
      04-17-2017, 11:00 AM   #7
lsturbointeg
that just means you spent the time and effort to do it right! the results speak for themselves! looks very nice with those skirt extensions!
      04-17-2017, 11:45 AM   #8
Sedoy
Drives: F10
Looks awesome! Any pictures from far?
      04-17-2017, 12:35 PM   #9
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
Side skirt extensions look great, but I don't like them with the M Performance decal. Looks a bit too busy for my taste. But great job on the install where it meets the mud flaps.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      04-17-2017, 04:40 PM   #10
mikekilpatrick
Car is full of pollen and some grass from yard work yesterday, but you get the picture... lol
      04-17-2017, 05:53 PM   #11
gabypr
gabypr's Avatar
Puerto Rico
150
Drives: Jet Black 2015 F10 535i
Where you bought them? Thanks
CQuartz UK 3 Ceramic Coating | GeoShield Pronano 50% Ceramic Window Film | M5 M Perf Steering Wheel | M6 Comp Pkg Mufflers | M Perf Floor Mats | CF Spoiler | RW CF Quad Setup Diffuser | RW CF Front Lip | CF Trim | BMW Interior Leds | M5 343 Wheels | Pure Stg 2 Turbo
      04-17-2017, 06:18 PM   #12
mikekilpatrick
I bought them here on the forums used, but here they are brand new:
http://store.slekdesigns.com/product-p/b-f10-s-diff.htm
gabypr150.00
      04-17-2017, 06:44 PM   #13
ItBloo
Fish Gill
ItBloo's Avatar
73
Where'd you get the mudflaps? Flush wheels kicking up WAY too much on a white car...
      04-17-2017, 08:39 PM   #14
lsturbointeg
So it doesn't actually mount from underneath...got it! Makes sense now about how you had to install it now. Love the white tails and the diffuser!
      04-17-2017, 11:50 PM   #15
mikekilpatrick
Mudflaps
Www.getbmwparts.com. Jason runs that dealership online store and will take good care at best prices. These are OEM bmw splash guards. Almost everything I have on car is OEM bmw. Rear diffuser is Vorsteiner, rear tail lights are OEM bmw from Latvia on ebay and 500 shipped. Lativia has great prices due to exchange rate I believe.
      04-17-2017, 11:51 PM   #16
mikekilpatrick
Thank you sir. I debated on those for six months but look great on silver. European plug and play tail lights
      04-18-2017, 12:01 AM   #17
mikekilpatrick
Label
Msport label came with car and my goal is to make this the msport bmw should have made on this //m car. Electronic suspension with Dinan control arms and shockwave. Sw, sway bar bushings upgraded to polyeurothane over rubber. Sway bars are not uogradeable on this suspension model. Dinan intake, intercoolers and exhaust.
Mid 12s at ATCO with bad octane booster. Once I get the car dialed in with Alpina turbos and M5 downpipes, I am told the bms stage 2 beta should yield around 680 hp when tuned properly. A dyno will prove that or not
Wish I could find a pre TU tuner to tweak the ECU besides Dinan stage 6 sw. But no one has cracked it nor wants to do it
      04-18-2017, 10:32 AM   #18
ItBloo
Fish Gill
ItBloo's Avatar
73
After some communication with their sales team, they're telling me that they do not make the flaps for the M-Sport body...
      04-18-2017, 10:40 AM   #19
mikekilpatrick
They are the same...
http://f10.m5post.com/forums/showthread.php?t=1238007
