2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wash, Wax, Detailing and Cosmetic protection/repairs sticky door handles and leather dye 550i
      08-30-2020, 02:40 PM   #1
cheeber
Drives: 12 550i, 15 m4
had the sticky door handle problem on 2012 f10/550i oyster interior, and thought id post my experience.
on the drivers side bought a cheap replacement, quality looked good but fitment was an issue, so returned and bought the oem part for around 50usd on ebay.
on the right/passenger side bought the cheap part on ebay (only the plastic portion) for around 10usd, fit well, and color was a good match to oyster.
installation was easy - you will find on utube.
on the left side had some discoloration of the door panel leather and bought some dye from seatdoctors.com. Andy was very helpful, and sye was a perfect match.
      04-18-2022, 01:37 PM   #2
jimjaxx
Drives: 2014 BMW F10 5 series
Are you able to figure this out cos im haveing hard time fixing mine also
      05-18-2022, 04:10 PM   #3
sszablya
Drives: 2011 F10 550xi
Nice! Thanks for the tip.
      06-26-2022, 01:59 AM   #4
550bye
550bye's Avatar
Drives: 2011 550i
2011 BMW 550i  [5.67]
I think you guys are talking about these pieces. They are older photos, but I replaced mine with carbon fiber look. I bought two different kits, one was the door pull handle and the door lever trim. The pull handles for passenger and rear doors is only half of the handle, wish I could find the other half in carbon but I may settle for having them epoxy/resin wrapped here soon. The do have other colors that match OEM trim fairly well depending on where and who you get it from.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R.
      07-12-2022, 10:39 PM   #5
Joeker
Drives: 2012 550i
2012 BMW 550i  [0.00]
2012 550i  [0.00]
Do you have an image of the parts installed in vehicle?
      07-20-2022, 07:39 AM   #6
cheeber
I bought some black covers on Amazon to fix the sticky handle problem. Worked great and fit perfectly. Very cheap and easy fix.
      07-20-2022, 01:37 PM   #7
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Link?
      07-20-2022, 09:15 PM   #8
cheeber
Link?
I don't know how to post a link. But here is description. Is for 3&4 series. 25$
Jaronx 2PCS Door Handle Covers Compatible with BMW 3 Series 4 Series Driver Side &Passenger Side Door Pull Handle Covers (Compatible with BMW 320i,328i,330i,335i F30/F31 and 428i, 435i F32/F36)(Black)
