2010 2011 BMW 5 Series Forum F10 TPM warning when temp drops |
10-14-2015, 10:16 PM | #1 |
Rep 46
When it gets cold the TPM gives me a low pressure warning. I used to check it but now I just ignore it. It only got to the low 50's F and it went off. Checked the pressures, 26.5 all around. Topped it off to 30 all around to see if that helps. I see max is 35. Don't want to go there. What's number seems to work best for everyone.
10-14-2015, 10:27 PM | #2 |
Rep 494
Set the pressure to whatever it says in the drivers side door jamb when the tires are cold. Mine is 35psi fronts, 39psi rears.
10-14-2015, 10:30 PM | #3 |
Rep 237
The TPMS measures changes in psi. It doesn't matter what the starting point is. It only measures changes compared to that starting point.
BTW, you should be setting the pressures to what is in either your manual or on your door jamb. 26.5 is very low and there should be a variance front to rear. My door jamb recommended pressure is 35 front and 39 rear. These are not maximum but recommended pressures. Your car ride should change radically (for the better) with these pressures. At 26.5 the tires should be squirming around and in fact feel flat. The pressure should only be checked when the tires are cold. The TPMS should be reset after any pressure change. Hope this helps.
2018 640ix GT; Alpine White, Blk Nappa, Piano; M-sport, Premium (Ceramic, SIRIUS, Soft-close, Vent/Massage Comfort seats, Surround, Sunshades, Parking Ass't), Advanced Driver Ass't (Lane keep, Steering/Lane control, Cross traffic, ACC with Stop/Go), Smartphone, Tint.
Retired: 78 300D, 81 300SD, 87 190E, 88 Porsche 924, 89 260E, 93 300E, 97 Volvo 850, 98 E320, 03 BMW 325iT, 02 C230 Sport Coupe, 08 BMW 535i, 12 BMW 535i X-drive |
10-14-2015, 10:56 PM | #4 | |
Rep 494
10-14-2015, 11:31 PM | #5 |
Rep 5,378
I coded my 535i to display the actual temp and pressure yet all I get is --ºF and --PSI. I do have the metal stems.....
10-15-2015, 12:04 AM | #6 |
Rep 14,521
Funny someone posted this as I'm having the same issues. Every morning I have to reset it. I thought cause I read some where that maybe the batteries on these TPMS are going since my car is a 2011? so now the seasons are getting a bit colder the TPMS are pretty much useless?
10-15-2015, 02:39 AM | #7 |
ZEROdoubleZERO
228
Rep 659
What are you talking about Willis? Do metal stems cause the tpms to not work correct? My tpms sensors don't work , I ordered the beru tpms for my forge stars and they learned into the car on the way to the tire store, and then after I had them put in they won't learn in anymore. And yes they learned in sitting in the box on the front seat while driving to the wheel shop. I don't get it, if I don't figure out why soon I'm going to swap the sensors from my stock wheels. If I do that I have to put my wheels at risk by the tire jockeys again, if they scratch em I'll go ape shit!
10-15-2015, 02:44 AM | #8 | |
ZEROdoubleZERO
228
Rep 659
10-15-2015, 07:19 AM | #9 | |
Rep 14,521
10-15-2015, 08:18 AM | #10 |
Rep 243
10-15-2015, 08:57 AM | #11 |
Rep 18,728
TPMS battery life is 10 years on the shelf, but once installed and pressurized, the battery life is 4-5 years.
It has tolerance 25%. So unless it gets really cold very much, then it will give you a low tire pressure message. The best solution is to run nitrogen or check your tire pressure frequently and reset the tpms to memorize the new pressure. That way it will only give you warning after it dropped 25%.
10-15-2015, 11:43 AM | #13 | |
Rep 14,521
10-15-2015, 12:45 PM | #14 | |
Rep 5,378
Air is 78% nitrogen...... Does the other 22% make that much of a difference? Just asking.... |
10-15-2015, 01:18 PM | #15 | |
Rep 237
You are of course correct that the TPMS measures actual pressure and temp BUT it will only give a low pressure warning if the actual pressure is lower by ??? % compared to the reset value. i.e. if the TPMS was reset when the tire was at 39 psi and the reading subsequently fell to (say 25% less) 29 psi then the warning would let the driver know the tire pressure was low. I had TPMS on an E60. All Canadian F10s do NOT have TPMS but have FTM (Flat Tire Monitor) which is a useless, cheaper system that only tells the driver when the tire is critically under-inflated or almost 0 psi. FTM is particularly ineffective with run-flats since they don't change their shape as radically as a 'normal' tire. FTM must also be reset when tire pressures are changed. Thanks for allowing me to clarify.
10-15-2015, 11:34 PM | #19 |
Rep 14,521
So here's what mine looks like...no temp, no psi...just yellow = boring! Is that a coding u guys do to get the additional info displayed?
10-15-2015, 11:44 PM | #20 |
Rep 5,378
10-16-2015, 05:16 AM | #21 |
Field Marshal 🔱
144
Rep 294
Drives: 2019 M5 Competition (F90)
2019 F90 M5 Competition - Black Sapphire Metallic
2015 F10 535i xDrive M-Sport - Jet Black (retired) 2008 E60 528i - Space Grey (retired) 2002 E46 325i - Space Grey (retired) 1999 E46 328i - Orient Blue (retired) |
10-16-2015, 08:07 AM | #22 | |
Rep 15,858
