2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Estimated time of arrival - Navigation Pro
      08-17-2010, 04:54 PM   #1
LMOR
Norway
10
Drives: Space gray, M Beige F10 520d
Compared to my Garmin I used in my previous car, that gave a very good prediction of the estimated time of arrival, my new F10 Nav-Pro is way off. 30-40% more, and it is not very helpful. Has anyone similar problems, or a solution?
      08-17-2010, 06:56 PM   #2
Raptor04
Drives: 335xi
yes
I also noticed this the first time I used the Nav. It seems to route the longest way possible no matter which setting you use. Also, it does not seem to route like my Tom Tom did.
      08-17-2010, 08:47 PM   #3
LMOR
Norway
10
In my case, the route is the same, but the estimated time is 30-40% longer. When you drive, the estimate is updated, so so I "gain" time all the way. On the Garmin the estimate were more correct and stable. So it seems like it nav in the F10 have wrong information about driving time/speed limits or something else.
      08-17-2010, 10:13 PM   #4
raleedy
Drives: 2016 228i 6-speed
Don't it always come out even?
      08-17-2010, 11:01 PM   #5
Raptor04
Drives: 335xi
yes
it probably comes out even, but you really don't know your expected arrival time. With my Tom Tom it was dead on w/in a few minutes of the original estimated arrival time. I tried a Navigon before and it was constantly changing the arrival time earlier and earlier, which isn't very helpful. The F10 Nav seems to do the same as the Navigon. I want my arrival time to be as accurate as possible before I start driving....I don't want it to keep changing as I'm driving.
      08-18-2010, 08:58 AM   #6
Bandman
eyeing July 2011 for European Delivery!
Drives: 2000 Z3 Impala Braun 2.8
Probably because it uses the LEGAL speed limit to estimate time!
      08-18-2010, 09:28 AM   #7
LMOR
Norway
10
I wish this was true, but it is on speed limits. It says it takes 18 min to drive 10 km, with a speed limit of 70km/h most of the time. Due to traffic it takes 10-11min = 60km/h, but if you really should use 18min, you will be driving down to 30km/h making all other cars not very happy....
Driving 500km, that normally takes 6 hours, is estimated to 10,5 hour...
      08-19-2010, 06:46 PM   #8
CJ 43
Drives: F10
Have to say it doesn't seem as accurate as my Tom Tom and doesn't have warnings when you're approaching speed cameras as the Tom Tom does. I haven't really gone in depth with it yet though, so there may be things that I need to set up properly, but in terms of some basic functionality it seems lacking (haven't seen an option to insert a postcode for example).
As said it did start with some very strange times compared to the Tom Tom, but it seems to be improving now. I also tried the dynamic routing feature as well but can't say it helped much. So when it offered me the same option a couple of days back I ignored it thinking I might be OK and ended being stuck for 40 mins...#
Bloody computers...
      08-19-2010, 06:57 PM   #9
lindros2
Drives: 535i M-S
Nissan/Infiniti navigation allows you to set speed for each type of road.
It was absolutely dead accurate regardless of where I went (and while I had XM NavTraffic, it was spooky how accurate it was when traffic was involved).
The BMW navigation system is way too complex and ultimately defeats its own purpose.
2013 F10 535i Carbon Black M-Sport
2011 F10 535i Dark Graphite (Sophisto) Metallic (traded)
2009 Nissan GT-R (sold)
BMW CCA # 493835
      08-19-2010, 09:22 PM   #10
Raptor04
Drives: 335xi
Tom Tom is very accurate as well. I'm going run my Tom Tom next time I use the Nav and compare routes/times
      08-20-2010, 10:13 AM   #11
eripers
Norway
Drives: F11 523i
I think it bases estimated speed based on avarage speed for the last period. This is done for the different road types. So if your in a traffic jam one day it might estimate to low speed the next.
      08-20-2010, 10:24 AM   #12
LMOR
Norway
10
I dont think so. I have deleted all avarages, and driven fast over some time, to see if there is a slight effect. No change. I have also tried a the previous 5 series with the newest navigation. It gives exactly the same estimate, an there is no way these 2 cars have the same "experience" from the last period.
      08-20-2010, 10:31 AM   #13
gorban
Sweden
11
Drives: F11 520xdAT, E87 120dM
Garmin learns to adjusts ETA according to your driving style. As I always drive fast I always get ETA's that are a little challenging to meet.
Of course it's spot on in the end as the calculation is dynamic, but I can almost never shave off more than 5-10 minutes even on long drives.
