2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Doing meth on 550xi
      07-10-2014, 10:30 PM   #45
The_Transporter
Drives: 2019 BMW X3 M40i
Originally Posted by badblack550xi
For now it's a hack job to get me to the racing event tomorrow and Saturday.
Nice! Can't wait to see your results.
Good luck!
      07-11-2014, 08:59 AM   #46
badblack550xi
badblack550xi's Avatar
Good luck!
Not done yet.. seems hat the thinner aluminum piping after turbos is decreasing boost.
2011 550i RWD 60-130 7.35
      07-11-2014, 11:02 AM   #47
gclions
gclions's Avatar
78
Drives: 2011 550i
So, the smaller inside diameter tubing is restricting flow longer, causing boost overall to be lower?
Where before it was 1 inch in length, now it is approximately 3 inches in length?
Any thought that the methanol is causing a rapid reduction in temperature and therefore pressure? To me that would be expected, but to my knowledge there is no way to inject methanol prior to pressurization in the turbo, so is it even possible to avoid the drop in boost? I guess my first thought is this is one of the evils associated with methanol.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
      07-11-2014, 11:51 AM   #48
badblack550xi
Meth is not in yet this is just changing of pipes for now... i will have to find someone who can most likely 3D print this for me or CnC machine exact copy of the rubber ones the car comes with.
      07-11-2014, 03:27 PM   #49
NeoNz
335 Newbie
NeoNz's Avatar
Drives: 2011 335i xDrive
Great job pioneering the way for F10 owners, sucks the aluminum piping is robbing boost with the smaller diameter but you'll work it out no time!
2011 BMW 335i xDrive, 12.2 @ 111 (e90 N55 XDrive Record)- Sold
Stage 2, Map 7/e85 mix, JB Intake, Vishnu Catted DP, ETS FMIC, CPe Chargepipe
1994 Toyota Supra, Baltic Blue, 6-speed, mods... FOR SALE
1200rwhp/875rwtq, 3.4L Stroker
      07-11-2014, 05:49 PM   #50
badblack550xi
Almost there
      07-11-2014, 06:35 PM   #51
badblack550xi
About to start logging
      07-12-2014, 12:55 AM   #52
badblack550xi
More bull shit my welder fucked up the thread inside the bung now one of the meth nozzles leaking out meth! Me and tnt werks did all we can but I think I will need to get a new bung welded in. As for meth power car feels less lagy and continues to pull hard. After I fix the leak issue I will do 1/4 and mustang dyno.
      07-12-2014, 09:51 AM   #53
gclions
gclions's Avatar
78
Drives: 2011 550i
Count me in as excited, this is a step in the right direction, welder screw ups and all.
Apparently this guy welds like me, or more accurately burns holes in metal like me.
      07-12-2014, 09:54 AM   #54
badblack550xi
I was able to hit over 20 psi boost so after terry looks at logs we will decide if I can go higher.
      07-12-2014, 10:19 AM   #55
gclions
gclions's Avatar
78
Drives: 2011 550i
Good grief, Stage 2 aggressive on 93 octane is only 16 psi averaged between banks right?
Time to check out the strength of various components that see pressure. If those rubber hoses are $265 each, how much are head gaskets for these things?
Edit***
I just looked it up, it's 15 psi on stage 2, 16 psi on aggressive. 20 psi is insane compared to stock, that thing is going to scream!
      07-13-2014, 01:37 AM   #56
badblack550xi
Jesus Christ Meth Is Fucking Serious!!!!
      07-13-2014, 02:15 AM   #57
Chili Palmer
Master Of My Domain
Drives: 2015 650i Gran Coupe
With in next few weeks i will be testing meth injection on my car it is the same set up terry runs on his M5. Meth kit added around 25-30whp over the previous race gas mix!
[IMG][url]http://www.n54tech.com/forums/attach...1&d=1397262116" rel="ugc" target="_blank">http://<a href="http://www.n54tech.c...1397262116</a>[/IMG]
Damn! Look at the size of the intercoolers on the M5! I never realized they were so huge!
RIP: 2015 Black Sapphire Metallic 650i Gran Coupe, 343 Wheels, Michelin Pilot Super Sports 255 F / 285 R, M6 Front Grilles. Coming - M6 Comp. Mufflers, Carbon Fiber Diffuser & Spoiler.
      07-13-2014, 02:18 AM   #58
badblack550xi
we see what i run 1st and then we think if i need bigger inter-coolers
      07-13-2014, 02:23 AM   #59
Chili Palmer
Master Of My Domain
Let me try this again - I tried to edit my post on my phone and jacked it all up.
Damn! I never realized that the intercoolers on M5's were so huge!
      07-13-2014, 08:02 PM   #60
gclions
gclions's Avatar
78
Drives: 2011 550i
Dude, 20 psi, I gotta know the AWHP numbers as soon as you get them...I'm guessing 550, easy!
I'll be honest, I've been checking the forum every 5 minutes waiting for the results.
Off topic, were you going with the Hankooks? RS3's? I think those were the ones, they were recommended to me by someone else. I need new rears, and I need something with more grip for autocross.
I need to do more research on how much tire I can fit on the stock wheels, but these things need something sticky regardless.
      07-14-2014, 11:30 AM   #61
badblack550xi
Me and terry are testing different settings for now to see maximum power. Get hankooks rs3 for summer only... But they might not be 2 good on rwd car in rain.
      07-14-2014, 11:43 AM   #62
gclions
gclions's Avatar
78
Drives: 2011 550i
I'm in no major hurry to buy tires, but the rears are getting thin. I'm guessing about 25% tread left. I plan to ask around for the best balance between performance and tire wear, though picking up an extra set of light wheels and sticky tires would make the most sense for going to the track. Seeing how tire wear and grip are directly opposed, I need to find the right balance for me.
How did the car run? Clearly more power, but did it run smooth? Any codes? I assume you worked through the boost drop issue if you were hitting 20 psi.
I feel like a kid on Christmas eve.
Just hoping I don't get socks this year...
      07-14-2014, 01:07 PM   #63
badblack550xi
I was able to hit +6psi over stock on Meth and race gas... now i just need to hit 1/4 and see what happens.
      07-16-2014, 02:30 PM   #64
badblack550xi
Guys i will be at 1/4 this Friday night wish me luck
      07-16-2014, 04:51 PM   #65
Sum1.
Addict
Drives: '14 550iX M-sport
When you sort it out, let us know how much power you put down and how it runs through the traps.
'14 550iX M-Sport | BMS Tune | M5 Exhaust & Diffuser | 20" 601's | Beltronic STi+ | L.I. Quad | Color Matched Everything...Carbon Black |
      07-18-2014, 04:41 PM   #66
badblack550xi
Someone did a hit and run on my car I will have to wait some time before I hit the track again.
