2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications How many F10 N55 owners had a charge pipe cracks?
      01-09-2018, 03:55 PM   #23
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
Originally Posted by 5soko View Post
wow right where the sensor mounts.. Maybe someone could have caused a crack when install the jb4 and pushing on the sensor?
Doubt it, I've had the JB4 installed for a while now (did it myself).
I did, however, take my car to service for an oil change a couple days ago and now this happens...
      01-29-2018, 03:47 PM   #24
ItBloo
Fish Gill
ItBloo's Avatar
73
Drives: 2018 Accord Sport | 1995 540i
1995 BMW 540i  [0.00]
2012 BMW 535i  [0.00]
Fun times! I went to do a spark change, and I gave up after plugs #1 and #2. Reverted back to original. Now I'm not making any boost. Shop is saying codes are showing low pressure for turbo. I wonder if it's a cracked pipe, or what you had AMTF10
Ironically, also happened when I was just doing standard maintenance :P
Bloo The Bimmer - 2012 BMW 535i (15%/5% Tint | Dual Slat Grillle | H&R Sports)
Bessie The Bimmer - 1995 BMW 540i
      01-29-2018, 06:50 PM   #25
nwob
nwob's Avatar
16
Drives: 13' 535i
https://www.alibaba.com/product-deta...513397421.html
Thoughts?
      01-30-2018, 04:04 AM   #26
Techgeek80s
Drives: 2013 silver 535xi
Do you have stage 1 or 2? I wanna get stage 2 but don’t want lights flashing or blow a turbo or not pass inspection. Also how much are the horsepower gains from a chargepipe
      01-30-2018, 08:06 AM   #27
paul223
paul223's Avatar
Drives: F10
Originally Posted by Domey View Post
Good find at cheap price. what about lower half piece? It would be nice if it is available.
      01-30-2018, 08:07 AM   #28
paul223
paul223's Avatar
Drives: F10
None! Charge pipe is for throttle response and not crack under higher pressure.
FSociety3812.50
      01-30-2018, 08:19 PM   #29
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
You're driving a car with a nearly $70k MSRP. Do you want to cheap out on a part directly correlated with your engine? If you want price value, get a VRSF CP. That's what I have and it's a great budget option.
      01-30-2018, 08:38 PM   #30
Sylverlee
Drives: White 535i M-Sport, 911 GTS
Did you install that VRSF yourself? ez?
      01-31-2018, 09:03 AM   #31
paul223
paul223's Avatar
Drives: F10
Not true, On $70K car OEM is plastic, so product is certainly better than OEM. You automatically assumed it is lower quality than OEM!
      01-31-2018, 10:53 AM   #32
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
Yes, relatively easy.
      01-31-2018, 10:54 AM   #33
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
Just because it's aluminum from China, you automatically assume it is higher quality than OEM...?
Go through a vendor with an R&D tested item.
      01-31-2018, 06:29 PM   #34
paul223
paul223's Avatar
Drives: F10
I can tell you it is better than OEM, it is a pipe in aluminum so better than plastic. You don't need lot of R&D to engineer a pipe, as long as it thick enough to withstand 40psi it is good to go. However, PTF has complete charge pipe for $300.
      02-01-2018, 02:49 PM   #35
jooobi3
jooobi3's Avatar
Drives: 2011 BMW 535i XDrive
I was told from a supplier VRSF is made in China. Not sure if this is true but if it is there's no difference from the alibaba listing.
      02-01-2018, 02:51 PM   #36
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
I don't doubt that VRSF is in China. However, it's about quality control. You pay for someone sourcing it, making sure it fits correctly, and providing customer support/service. I'm not one to pay full price for things like M Performance parts. However, something like this I would spend the extra $1-$200.
      04-27-2018, 02:10 PM   #37
Shieldze1025
Keepin' America Free
Shieldze1025's Avatar
Drives: F10 535i
I had a loss of power during WOT and no boost is being made. There's also a very noticeable whooshing sound that sounds like a pressure leak of sorts when the turbo is spooling up.
Oh and, well the obvious from the attached photos lol. Looks like my sensor popped right off the charge pipe.
Exact same thing happened to me today! Same symptoms, I blew my charge pipe on my old 335 so I knew it was that right away. Who the hell decided that sensor should be glued on rather than screwed in like EVERY OTHER sensor on the engine.
How does it attached to the new charge pipe? I'm going to order one today.
UPDATE: sensor has screws but the whole flange broke off
For anyone wondering, I'm running a BMS intake and catless dp that was recently installed. Haven't had the chance to tune yet so stock power still (goes to show how much that catless dp frees up the turbo in itself).
F10 535i | Retired: E60 ///M5 | E92 335i
"If everything seems under control, you're not going fast enough"
-Mario Andretti
      04-27-2018, 03:46 PM   #38
SC300T
Drives: 13 E92 M3, 540xi, 535ix GT
Maybe we all just need a little JB Weld on that sensor and see if the stock pipe holds???
      04-27-2018, 05:13 PM   #39
Shieldze1025
Drives: F10 535i
After looking deeper the sensor does have screws but the flange separates from the pipe. Def worth the upgrade, but for those wondering, man fix will get you by until the new pipe ships.
ey2001310.00
      04-27-2018, 07:20 PM   #40
Proimport
Drives: 2014 BMW 535i
I had a minor crack in my never noticed until I upgraded to er charge pipe. Had less then 32k Miles.
      04-27-2018, 08:15 PM   #41
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
Zip ties goes a long way!!! Love them
      04-29-2018, 11:11 AM   #42
5soko
5soko's Avatar
333
Drives: M5
Interesting where we are having issues with our chargepipes. At the seal on the mount of the TMAP sensor.
I guess we could throw some jb weld or some strong glue around the base of the sensor holder to help keep it strong, ahead of time.
Current: E63S AMG 4matic RENNtech || M5 Evolve..Eventuri || F10 LCI 535i MHD
      05-02-2018, 04:27 AM   #43
tcabill
tcabill's Avatar
Drives: e63 650i, F10 535i, E93 335i
I had the sensor blow off my CP the exact same way. I epoxied it back together and it held for a few months till then I installed the VRSF pipe. I kept the stocker and will still use it for smog inspection.
      05-04-2018, 11:06 AM   #44
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
You guys make me feel dumb. I ubered for a week to work and back while waiting for my CP to arrive. I had zip ties in the trunk too lol...
