2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications BPC N63 Non TU Flash tuning coming soon
      10-17-2017, 11:36 AM   #23
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
Originally Posted by exylyr View Post
Very interesting - would it be possible to post your N63 Stage 1 vs the stock N63tu?
N63 Stage 1 should be substantially higher than a stock N63tu.
I'd rather see a stage 1 N63 and Stage 1 N63tu overlayed....
      10-18-2017, 12:48 PM   #24
Bob@BPC
Bob@BPC's Avatar
Drives: F30 328i Sport Line
Originally Posted by 135i_vs_ View Post
Please share dyno sheet.
Is this still in Beta? Or it is available on the website as well?
Stage 1 is out of beta, and is for sale, we just havent posted on the website. If you are interested in the tune, just give us a call (919 501 2090) and ask for Tom
Red Line stock N63TU
Blue Line Stage 1 N63 NON TU
FSociety3812.50
      10-18-2017, 04:51 PM   #25
535_BiTurbo
how much boost is on the stage 1 n63 non tu?
      10-19-2017, 06:41 AM   #26
Bob@BPC
Bob@BPC's Avatar
15 peak, then tapers down to 13
      10-19-2017, 07:30 AM   #27
135i_vs_
135i_vs_'s Avatar
Drives: M5, 135i, 335d, F10 550xi
Any special procedure to follow prior to pulling the DME on an F10?
      10-19-2017, 09:53 AM   #28
Bob@BPC
Bob@BPC's Avatar
Make sure you have a fresh set of plugs installed and 91 -93 octane fuel. Make sure to disconnect the battery before removing the DME.
      10-24-2017, 10:04 PM   #29
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Looking for a guinea pig for the S63 non-TU?
'10 BMW X5///M - Alpine White on Sakhir Orange - JB4 w/ HCP Stage 2 BEF, NGK 97506 @ .20, SS tubing & BMC filters, gutted cats, AC Forged 312 22's, H&R 2"
'98 BMW 740iL - ///E39 M5 6spd swap, fully built engine (sleeved, P&P, cams), 3.46 LSD, H&R Stage 2/Bilstein HD, Magnaflow 14816's
'97 BMW 328ci - ///E36 M3 clutch & L/W flywheel, Z4///M 18's
      11-01-2017, 07:14 AM   #30
Bob@BPC
Bob@BPC's Avatar
Just did one, already have a tune out for the X5m We can flash e70/e71 over obdII with out need to unlock them.
      11-01-2017, 12:51 PM   #31
Bossman535
Drives: Alpine white
How hard is it to remove the DME on the n63?
And what kind of power gains can be expected from Stage 2 tune with catless downpipes?
      11-03-2017, 08:46 AM   #32
Bob@BPC
Bob@BPC's Avatar
Its located behind the passenger side headlight. You have remove the cover and disconnect the plugs from the dme and remove another cover plate, it slides out and then you have remove the coolant connections.
As for the power gains on stage II. We should be seeing another 25-35hp over the stage I tune.
      11-16-2017, 09:19 AM   #33
Bob@BPC
Bob@BPC's Avatar
UPDATE:
We've added stage 1 tune our webstore: https://bimmerperformancecenter.com/...x-stage-1-tune
This tune is also included in our black Friday sale
FSociety3812.50
      11-16-2017, 10:24 AM   #34
135i_vs_
135i_vs_'s Avatar
UPDATE:
Thanks! I guess we have to place the order on November 24th with the code on your website, but not before that?
      11-16-2017, 11:28 AM   #35
535_BiTurbo
How much will the Stage 2 tune be?
      11-16-2017, 12:57 PM   #36
135i_vs_
135i_vs_'s Avatar
Bob@BPC I plan to run 70/30 | 93/E85 mix with the tune. Should be no problems right? Just want to confirm. Thanks.
      11-16-2017, 01:48 PM   #37
Bob@BPC
Bob@BPC's Avatar
Thats correct, sale code is only good on black Friday
$100 more than the stage 1
It will not hurt it, Im looking into doing a e40/e50mix tune soon.
FSociety3812.50
      11-16-2017, 02:26 PM   #38
535_BiTurbo
Whats the difference between stage 1 and 2? is it more boost and timing?
      11-21-2017, 12:24 PM   #39
Bob@BPC
Bob@BPC's Avatar
Stage II has timing, fuel and boost adjustments and downpipes are required for the tune upgrade. Power gains will be around 40 -50rwhp more than stage I.
      11-21-2017, 02:45 PM   #40
Bossman535
Can you guys do the burble tune ? Where exhaust pops and cracks ? ?
      11-21-2017, 03:30 PM   #41
535_BiTurbo
How much boost on Stage 2? Any issues with boost variances between each turbo bank at the higher boost levels?
      11-21-2017, 03:59 PM   #42
Bob@BPC
Bob@BPC's Avatar
Still working on it, trying to find a good balance between the different levels of duration on an auto car so its not burbling all the way down to idle on decel.
stage II we are going to target 17 -18 peak and drop down to 15 near red line. We did some testing a few years ago with a jb4 and at 20psi, we did see one turbo make more boost than the other. We've seen this also on the N63TU(21lbs) & even on the S63TU (28+lbs of boost on hybrids)
      11-22-2017, 07:46 PM   #43
m5james
m5james's Avatar
Nothing S63 is listed on your website, only E70/E71 diesel stuff.
      11-30-2017, 11:13 AM   #44
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
228
Drives: 2011 550i m sport
EDIT: We've also done some f10 work as well http://f10.m5post.com/forums/showthread.php?t=1365679
We already have a tune out for the 2013 - 2017 TU engine, dyno below.
Are these dyno numbers (before and after) with or without correction factor?
I looked at the this again morning and I see in the upper right corner CF SAE, so duh!! Yes its with correction factor. I answered my own question.
