2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum HID Recommendations??
      01-26-2014, 05:17 AM   #1
oldschool_94
oldschool_94's Avatar
Drives: 2012 F10 528i
Hey guys
I have a 2012 528i. I'm looking to upgrade my low beams to 6k and do a fog light conversion to 6k as well. What's the best/most commonly used kits out there from our members? I'm not concerned with price. I don't want a cheap 8 month lasting kit. Any suggestions or opinions are welcomed. Thanks guys!
      01-26-2014, 01:20 PM   #2
1HOT BMR
1HOT BMR's Avatar
Drives: Car-less and shopping +'12 35d
In my experience one does not get better lighting with an HID kit. I have done three of them always thinking/blaming the quality level of the kit, but it's not the bulb that makes the difference - it's the reflector. Yes, the light is whiter and brighter but the illumination it provides is no better and many times it is worse than the original halogen light. The higher the temperature of the bulb you use the higher blue/purple color and the lower the performance. Now, if you are just doing it for looks then my comments are irrelevant - just go for it
      01-26-2014, 02:20 PM   #3
BMWrules7
Drives: 2015, 740 LdX, Alpine White
Agreed. The yellowness provides more "thickness" in your nighttime illumination.
The whiter the light, the thinner the illumination.
      01-26-2014, 08:28 PM   #4
oldschool_94
Yeah I've noticed that. 6k color is actually lower lumens than stock. Thanks for the replies I appreciate it!!!!
      01-26-2014, 09:08 PM   #5
2k15f30
2k15f30's Avatar
Drives: 2015 335i M Sport
Morimoto
Morimoto is the only aftermarket brand Id ever go with to retrofit factory halogen.
Osram Xenarc CBI
People are correct in saying the higher the color temperature the less lumens you get in output. This said 5k color temperature will fluoresce reflectors and signage better than the stock 4700k lamps. The Xenarcs will give you more output at the same wattage so this is your workaround for the problem presented here. If you have the dough swap em. Id do it in a heartbeat but once a month the car chews up my extra money in the form of a lease payment.
Let us know what you come up with for your car.
      01-27-2014, 08:35 PM   #6
gtmassive75
gtmassive75's Avatar
361
Drives: G05 X5,G20 M340,Infiniti Q50RS
+++ Morimoto..http://www.theretrofitsource.com/hid-systems.html
2020 G05 MSport 40i--Phytonic Blue Metallic/Vernasca Coffee Leather/Multi Contour SeatsTrim/Executive Package/MSport Brakes/Icon Adaptive Led HeadlightsW/Laserlight/Harman Kardon/Heated Front Seats Armrests & Steering
      01-29-2014, 04:19 PM   #7
hufington
hufington's Avatar
3121
Drives: 2022 X5 m50i
+1 for Morimoto. I have the 4300K in my fogs and it is bright as hell.
2022 BMW X5 m50i
2024 MB S63 on order
'18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3
      01-29-2014, 06:20 PM   #8
Bobby_Drake
Bobby_Drake's Avatar
390
Drives: '16 X5M
Morimoto from retrofit source. like everyone else said 6000K is probably the highest temp you want. look at the lumens rating and this will tell you the light output. you want to stay in the 4300K to 6000K. as the K rating goes up, the lumens go down, thus light functionality decreases as well.
