01-26-2014, 05:17 AM | #1 |
Rep 30
HID Recommendations??
Hey guys
I have a 2012 528i. I'm looking to upgrade my low beams to 6k and do a fog light conversion to 6k as well. What's the best/most commonly used kits out there from our members? I'm not concerned with price. I don't want a cheap 8 month lasting kit. Any suggestions or opinions are welcomed. Thanks guys! |
01-26-2014, 01:20 PM | #2 |
Rep 351
In my experience one does not get better lighting with an HID kit. I have done three of them always thinking/blaming the quality level of the kit, but it's not the bulb that makes the difference - it's the reflector. Yes, the light is whiter and brighter but the illumination it provides is no better and many times it is worse than the original halogen light. The higher the temperature of the bulb you use the higher blue/purple color and the lower the performance. Now, if you are just doing it for looks then my comments are irrelevant - just go for it
01-26-2014, 02:20 PM | #3 | |
Rep 1,684
The whiter the light, the thinner the illumination. |
01-26-2014, 09:08 PM | #5 |
Rep 169
Morimoto
Morimoto is the only aftermarket brand Id ever go with to retrofit factory halogen. Osram Xenarc CBI People are correct in saying the higher the color temperature the less lumens you get in output. This said 5k color temperature will fluoresce reflectors and signage better than the stock 4700k lamps. The Xenarcs will give you more output at the same wattage so this is your workaround for the problem presented here. If you have the dough swap em. Id do it in a heartbeat but once a month the car chews up my extra money in the form of a lease payment. Let us know what you come up with for your car. |
01-27-2014, 08:35 PM | #6 |
Rep 815
Drives: G05 X5,G20 M340,Infiniti Q50RS
+++ Morimoto..http://www.theretrofitsource.com/hid-systems.html
2020 G05 MSport 40i--Phytonic Blue Metallic/Vernasca Coffee Leather/Multi Contour SeatsTrim/Executive Package/MSport Brakes/Icon Adaptive Led HeadlightsW/Laserlight/Harman Kardon/Heated Front Seats Armrests & Steering
01-29-2014, 04:19 PM | #7 |
Rep 1,354
Drives: 2022 X5 m50i
+1 for Morimoto. I have the 4300K in my fogs and it is bright as hell.
2022 BMW X5 m50i
2024 MB S63 on order '18 X5 50i / '16 BMW F10 550xi / '13 BMW F10 535i / '07 BMW E64 630i / '03 BMW E65 745i / '95 BMW E34 540i / '89 BMW E30 M3 |
01-29-2014, 06:20 PM | #8 |
Rep 1,152
Morimoto from retrofit source. like everyone else said 6000K is probably the highest temp you want. look at the lumens rating and this will tell you the light output. you want to stay in the 4300K to 6000K. as the K rating goes up, the lumens go down, thus light functionality decreases as well.
