2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 headlight problem, code 800FC8
      03-16-2024, 07:07 PM   #1
TZ
Drives: 2011 535i xDrive, 2014 435i CO
Recently, my 2011 F10 535iX has headlight issue. No left turn light, no left halo.
iDrive showed
"Left turn light malfunction"
"Daytime lamp malfunction"
Pull a code of 800FC8, LIN bus headlight driver module(TMS), left, communication fault.
Does anyone have idea?
TIA
2014 435i RWD Convertible
Service Manual: www.newtis.info
Part: http://www.realoem.com
      03-17-2024, 09:50 PM   #2
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
You need to replace the headlight module. You are likely getting moisture in the headlight and it fouled the module. Very common problem in the F10. I just changed my module 3 weeks ago, PITA to get to.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      03-18-2024, 07:15 PM   #3
TZ
Which module did you change, TMS or FRM? Do you need to reprogram?
What symptom did you have?
      03-31-2024, 08:24 PM   #4
TZ
Update:
The fault code was 800FC8, LIN bus headlight driver module(TMS), left, communication fault.
I swapped the left/right headlight assemblies and confirmed the problem followed the left one. I removed the left light model TMS. It looked clean and no suspicious. I measured the wires point to point from headlight connector to TMS connector and found no fault.
Then I cleaned and resealed the headlight assembly. Put it back. Amazingly, it works again! Still not sure what is the root cause. Giving the headlight had condensation before, the only thing I can imagine was moisture and contamination (but I saw none) on the connection points.
