2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Headlights not working
      03-25-2024, 01:41 PM   #1
lukavergille
lukavergille's Avatar
Georgia
206
Drives: BMW 535i F10
2013 BMW 535i  [9.50]
Hey, i had my car (2012 model) parked for 2 weeks in winter and apparently a moisture went into both headlights. On the right one a low beam stopped working but DRL still works, on the left one its vice versa - DRL stopped working but low beam works. I took both headlights off and dried them, then swapped TMS modules thinking they were faulty but it didn’t change anything. Checked a DRL modules and they also look fine. Any idea what could cause this problem? Does these cars have a fuse for headlights that might be blown?
      03-25-2024, 07:56 PM   #2
TZ
Drives: 2011 535i xDrive, 2014 435i CO
What type of headlight do you have? Adaptive Xenon?
2014 435i RWD Convertible
Service Manual: www.newtis.info
Part: http://www.realoem.com
      03-26-2024, 12:25 AM   #3
lukavergille
Georgia
206
Yes
      03-26-2024, 11:48 AM   #4
blue335xi
blue335xi's Avatar
Drives: 2008 335i
Have you figured anything out, I'm having same issue lost low and high beam adaptive xenon lights was thinking to change tms xenon driver module.
      03-26-2024, 12:53 PM   #5
lukavergille
Georgia
206
Checked with scanner and is says that there is a short circuit with footwell module, will check the FRM module tomorrow to see if it really is the issue. Have your both headlights stopped working or is it single?
      03-26-2024, 05:41 PM   #6
blue335xi
blue335xi's Avatar
Drives: 2008 335i
Yes both lights are out just dlr and blinkers are working, I'm having these codes
800f2e
800f2f
low beam headlight faulty or re ignition for xenon failed.
      03-26-2024, 09:25 PM   #7
TZ
To replace TMS, you need to recode or reinitialize.
