2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Remus exhaust and rear diffuser
      07-20-2015, 01:01 PM   #1
M5Beast_NYC
Drives: 15 M5
I just recently install my Remus exhaust on my 535i xdrive and I am using the 550i rear diffuser to allow the dual exhaust opening.
My problem is the rear exhaust hanger dont line up properly with the 550i rear diffuser opening. I tried adjusting the hanger two different ways and its either too far out or too far in if the hanger is bolted down correctly. Right now, I just have the exhaust hanger tied up so I can center it.
Has anybody else ran into this issue? Did I get the wrong diffuser? any advice?
Thanks in advance.
      07-20-2015, 01:20 PM   #2
OEMonsterz
OEMonsterz's Avatar
Drives: 535D M Sport
Pictures please
      07-20-2015, 09:50 PM   #3
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
I know if u use a M5 diffuser the exhaust has to be modified slightly on a 535 but I would think the 535 and 550 should be the same. Pictures would Definitely help if u can take some.
      07-20-2015, 10:08 PM   #4
M5Beast_NYC
Drives: 15 M5
Ill take some pics. It started raining here then it got dark so didn't get a chance. Thanks.
      07-29-2015, 12:02 PM   #5
KmanM3
Drives: 2017 540i
Any updates? I will also be installing a Remus soon and want to make sure there are no issues.
      07-29-2015, 04:58 PM   #6
M5Beast_NYC
Drives: 15 M5
Apologies for the delay.
if you look at the pic, there is about 2 inches between the bolt and the bracket hole. I can mount the bracket in the bolt, but once i do that I cant put the rear diffuser on because the exhaust tips will not line up with the opening.
To go around this problem... right now i have it lined up but the rubber hanger is held on by zip ties onto the body.
again, I have not seen anybody complained about this before so it might just be mine. I bought the exhuast used so the previous seller might not have gave me an additional bracket.
let me know how your install goes
      07-29-2015, 08:04 PM   #7
KmanM3
Drives: 2017 540i
Mine is also used so hopefully everything lines up correctly.
      07-29-2015, 09:07 PM   #8
lsturbointeg
So I'm trying to search in the forums if the 535 and 550 exhaust openings are different or the same? No luck yet? I know valbmw would know!
      07-29-2015, 09:22 PM   #9
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
535 and 550 openings line up on center. I know this because I added quad tips to my stock exhaust first, and then my M Performance exhaust, and I am using an OEM M Performance rear diffuser made for a 550. The exhaust outlets line up perfectly. The only reason this should be off is if it was made (or modified) to line up with an M5 diffuser, where the muffler outlets are more centered.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      07-30-2015, 12:02 AM   #10
M5Beast_NYC
Drives: 15 M5
My thoughts are the same. But I dont have an m5 diffuser to test with. If I go with the m5 diffuser that means I have to modify my support bracket and might lose my comfort access in the trunk. Eeerr
      07-30-2015, 06:37 AM   #11
The Beast
The Beast's Avatar
Drives: VW Transporter Sportline
Can't you just get the bracket extended by welding on a piece? Any decent shop should be able to do this
      07-30-2015, 10:31 AM   #12
M5Beast_NYC
Drives: 15 M5
Its definitely an option. I wanted to get feedback from others that had this exhaust installed before I make any expense on getting some welding work done.
      07-30-2015, 10:39 AM   #13
valbmw
valbmw's Avatar
94
Drives: 2016 BMW F10 M5 CP 600 hp
The case is simple: muffler brackets needs to be adjusted. Let me provide you with my research on that, since building the exhaust is important project and you asked to share install experience.
The upper (car’s) bracket (6) is always on its place and bolted to the car bottom, the lower (muffler’s) bracket should be aligned level to it (see drawing), and together they come into the rubber ring (7). There is no other position to the brackets until they are modded.
These are the brand new Remus mufflers for 535i (see white label). The muffler’s bracket is placed next to the side. The rubber ring when placed will look at the muffler side.
Size:  472.0 KB Name:  3.JPG
Your picture shows the muffler bracket is placed more towards the tips, so it looks like the M5 narrow type and the split is like two-inch. I would suggest to check the label (if present), because maybe your muffler brackets are not for the 535i.
Please see links with additional pictures of Remus for 535i and bolt-on install:
http://f10.5post.com/forums/showthread.php?t=635311
http://f10.5post.com/forums/showthread.php?t=643868
http://www.remususa.com/WebRoot/Stor...0-0500lr_1.jpg
Now let's have a look at my Supersprint install. As you can see, regardless of type of the rear diffuser, both brackets and the rubber ring must be aligned and sit at the proper place:
Size:  120.2 KB Name:  7.JPG
Size:  111.5 KB Name:  9.JPG
Size:  131.1 KB Name:  10.JPG
Therefore you need to bolt on the car bracket back to its place and adjust the muffler bracket (move or extend it, as already said) by two inches towards the center to fit its proper position.
I don’t think you need to change diffuser if you don’t want the M5-style. However shape and material of the diffuser doesn't affect function of the comfort access to trunk since the sensor is just a capacitive antenna wire.
      07-30-2015, 10:46 AM   #14
M5Beast_NYC
Drives: 15 M5
Just found this link from Alan. Post #11 shows a remus exhaust installed on a 550. i think this is the same issue that i have so maybe an M5 diffuser is the way to go...
http://f10.5post.com/forums/showthread.php?t=950378
the other post ive been reading is by modifying the existing single tip to accommodate the larger dual tip. By cutting it open, are can pretty much guarantee that it will be centered. I chose to keep my single tip diffuser in tact in case i need to revert to stock.
let me know if anybody else have feedback on their install.
      07-30-2015, 11:45 AM   #15
M5Beast_NYC
Drives: 15 M5
Valbmw, thanks for the input. I will take another stab at it when i get some time. I will mount the bracket on the bolt and figure out the rubber hanger situation from there.
      07-30-2015, 12:04 PM   #16
valbmw
valbmw's Avatar
94
You're welcome!
I always wanted the diffuser and exhaust in M5 style, but then realized how many tricks with all these brackets, bolts and different plastic and carbon stuff it will involve. In my case install has been done by a tuning shop in 2 days.
      07-30-2015, 10:09 PM   #17
lsturbointeg
Some really good info there valbmw!
      07-30-2015, 10:10 PM   #18
lsturbointeg
Carbonm3ny... post some pictures when u get it done!
      08-07-2015, 04:33 AM   #19
KmanM3
Drives: 2017 540i
Did you get it to work?
      08-07-2015, 03:31 PM   #20
Boss330
Boss330's Avatar
When I bought my Remus exhaust there was a couple of extra brackets included with different layout. Perhaps you didn't get the proper bracket from the previous owner?
      08-07-2015, 04:57 PM   #21
lsturbointeg
By the Looks of it it Looks to be Remus is just a catback system. Is worth upgrading the pipes all the way up to the downpipes?
      08-07-2015, 05:13 PM   #22
M5Beast_NYC
Drives: 15 M5
Remus is an axle back exhaust. Not a catback unfortunately
