2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications N63 and N63 TU 60-130 times
      08-30-2018, 10:33 AM   #1
badblack550xi
badblack550xi's Avatar
Hey guys would like to start a thread for 60-130 N63 and N63Tu powered cars.
List your mods and share your picture or screenshot of 60-130.
Ill start:
2013 550i Mods: N63 intake, 60mm Alpina Turbos, Dinan Intercoolers, N63 intake stage 3 tune. 100 octane.
Results:
2011 550i RWD 60-130 7.35
      08-30-2018, 11:32 AM   #2
AMT92
AMT92's Avatar
Iran
390
Drives: F85 X5M
What did you log this with?
      08-30-2018, 12:08 PM   #3
ey2001
ey2001's Avatar
310
Drives: F10 535i 6spd
probably this...
https://www.amazon.com/dragy-10Hz-Ba.../dp/B077KKPMTB
      08-30-2018, 12:27 PM   #4
badblack550xi
Draggy was done in LA
      08-30-2018, 04:10 PM   #5
535_BiTurbo
Drives: 2012 550I - BMS Stg 1 & CAI
Ill start:
Results:
What does a stock N63 and N63tu run 60-130 in?
      08-30-2018, 11:20 PM   #6
badblack550xi
no clue but my 2013 550 N63 at the time when it set the 11.8 1/4 record which still stands 3 years later was only able to do it in 10.8
      09-16-2018, 05:07 PM   #7
M335
M335's Avatar
47
Drives: E90 n55 IG@FrozenF10
Who did 1/4 10.8?
      09-17-2018, 08:25 PM   #8
535_BiTurbo
Originally Posted by M335 View Post
Who did 1/4 10.8?
he is saying 60-130 in 10.8
      11-15-2018, 08:25 AM   #9
Drottam
Drives: 2019 M5C
2014 550i xdrive
JB4 wBCM, BMS MI kit dual cm7 pre IC dual cm3 pre turbo, ARM DP, Frequncy intelligence cat-back, 20” Ferrada F8-FR5, conti extreme dws, 2-step colder plugs, HR Springs. Stock everything else.
60-130: 8.31s
[IMG][/IMG]
M33546.50
      11-15-2018, 01:28 PM   #10
badblack550xi
Originally Posted by Drottam View Post
2014 550i xdrive
60-130: 8.31s
[IMG][/IMG]
Thats moving! similar to my 2010 550i N63 test car with Meth, JB4, BCM, Back End flash by me. Stock everything else.
      11-15-2018, 04:31 PM   #11
535_BiTurbo
whats a backend flash?
      11-15-2018, 05:54 PM   #12
Drottam
Drives: 2019 M5C
Really! I’m surprised you got an N63 going that quick. Must have solved the high boost issue with the BEF. FYI, I also ran a best 11.05s 1/4 mile before the MI...I didn’t get back to the track after installing MI.
      11-15-2018, 07:10 PM   #13
M335
M335's Avatar
47
Let’s see log or it didn’t happen
      11-16-2018, 08:25 AM   #14
badblack550xi
ask and you shall receive
      11-16-2018, 10:21 AM   #15
Drottam
Drives: 2019 M5C
That’s much faster than my pull man! Crazy fast for stock turbos. I was running 28-29 psi in cold weather to get my time. When did you run this? I have so many questions...I mean I really maxed out the car running the 8.31. What’s the secret??
M33546.50
      11-16-2018, 02:05 PM   #16
badblack550xi
It’s very impressive numbers for n63, I’m assuming that’s on Alpina turbos
Nope stock. Right now I’m developing a hybrid turbo setup already in testing. Biggest issue is the fueling.
      11-16-2018, 02:07 PM   #17
badblack550xi
Also 28-29psi I guess at big Psi levels N63 is better recently in cold weather.
      11-16-2018, 02:45 PM   #18
M335
M335's Avatar
47
Hmmm very interesting...
So what year is that 550i? Would you upload jb4 log from that run?
      11-17-2018, 03:22 AM   #19
badblack550xi
2011 ill look for the log
      11-17-2018, 04:06 AM   #20
warpeacelove
Drives: 550i
Can’t you use M5 fuel pumps to address the fuel issue?
      11-17-2018, 10:58 AM   #21
Drottam
Drives: 2019 M5C
I also find it interesting...that is the same run time and video of Sergy; a guy in Russia with a N63 who has hybrid turbos. This is his best time before the tuning was complete. I think I still have the fastest stock turbo set up
[IMG] [/IMG]
      11-17-2018, 11:18 AM   #22
M335
M335's Avatar
47
He’s not going to find that jb4 log simply because it’s not his dragy log, back end flash, nor car (btw car is 2010 not 2011) nor anything he is claiming for 7.85s run...
Badblack550xi why are you claiming some Russian guys (Sergey Krasnodar,Krasnodar,RU) dragy log as YOUR test car with your back end flash on stock turbos?
First of all Badblack550ix is not a tuner.
Second he went on dragy and took someones screenshots and video and claiming that’s his....
Third, and another lie, is that the 2010 550i had a hybrid stage 2 turbos on stock flash NOT on stock turbos & his supposed development back end flash as Badblack550ix claimed.
