2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Having to add coolant...no smoke or smell
      03-05-2023, 01:48 AM   #1
Kermdaddy
Drives: 2016 550I
I keep having to add coolant about every week (2016 550i). Doesn't run hot, smell, or smoke. I took the plastic cover off the engine and saw this.
You think this is my issue?
      03-05-2023, 04:56 AM   #2
SWFLf10
SWFLf10's Avatar
That’s a common issue from what I’ve read. I believe some have replaced the stock T with something a bit stronger. Definitely is leaking there, but I couldn’t say just how much. I’d start there though and keep monitoring. Make sure to bleed the coolant system afterwards and keep checking.
      03-05-2023, 05:41 AM   #3
Hoa
Yes, common fail point on 550. You can go to hardware store and get brass fitting to make it a one time replacement.
      03-05-2023, 07:42 PM   #4
Kermdaddy
Drives: 2016 550I
Thanks guys. That is what I thought but just wanted to make sure I didn't end up down a deep expensive hole for no good reason.
I'll just replace the hoses, tees, etc.with the other maintenance things I need to do. Brakes being one of them. But hey how else could I have spent my tax return? Wish there was enough ro throw some catless downpipes with it lol.
      03-06-2023, 10:51 AM   #5
kohsin
Drives: 2013 F10 550ix
Make sure you also look for the Y adapter down under between the valley where the turbos sit. That one is harder to locate but usually fails . That one will cost you an arm and leg to replace as the turbos need to be removed.
      03-11-2023, 01:43 PM   #6
Kermdaddy
Drives: 2016 550I
Thanks for the heads up. My future brother-in-law is a mechanic so hopefully I can swindle my way into borrowing the lift.
