2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Ongoing remote locking issue - Diversity Antenna?
      03-15-2024, 11:35 AM   #1
Jegethy
Jegethy's Avatar
Drives: F10 530D
Hi folks,
I have a 2011 F10 and for the past year I've been having an ongoing issue with my key fob / remote locking. You can check my previous threads for full context, but TL;DR, I don't believe it's the key at fault anymore.
Because recently my key fob (I only have the one) had been working flawlessly, but after some very heavy rain, it stopped working again. That made something click in my head and I realised that the previous issues tended to occur after heavy rain or having my car washed.
Is it possible that the diversity antenna is at fault? I've checked for error codes and don't have anything relating to the remote locking system, and I don't have any water ingress in the car and there are no obvious signs of a leak. I'm not even sure if this is an issue on the F10 as the antenna is inside the car, but I know the diversity antenna in general can cause a lot of issues and I'm not sure what else it could be at this point. Something in the sharkfin?
      03-15-2024, 02:09 PM   #2
Qsilver7
Qsilver7's Avatar
Drives: F06 650ix GC / F15 X5 50i
There are multiple aerials for comfort access…some are in the interior and some are on the exterior.
The shark fin attenna is for GPS/phone/satellite radio signals.
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      03-15-2024, 11:06 PM   #3
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.21]
2009 BMW 328i Touri ...  [7.90]
2013 BMW X5 35i  [7.63]
2011 BMW 528i  [8.75]
2006 Mazda3  [5.50]
It sounds like you're on to something with the moisture intrusion... Isn't the DA under the rear headliner, but inside? Sharkfin area might be leaking, or even around rear window seal or sunroof? But like Qsilver7 is thinking, maybe another antenna or the CA module? I think that's under the dash, but maybe moisture there???
      03-17-2024, 09:12 AM   #4
Qsilver7
Qsilver7's Avatar
F10 Interior & Exterior Comfort Access Aerials:
E84 - interior center console aerial front:
E22 - interior center console aerial rear:
E74 - interior aerial rear parcel shelf
E28 & E36 - luggage compartment aerials
E23 - exterior left side aerial
E83 - exterior right side aerial
E27 - rear bumper aerial
B207 - ring aerial
      03-19-2024, 08:44 AM   #5
Jegethy
Jegethy's Avatar
Drives: F10 530D
Hmm, interesting. I didn't realise there were so many. I had an issue with the vapour barrier leaking, but had it repaired a while ago. I wonder if that is still an issue and is causing a problem with the left and/or right antennas?
Do you know if there would be any errors? I checked with bimmercode and didn't see anything relating to the remote locking.
      03-19-2024, 04:21 PM   #6
Qsilver7
Qsilver7's Avatar
If they are any errors...you'd need the Bimmerlink (sister app to BimCode) to look for errors.
