2010 2011 BMW 5 Series Forum F10 F11 Wagon\Touring Wheel Spacers? |
07-21-2013, 07:32 AM | #1 |
Rep 208
Hi all,
I had spacers on my E61 550i which really improved the look. I'm thinking of doing the same again on my wagon\touring. I have the 19" optional rims, 245 wide tyres. What spacers sizes are you guys running? All my searches return results for the saloon. I'm thinking 12mm front and 15mm rear. I don't want any rubbing, rolling arches, fender work etc. I will potentially lower slightly on ACS springs at some point. Thanks in advance. G |
07-21-2013, 10:24 AM | #3 |
Rep 208
Thanks.
Do you have any pics? I'm not concerned about the rears, 15mm will fill the arches nicely, in fact I could maybe get away with 20mm. But I'm not so sure about 12mm on the front, the other option is 10mm. G |
07-21-2013, 01:21 PM | #4 |
Rep 572
hi,
here you go: with 10mm per side (front and rear) on 8,5xET 35... am pretty happy with teh outcome. tüv tested the combination with 300kg in the book with the wheels up on a wedge.. very closed to rubbing...
Daily: Porsche Panamera 971 | BMW 520xD G31
Sh!tbox: BMW Z4 M E86 | BMW 1M E82 | BMW M3 E90 Insta: bmw.shitbox |
07-21-2013, 02:11 PM | #5 |
Rep 208
^ wow, stunning!
Thanks. I'll need to work out the difference in offsets. What wheels are those? How is the ride? Also, is that an additional front lip? G |
07-21-2013, 03:31 PM | #6 | |
Rep 572
if you have the optional OEM 19" wheels, then you have ET 33 front and rear. With 10mm on each side, you should be fine. It would stick out a further 2 mm compared to my setup - that should work. I would not go for more than 10mm -> safety comes first and i saw it with TÜV putting 300kg in my car and putting diagonal wheels on wedges - effectively this is the extreme and simulating high speed cornering with weight. After seeing how close it gets, I am not sure how people go for more..
07-21-2013, 04:09 PM | #7 |
Rep 208
20" I assume?
I measured the gap from the tyre to the outer arch. My front is only 5mm but the rear is 20mm. If I fit 10mm the front wheel will stick out past the wing which I don't want. I'm thinking 15mm rear only now. I've ran hub centric spacers on my M3 track car so it's not a concern. In fact some manufacturers won't make hub centric 10mm for safety reasons, eibach being one of them. |
07-21-2013, 04:29 PM | #8 | |
Rep 572
if you have OEM wheels, i am sure you have more than 5 mm for teh front. See my previous posting.
07-21-2013, 04:34 PM | #9 |
Rep 29,202
If you're not dropped the fronts are pretty flush, but the fronts will camber in when you lowered, so you need a lower offset/spacers on the front when lowered.
01-28-2014, 02:59 PM | #10 |
Rep 169
Drives: LCI F11 MSport Xdrive (I.Blue)
01-28-2014, 03:14 PM | #11 |
Rep 208
Great timing to bring this thread alive again, just away to buy spacers
I've decided 10mm front and 12mm rear. What 10mm spacers are you guys using? H&R? Or the expensive Macht Schnell spacers? |
01-28-2014, 03:23 PM | #12 | |
Rep 169
Would like to find out as well. (I'm in phase one....trying to decide if 10mm (front and rear) would be good enough on my f11 with m351 or not ) |
01-28-2014, 03:27 PM | #13 |
Rep 208
My winter wheels are 7mm more aggressive in offset and I tried 3mm spacer on the front and it was perfect. Bought some cheap ones off ebay for £3 just for testing on my driveway.
Did the same on the rear and 12mm would be safer, but 15mm is definitely possible to be as flush as the front. |
02-11-2014, 04:09 PM | #14 |
Rep 169
02-12-2014, 11:43 PM | #15 |
Rep 375
Drives: 2011 535i Sport - P1, P2
Check out this thread to see before and after pics with the spacers:
http://www.bimmerfest.com/forums/sho...d.php?t=663170 |
02-16-2014, 02:56 PM | #16 |
Rep 5
Hey rsyed,
Wow, thats a very great touring you 've got! I'm just wondering about the ET at the rear. Is yours an xdrive? RWD comes with ET 33 at front and ET 44 at rear. xdrive should have 44 allround. If so, ET 35 + 10mm spacers make more than the 2% of the original track width. I wonder how TÜV accepted this. I want to put the Breyton Race LS 10x20 ET35 at rear (without spacers). Could this work? Regards, Itanium |
02-16-2014, 05:40 PM | #17 | |
Rep 29,202
02-17-2014, 03:19 PM | #18 | |
Rep 5
I always thought it was the other way round. A friend of mine has got an F11 LCI xdrive that came with ET43 OEM wheels. But there should be enough space to put some 10-20mm spacers. Itanium |
02-18-2014, 07:48 AM | #19 |
Rep 29,202
Are you sure they're ET43, pretty sure the LCI is the same as pre-LCI offset wise so should be ET33.
02-18-2014, 02:34 PM | #20 |
Rep 5
