2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Removing 535 m sport diffuser
      07-16-2013, 09:11 PM   #1
MIKF10
Drives: 2011 535i M Sport
Hi I bought a 550i m sport diffuser to accommodate a quad exhaust, does anyone here know how to remove the existing 535i diffuser? Is it hard to do? Tools needed?
It would be awesome if anyone has a how to video or pictures of the process.
Difficulty rating on a scale of 1-10?
Thanks!
      07-17-2013, 12:01 AM   #2
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
Difficulty rating would be a 3 depending on how mechanically inclined you are. Get under the rear bumper and look at the back of the diffuser, you'll see it's only held on by tabs(if I remember correctly). Not hard to do, just a bit time consuming and hurts your fingers getting those tabs undone. You should be able to swap the diffusers in about 15-20 minutes!
      07-17-2013, 02:31 PM   #3
Alan l.
Alan l.'s Avatar
5437
I would rate this a 1-2 and should take no more than 15mins if that. No special tools needed. There is about 6 or so push pin style tabs under the diffuser that you will need to remove. Once those are out you can just push the diffuser out from behind.
Alan
      07-18-2013, 02:01 AM   #4
Aaron@Autosource
98
Drives: F110/F22
Alan
Geez way to make me look like an amateur haha! But everything Alan said is right. Very simple and straightforward. At some point you'll probably think "If I keep tugging, something's going to break." But just be patient and keep popping those tabs off.
      07-20-2013, 04:27 PM   #5
HighConcept
Drives: F-Ten ///M
Well that usually is the main concern...feeling that we might damage something. Most technicians are MUCH more rough than we are haha. Over time with experience you develop a sense of how much pressure to apply and when something is at a breaking point.
