2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 pulling to the right...
      11-07-2010, 12:21 PM   #199
FstTrack
Any more feedback re: this pulling to the right issue? Has anyone had their problem fixed yet?
Mine's still in the shop, but (hopefully) I'll have it back by the end of this next week.
      11-07-2010, 12:47 PM   #200
DuneMan
Drives: 2011 535i, Sophisto Gray
Yep... Mine's also pulling slightly to the right. It's not wearing me out though. I guess it's more pronounced with some owners. My case not so much.
Had my dealer check it out. He says this is already flagged by BMW global as a common provlem and he expects a recall soon.
Honestly, I'm more worried about the hesitation problem when acceleration from zero.
      11-10-2010, 01:11 PM   #201
SCPACKAGING
Drives: 2011 BMW 535
Mine is back in the shop this week for the 3rd time (for the pulling issue). They have already replaced tires, struts, etc. and this time they said they were doing the software update. After two days the show manager said he drove it yesterday and today and it's ready to pick up. They said the same thing the first two times so we'll see what happens when I pick it up later today. My pulling was prettey severe so hopefully it's fixed and not just "better"!
      11-10-2010, 01:27 PM   #202
blackberrycubed
Drives: 535i Xdrive
Excercise lemon law, get a new car. Shove the defective car back up BMW's @ss.
      11-10-2010, 03:29 PM   #203
bazmann
Drives: 2011 535i
My 2011 535i also pulls to the right. It is currently at the dealer, they changed the software and that did not fix the problem, the technician is telling me they are going to change some parts in the steering column. This problem is very annoying, I have to keep holding unto the steering wheel, otherwise, I will drift to the right. I had the car for only one week.
      11-11-2010, 12:40 PM   #204
bazmann
Drives: 2011 535i
I took my car to the dealer for the same problem pulling to the right (2011 535i), the were able to fix it. Now, it is just perfect. BMW is well aware of the problem, according to the tech, the software controls the gear ratio in the steering wheel, the dealers do not have this software yet, it is downloaded from Germany. They downloaded the software and it did not fix the problem, then the techs in Germany tweeked the ratio in the software and the second download fixed the problem. My car no longer pulls to the right. Problem fixed. The fact that the first software did not fix the problem indicates that each vehicle may require specific tweeking until BMW figure out a universal solution. I read some posters mentioned adjusting the struts by 10mm, my dealer did not do that, it was purely software issue.
      11-11-2010, 03:28 PM   #205
savela
savela's Avatar
Drives: 2015 X5M
Glad it worked but I'm a bit confused. How would changing the steering ratio correct the pull without applying a counter turn and therefore making 'wear' more of a problem? Strikes me that the mechanics of a car should have the car run straight as an arrow without any 'correction'.
It is good to know that there exists a solution, though.
      11-11-2010, 05:31 PM   #206
TX535i
Drives: '11 535i
Mine is in right now. Last week a BMW tech was there looking at the GMs car for the same issue, so I took mine in this week. Right now they are moving the struts, and then they'll redo the alignment. We'll see if it works. They didn't say anything about a software fix yet.
      11-11-2010, 08:55 PM   #207
jc031662
Veteran
Drives: F10 535i
Which dealership are you working with?
2011 F10/535i Space Gray ("v2.0"), ZSP, ZAV, ZCV, ZDA, ZPP, ZP2, NASW, 465, 464, 4NB
2011 F10/535i Space Gray ("v1.0") ("Ain't my problem no mo'...")
2008 E60/528i (Retired)
      11-12-2010, 02:38 AM   #208
pharding
Drives: 23 Audi Q4 e-tron + 14 X3 28i
I have a 535i loaner with the standard steering and 250 miles on it, the sloppy feel when driving straight has definitely been fixed. The steering felt light years better than prior F10's with basic steering that were pre-September builds. Dramatically better. I drove a loaner 535i with 4000 miles on it last week and it had the sloppy when driving feel. Hopefully BMW has the sloppy feel issue fixed once and for all.
23 Audi Q4 e-tron; 23 i4 M50 on order
14 X3
Retired: 20 Tesla Model 3 LR AWD; 17 540i x; 14 550i Euro Del; 11 550i Euro Del; 08 550i Euro Del; 06 330i Euro Del; 04 545i Euro Del; 01 530i Euro Del
      11-12-2010, 03:13 AM   #209
HighlandPete
Drives: BMW F11 535i Touring
That is good news, really what we'd expect if the feedback was to 'firm it up', more central feel. Wonder if it will apply to all models, or whether steering will be model related, or even standard or m-sport type settings?
As I see it, no reason why they can't have a dealer 'software' option. You don't like the light steering, opt for the meatier 'dealer tweaked' option. I'd even suggest it could be configured into i-Drive, as the interface is there, so the user can choose the option, without needing DDC.
HighlandPete
      11-12-2010, 10:33 AM   #210
MojoeF10
Drives: 2011 535i
For anyone who has a September or later build, can you please confirm whether or not your car has this issue? Even if you notice a small drift to the right, could you let me know?
I will be test driving a September build next week so that I can compare it to my 'lemon.' Based on previous posts in this thread, the issue appears to be fixed on the September models...but I'd like a little more feedback if possible. Thanks!
      11-12-2010, 12:13 PM   #211
kirbyj
Drives: 2011 535xi
I have a late September build 535xi that I just received and now have 300 miles on it. I have not seen any pulling to the right. I just took the car down to Boston and I even took my hands off the steering wheel for a while and the car tracked perfectly and stayed straight in the travel lane.
      11-12-2010, 12:20 PM   #212
JOHNBMWM5
JOHNBMWM5's Avatar
Drives: 2022 LCI Marina Bay Blue/ Smok
Originally Posted by jc031662 View Post
The new electric steering is far more sensitive and does not pull back to the center like previous models. BUT having said that, the F10 still should not have a pull, no matter how slight, in either direction - it should drive straight - and that is right out of the mouths of 3 BMW field tech reps.
If "ANY" of my BMW's pulled one way or the other they would be returned ASAP as faulty end of story, I really am surprised at all these cars having faults, NONE of my BMW's have had a fault at all!!!.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      11-12-2010, 12:33 PM   #213
BimmerGuyFL
Drives: 2013 F10 BMW 535i M-sport
In general if a car drifts to the right it's because it has a road crown which will cause the car to feel like it is pulling to the right. In the case for the early Build F10 5-series models there was a significant pull to the right which was not normal. In General though car will tend to drift slowly to the right but NOT Quickly.
2013 F10 BMW 535i Alpine White / Oyster Dakota Leather / Anthracite Wood Trim / Steptronic transmission / M Sport Package / Premium Package / Technology Package / Rear-view camera / Park Distance Control
      11-12-2010, 01:08 PM   #214
BimmerGuyFL
I read somewhere that the xi's don't have the electric steering - does anyone know that to be correct? If that's the case, they wouldn't be affected by the pull issue at all -
However, if I'm wrong about that and they do have EPS - then yee-haw! That gives me hope about the week 44 (Nov.) build of my replacement F10.
Yes this is correct, xDrive Model 5-series come with Hydraulic Power steering where as the "i" models come with EPS. I have confirmed it. Trust me! The turns lock to lock and ratio 17.0:0 is still the same.
      11-13-2010, 04:47 PM   #215
gbates
Drives: 2011 550i
Took my 550i to the dealer today. It too pulls to the right. Was told the struts would need adjustment, the car re-aligned, and software upgraded. We'll see what happens... Will pick it up Monday. I'll keep the board posted on the outcome.
      11-13-2010, 04:56 PM   #216
jc031662
Veteran
Drives: F10 535i
What's the manufacture date of you car?
      11-13-2010, 05:00 PM   #217
pharding
They have hydraulic steering as will the upcoming F30.
14 X3
      11-13-2010, 05:03 PM   #218
pharding
I have a September 535i loaner with base steering. It is much better and does not pull to the right. It is spot on.
14 X3
      11-13-2010, 05:10 PM   #219
gbates
Drives: 2011 550i
I believe it was an August build.
      11-13-2010, 08:05 PM   #220
jc031662
Veteran
Drives: F10 535i
Ok. I've driven a couple of August builds too and they had the pull as well. Most people have reported that cars built from September forward are fine.
