2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums USA - NY/NJ/PA/CT Drivetrain Malfunction with AC on
      04-24-2022, 05:58 AM   #1
Fantasy3043
Fantasy3043's Avatar
Drives: F10 528xi
Hello everyone,
Just thought if I could get anyones opinion on if I should change the AC condensor. In traffic while doing a 5-10mph crawl or stop and go traffic the car will rev up a little bit then drop back down to regular idle and will keep doing it until I get a drivetrain malfunction only with the AC on. The moment I turn that AC off the car is perfect. Spark plugs , coils , and belt were recently replaced so I marked that off the list. I just find it weird it only happens when the AC is functional. Any feedback would be helpful. Vehicle is FBO btw.
      04-24-2022, 10:21 AM   #2
Hoa
You only need to replace the AC condenser if there is a leak. If there is one, you will leak all refrigerant and AC will not engage. It will just blow hot air. If your vehicle still blow cold AC, I suspect maybe compressor is failing instead of condenser.
      04-24-2022, 12:55 PM   #3
Fantasy3043
Drives: F10 528xi
Ahh okay. I suspected it was a part that had to do with AC functionality. I will get the compressor checked out.
      04-25-2022, 09:33 AM   #4
TJ@AUTOcouture
TJ@AUTOcouture's Avatar
41
Drives: Multiple
Have the codes read before going down a path that is not needed. Sometimes weird issues like this could also be caused by low battery voltage.
