2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums F10 / F11 5-Series Photos - Video - Media Oil catch can installed
      02-12-2023, 03:43 PM   #1
Petr4271
Drives: BMW f10 2012
Arrow Oil catch can installed
Anyone else running this ? Any result ?
      03-21-2023, 06:42 AM   #2
musclesmarinara75
musclesmarinara75's Avatar
Drives: 2013 BMW F10 N55 535i XDrive
2013 535 XDrive  [9.75]
Yessir, I installed on from Burger Motorsports, defintely helps with getting some of the muck that blows by, I used some customized the hoses for a neater look, very simple to do, just remember to leave space if you want to mount a certain air intake in that location thats the only open area in the engine bay that you can put it, I'll take a pic of my and post it when I get home
$ PURE STAGE 2 {} JORDAN CUSTOM TUNE {} DORCH HPFP {} SNOW METH {} DINAN EXHAUST {} EVOLV DARK OLIVE WRAP $
      03-21-2023, 06:47 AM   #3
musclesmarinara75
Found some old pics of the OCC
Hope this helps
      03-21-2023, 06:49 AM   #4
musclesmarinara75
#2
      03-21-2023, 09:33 PM   #5
Originally Posted by musclesmarinara75 View Post
#2
How about pictures of the connections?
      03-22-2023, 05:21 AM   #6
musclesmarinara75
I'll take some today, totally forget to take more pics yesterday lol
      03-22-2023, 02:10 PM   #7
musclesmarinara75
Pics of connections for OCC
Hope this helps
      03-22-2023, 04:27 PM   #8
Double Nickel
Double Nickel's Avatar
Drives: BMW F10
2015 BMW F10  [10.00]
Hope this helps
My MST intake lives there, any other real estate this can go?
      03-22-2023, 10:56 PM   #9
Next question... Where did you obtain the hoses and what sizes are they?
TIA
      03-23-2023, 06:35 AM   #10
musclesmarinara75
You can put it anywhere you want, as long as you get the hoses to where you want to go, you might be able to drill through the shield that is before the filter on your MST intake and pass the hoses through that and mount the can closer to the are left of mine, I'm not sure how much free space you have in there
      03-23-2023, 06:46 AM   #11
musclesmarinara75
TIA
I used 3/4" for the larger hose that's just a regular coolant hose you can buy from anywhere, connected with a brass male x male hose barb and cut down another coolant hose I found on ebay.... that is the tough one cause of the bend, you dont want too have a heavy kink on that... I've seen people use longer one and loop it around, but that looks horrible, the smaller one from the valve cover is hose from a pack of hoses I found on Amazon, it was a kit from an X5 that worked perfect, not sure of the size, but that can size pretty good and I just used the stock connection form the old linejust cut the ribbed plastic piece off on re-use the connection that goes into the VC.. you'll have to trim down your engine cover if you use it, very simple with a Dremel.
This is the desription from Amazon to the hoses from the X5
For BMW X5 Crankcase Vent Valve 2000 01 02 2003 | 5-Piece Kit | 0450408 | 11151705237
      04-15-2023, 01:54 AM   #12
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Here's the one i used
      04-16-2023, 12:55 AM   #13
Encendido3
Encendido3's Avatar
Drives: 2016 535i M Sport
Did you hang it from the negative post?
      04-16-2023, 08:02 PM   #14
musclesmarinara75
Nice clean look
      04-19-2023, 12:10 PM   #15
lsturbointeg
i did no issues. highly recommend doing this. i acutally just got this from my video i just dropped. check it out if you get a chance
      04-20-2023, 06:36 PM   #16
Double Nickel
Drives: BMW F10
Whats tbe size of these roughly? And how heavy are they?
      04-21-2023, 03:37 PM   #17
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
Probably about the size of a coke can? 1-3lb's?
2015 BMW 535xi
ISTA VM Setup/Tutorial
      04-21-2023, 09:20 PM   #18
musclesmarinara75
Your short on space with that MST.. I was thinking of that intake...lmk where u putting it
      04-22-2023, 04:01 PM   #19
Double Nickel
Drives: BMW F10
1 to 3lbs not bad and i can get a can behind my MST plate, im thinking of just drilling a hole righr beside that core support bar. ...IDK BRUH, but im weird af if i want it i get it and then suffer the pain of the Oj effect, wheels and tire not suppose to fit, brakes all over the place, whats a can a bolt and couple hoses?
      04-24-2023, 01:45 PM   #20
Unspec
Unspec's Avatar
1301
This is where I installed mine.
2015 BMW 535xi
      04-26-2023, 10:21 PM   #21
Houranimd49
Houranimd49's Avatar
Drives: F10 535i xDrive, F25 xDrive35i
I’ve always considered doing this but I’ve debated it because both of my N55 powered cars now have over 100k miles on it. Despite the mileage, is it still worth doing?
      04-28-2023, 10:15 AM   #22
musclesmarinara75
I say yes, can't hurt.. get your engine nut blasted first to clean out what's in there.
