2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Remove cupholder?
      11-16-2010, 08:06 AM   #1
DNA_42
Drives: F10 520d
Remove cupholder?
Does anyone know how to take the cupholder out on an auto?
Thx
DNA
      11-16-2010, 10:39 AM   #2
ghueser
Drives: 2014 M5
There is an illustration of this in the Manual if I remember correctly.
      11-18-2010, 07:12 AM   #3
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Don't have a manual, only the handbook and there's nothing there about removing the cup-holder insert.
I tried to gently prize it out and managed to get a bit of movement, but it felt like something was going to break, so I gave up and pushed it back in.
If you have any further info I'd greatly appreciate it, as I could use the extra storage space for sunglasses.
      11-18-2010, 07:53 AM   #4
ghueser
Drives: 2014 M5
I tried to copy the illustration, but no luck. All it shows is that you pull straight up on the assembly to get it out. It does warn to watch out for the power cable, but does not reference whether or not there is a plug to the socket....there most likely is one though.
You were probably doing the correct procedure for removal...probably just had to lift it a bit more. I know that US F10's have the manual on the car's hard drive. If you do also, then look look under the section about dis-abling the transmission "park" for towing. This is where the cupholder removal illustration is.
      11-18-2010, 07:56 AM   #5
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Many thanks for such a quick and detailed response; I obviously chickened out too soon.
      11-18-2010, 09:31 AM   #6
rocco90
Drives: Airbus
Here is a link for the owners manual I found with images explaining how to take out the cupholder insert and set aside.
Download the PDF version http://pdfservicemanual.com/automoti...-owners-manual and
Go to page 69
Hopefully it helps.
      11-18-2010, 04:39 PM   #7
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Go to page 69
Hopefully it helps.
Many thanks for the link to the US owner's manual - very interesting.
I have the UK version and it's called a 'handbook' as opposed to 'manual', but it's basically the same, with the notable exception of any information on manually releasing the transmission lock and the release key is not supplied with the car over here. I wonder why - do they not trust us Brits with tools?
Another difference I've noticed is that your manual gives detailed tyre pressure info on pages 224/225 , whereas my handbook just refers you to the door frame sticker - I wonder what else I'll find...
      11-18-2010, 04:49 PM   #8
ghueser
Drives: 2014 M5
Jon D
None of the newer cars (post September I believe) have the Tranmission tool release key any more. BMW evidently put the ability to unlock the transmission into programming and you do it by initiating some pushes on the shifter. Do a search on this....which reminds me that I need to find it as well and make a copy of the instructions in the event I ever need it. Eveyone seems to think the whole tool thing would have been easier to use in the long run and question why the change to doing it "electrnically" was ever done.
Do you at least have the "Warning Triangle" in the trunk? or the First Aid Kit..... We don't get these in the US.
      11-18-2010, 05:06 PM   #9
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Jon D
Thanks 'ghuser', do you know where I can find the instructions - are they in iDrive?
It would good to have the procedure committed to memory in the event of having to push the car out of harm's way following a breakdown.
We do get the first aid kit and warning triangle in the UK, but that's only because it's predicated by EU legislation - not out of the goodness of BMW's heart!
      11-19-2010, 11:33 AM   #10
egokbulut
Drives: F10 520d
Jon D
) So funny, I complained to my dealer that my car lacks the tool, and he took one from from a 523i (pre sep 2010) at the show-room and gave it to me)) Should i return it?
History: '96 Alfa Romeo 146; '97 Passat 1.8T HighlineII; '99 Laguna RXT; '00 9-3 Aero; '04 A4 1.8t; '06 Grand Cherokee 3.0 CRD; '09 E60 520dA; '11 F10 520dA
      11-19-2010, 03:24 PM   #11
DNA_42
Drives: F10 520d
Couldn't find page 69.............
      06-09-2014, 01:17 PM   #12
serafim
Portugal
Drives: Station 520D
the link for download don t work anymore
Can Anybody take a Photo with removal instrution ?
thanks
      06-09-2014, 03:29 PM   #13
rocco90
Drives: Airbus
thanks
Here is a working manual I found: http://auto.needmanual.com/2011-bmw-...rs-manual.html
      06-10-2014, 02:05 AM   #14
serafim
Portugal
Thanks , but is very hard to remove !
i try with instrucions pag 69 , but is very hard to remove .....
i can t do it..
Anybody have luck with this ???
      06-10-2014, 02:25 PM   #15
Stormbitch
Drives: G11
Mazing I was going to post this!!!! I want to clean mine
