2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum 2012 BMW 528i Receives N20 Turbo 4-cyl Engine, Auto Stop/Start and xDrive AWD
      07-01-2011, 11:11 AM   #1
Jason
Jason's Avatar
Drives: F80 M3
Arrow 2012 BMW 528i Receives N20 Turbo 4-cyl Engine, Auto Stop/Start and xDrive AWD
BIMMERPOST NEWS
68
COMMENTS
2012 BMW 528i Receives Latest in EfficientDynamics Technologies New TwinPower Turbo four-cylinder, Auto Stop/start and xDrive AWD ensure that most popular 5 Series model set to become even more popular
Woodcliff Lake, NJ – July 1, 2011… BMW today announced significant enhancements for the 2012 BMW 528i Sedan, most significantly BMW’s new TwinPower Turbo 2.0-liter four-cylinder engine. To further enhance its efficiency in everyday driving, the 2012 BMW 528i also receives auto start/stop technology. For those who face the realities of four-season driving, the 2012 528i becomes the newest member of the 5 Series family in the US to offer BMW xDrive all-wheel drive as an option. When the 2012 model arrives in BMW showrooms this fall the most popular model in the 5 Series line-up is destined to become even more so.
BMW TwinPower 2.0-liter Four-Cylinder
Like the company’s latest TwinPower Turbo 3.0-liter turbo inline-6, the new 2.0-liter engine will combine high-pressure direct-injection and BMW’s VALVETRONIC intake control (hence the name: TwinPower) with a forced induction system consisting of a single twin-scroll turbocharger. With 240 horsepower and 260 lb-ft of torque, it offers more power and torque than the normally aspirated 3.0-liter inline-6 featured in the 2011 BMW 528i.
The maximum output of 240 horsepower is achieved at 5,000 rpm, 1,500 rpm lower than in the normally-aspirated 3.0-liter inline six. The peak torque of 260 lb-ft, comes on stream at just 1,250 rpm. Not only is that 30% more torque than the aforementioned inline-6, it also peaks 1,500 rpm earlier. The vigorous power comes on early and climbs steadily all the way to redline.
The 4-cylinder engine with its all-aluminum crankcase is lighter and more compact than a 6-cylinder engine of equivalent power. The turbocharger is a twin-scroll system. The exhaust streams leaving the two pairs of cylinders are kept completely separate as they flow through the exhaust manifold and the turbocharger, taking a spiral path to the turbine wheel. This configuration results in very low exhaust back pressure at low engine rpm, and allows the energy of the exhaust gas pulses to be optimally managed and translated into powerful rotation of the turbine blades, without a delay in throttle response.
The patented BMW VALVETRONIC system with seamlessly variable intake valve lift control dispenses with the throttle valve system typical of conventional engines. Instead, combustion air mass is controlled inside the engine, resulting in much faster response. Pumping losses are kept to a minimum, making the engine more efficient.
The High Precision Injection direct-injection system also helps to improve efficiency. Centrally positioned between the valves, solenoid injectors with a maximum injection pressure of 200 bar (2,900 psi) precisely control the supply of fuel. The fuel is injected very close to the spark plug, resulting in clean and homogeneous combustion.
The cooling effect of the injected fuel also allows for a higher compression ratio than might otherwise be possible. This results in further efficiency improvements. In the 2012 528i this innovative new engine will again be mated to BMW’s newest 8-speed automatic transmission. The 2012 528i accelerates from 0 – 60 mph in 6.2 seconds, 0.4 seconds quicker than the 2011 model and will deliver up 15 percent better fuel efficiency (final EPA results are pending).
xDrive All-Wheel Available for the 2012 528i
Like other 5 Series models, xDrive intelligent all-wheel drive has been updated to match the performance and character of the 528i. BMW xDrive provides the reassurance of sure-footed traction in all weather and road conditions, but it also goes far beyond that to provide an added measure of active safety. BMW’s Integrated Chassis Management (ICM) is able to identify and limit understeer by shifting torque rearward (initially 80% to the rear axle) while preserving the stability for which xDrive has been so widely recognized. As a second step, ICM can then apply a precise combination of throttle and individual rear-corner braking in order to maintain neutral handling in a corner - regardless of road surface conditions.
Every BMW xDrive model receives standard Hill Descent Control. This selectable function allows the driver to descend slopes in extremely slippery conditions while maintaining control at a pre-set speed.
Extra Measure of Efficiency with Engine Auto Start/Stop
In addition to BMW EfficientDynamics technologies like Brake Energy Regeneration, the 2012 BMW 528i will feature Engine Auto Start/Stop. This feature switches off the engine when the car is stationary at traffic lights or in slow-moving traffic in order to minimize idling. An ECO PRO mode, which is activated by the driving experience switch, adjusts the engine map, heating, air conditioning, and mirror/seat heating to minimize fuel consumption. The resulting increase in range is shown on a display.
The 2012 528i is the very embodiment of BMW EfficientDynamics – more powerful, more efficient and more sure-footed. The 2012 BMW 528i arrives at US BMW centers beginning this fall.
      07-01-2011, 11:19 AM   #2
Needsdecaf
Needsdecaf's Avatar
6599
Drives: 2024 G80 Comp xDrive
Bring. A. Diesel. Here
Prediction ---> not gonna happen.
With the 528 getting the n20, economy in that car is going to be so good there won't be a need for a diesel 5 series in the US, except for those who simply want diesel. And there just aren't enough of those.
      07-01-2011, 11:38 AM   #3
eisenb11
Drives: 2012 E92 M3 SSII
Will auto start stop be enabled or disabled (like the current m3) by default in the us market?
      07-01-2011, 11:39 AM   #4
hmmcolor
hmmcolor's Avatar
Drives: E90 335i 6MT
That's going to make for a very quick 328i.
2000 Dodge Dakota 4.7
2007 335i 6MT
      07-01-2011, 11:40 AM   #5
red.66mustang
Black.e90
red.66mustang's Avatar
Drives: 03 M3, 6MT, Carbon Blk/Cinnamn
It would be nice if BMW would offer the 528 with a manuel here in America! Its stupid that I have to go all the way up to a 535 to get that option. I would love this turbo four with 6 do it your self gears!
Current: 03 M3 6MT Carbon Black/Cinnamon; 1963 Volkswagen Beetle Ragtop; 1965 Ford Mustang Conv. 289/4spd
Retired: 2006 325i 6MT, 1966 Ford Mustang; 2006 VW Jetta 2.5L, 5MT
      07-01-2011, 11:50 AM   #6
M5007
M5007's Avatar
Drives: 2014 M5 Competition Package
Demand for both manual and diesel is just not there. But I think we should have the option to order it.
      07-01-2011, 11:51 AM   #7
gunship guy
Drives: A Manual!
[QUOTE=Needsdecaf;9935986]Bring. A. Diesel. Here
+1
If the 535d was offered here that is what I would have bought instead of a 550.
      07-01-2011, 11:57 AM   #8
BimmerGuyFL
Drives: 2013 F10 BMW 535i M-sport
15% fuel economy improvement over the 3.0 Liter NA engine in the 2011 528i means that MPGs go from 22/32 to 25/36. NICE!!!
2013 F10 BMW 535i Alpine White / Oyster Dakota Leather / Anthracite Wood Trim / Steptronic transmission / M Sport Package / Premium Package / Technology Package / Rear-view camera / Park Distance Control
      07-01-2011, 12:06 PM   #9
sparkyg
sparkyg's Avatar
142
Drives: A6 Allroad
Gas in the US is still cheap compared to Europe or the UK.
Diesel not gonna happen for years yet.
      07-01-2011, 12:36 PM   #10
M3_WC
Drives: M3
The problem is that US diesel prices are more than petrol. Which is complete BS, diesel is cheaper to refine. The federal excise tax is more on diesel, for what reason I do not know.
      07-01-2011, 12:54 PM   #11
grimlock
Drives: F10 N52B30@255PS
For U.S. buyers the new N20 is probably less bad, due to the neutered 230hp N52, but elsewhere the N52 is unleashed to 255hp.
Whereas in the U.S. it is an increase in HP from 230 to 240, elsewhere its actually reduced, although torque is higher and at lower revs.
Performance increases by 0.4s in 0-100km, but for the 255hp spec it is only 0.2s.
And this is before the consideration of driving dynamics/ characterics of a 3.0NA vs. 2.0T.
Start stop is annoying and i cannot think of any situation in which it would actually be useful and not a torture to have on, perhaps in a rigid test environment with 30s+stops and no true stop-go traffic as is often in reality.
Thats one less button I have to remember to push everytime i start the car, although i can't imagine it being forcibly implemented in such a way, this exceeds the annoyance of the normal/sport/sport+ mode reset.
I'm glad I got my N52 w/o startstop.
      07-01-2011, 01:09 PM   #12
rocco90
Drives: Airbus
Curios what kind of Power Steering System will use the 528xi....
      07-01-2011, 01:17 PM   #13
blackberrycubed
Drives: 535i Xdrive
The engine is not here yet and I am in love with it already!!!!!
      07-01-2011, 01:32 PM   #14
bavarian19
bavarian19's Avatar
Drives: Car
But I also agree. 535d!
      07-01-2011, 01:43 PM   #15
BimmerGuyFL
xDrive Models use Hydrualic Power steering, NOT Electric Power Steering.
      07-01-2011, 02:03 PM   #16
mkoesel
Drives: No BMW for now
True, but did you see the other thread with the global 5 series information?
There is still a 530i in the lineup with a naturally aspirated 6 cylinder, now making 272hp. It might not come to your region, but presumably it will be available in much of the world (not US though).
      07-01-2011, 02:34 PM   #17
positiveions
positiveions's Avatar
Lebanon
961
Drives: 19 Tacoma, 16 Golf wagon
530d is coming next year
      07-01-2011, 02:38 PM   #18
mkoesel
Pity they won't bring the 535d though (and 740d, 640d, 335d, X5 40d, etc.).
      07-01-2011, 06:24 PM   #19
Rallo
Sho'nuff!!!
Rallo's Avatar
Drives: 2011 528i
2007 GSXR 1000  [0.00]
2011 BMW 528i  [0.00]
Already ordered my 2011 528i but I'm happy to stick with the I6 NA.
      07-01-2011, 10:10 PM   #20
amdmaxx
My gift Registry: M2
amdmaxx's Avatar
Drives: Future Mowner of Monster
520 & 540 please.. That 313hp/485 torque and 35+mpg would be just amazing.
same for 3 series..
      07-01-2011, 11:20 PM   #21
ex-poster
Drives: 2000 328, 2006 330
Auto Start/Stop: NFW.
      07-01-2011, 11:44 PM   #22
cmk227
cmk227's Avatar
Drives: Goal: Another ///M
I be ordering the 528i, 4 cylinder next year and will do ED.
14 Lexus GX460 & 14 Lexus ES300H
14 BMW 528d Touring Estate - UK
Previous M's: 11 BMW M3 JZB ZCP 6MT, 02 BMW M3 Conv 6MT & 02 BMW M3 Coupe 6MT
