2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding AMBIENT/interior LIGHT HELP
      11-25-2018, 02:48 PM   #1
335socal
Drives: Alpine white 335 coupe
I need help trying to figure out what is the issue with my light. It seems that when I turn the light up to max setting my ambient and the other accessory lights seems to flash and if I don't turn it down the light will turn off and I must switch the light off and turn it back on to make it work again. I checked all the fuse and all of them are good. Thanks in advance for the help!
      11-25-2018, 09:59 PM   #2
Looks to me like a problem with the switch.
      11-26-2018, 02:13 AM   #3
335socal
Thats what i was thinking as well but then i took out the switch by removing the whole unit, did the same thing.
      11-27-2018, 10:52 AM   #4
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
interesting with the flickers. like ezaircon4jc said could be the switch or an electrical related issue. maybe a grounding issue? I would try swapping out the fuse to see if the fuse is ready to go?
      11-27-2018, 01:15 PM   #5
335socal
flickers is with the camera being 4k quality. The strobe effect is the issue. Iv checked all the fuse and they all pass for continuity check.
      11-28-2018, 07:32 PM   #6
335socal
CANT FIGURE IT OUT AND JUST TOOK THE CAR TO THE DEALERSHIP. Just so happen that my IDRIVE screen all of a sudden got some dead pixels. All should be covered by my exclusionary extended warranty. PHEW!
      11-30-2018, 10:46 AM   #7
335socal
update! Dealership says its the footwell module.
Kyngofpop676.00
      12-09-2018, 05:27 PM   #8
335socal
UPDATE! Purchased FOXWELL NT 510. I will check if it can reset my FRM (footwell module).
      12-10-2018, 05:26 PM   #9
335socal
UPDATE! FOXWELL NT510 cant read most of my modules. Very limited to what it can do. It is pretty much just a regular ODB2 scanner with little extras. Its more suitable for E series cars that claims to be able to code injectors and more.
      12-12-2018, 07:26 AM   #10
SWFLf10
SWFLf10's Avatar
I don’t know about an actual reset, but with Esys you can re-code modules to their original setting be right clicking the module in question, then hitting “code”. My thought would be to try the obvious first, disconnect battery and let sit for 30 minutes, then try to set the module to stock with Esys.
      12-12-2018, 11:29 AM   #11
335socal
Yep, That is my next step. I just ordered some ENET cable and take it from there. I tried disconnecting the battery for at least 30mins and still the same. If not I will just bring the car to one of the BMW shops @ my area that doesn't charge $170 for labor like BMW dealership and have them replace the FRM module and both of my turbo covered under my extended warranty
      01-08-2019, 11:03 PM   #12
335socal
UPDATE! UPDATE! UPDATE!
So, I knew that FRM is not fried due to me testing it with ISTA+. ISTA+ can read the module but just giving error 58g fault. I added some volt step down (12v input/9v output) to each led strip that I replaced and it worked! No more error, light doesn't blink anymore!
