2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum P3Cars Vent Gauges
      09-22-2013, 01:55 PM   #23
BMWrules7
Drives: 2015, 740 LdX, Alpine White
Originally Posted by tp550i
Installed my P3 Vent gauge this weekend. These were released late last month. Install took about 30 minutes and its as easy as the install video. I purchased the gauge already installed into the vent, that way I can swap back to stock vent if and when I need to.
You'll need a T20 torx bit to remove the vent from the dash. Removing the vent out of the dash is the trickest part, but not difficult. Its plug and play into the OBD port with digital Boost, Vacuum, RPM, Speed, Coolant Temp, Throttle Position, Battery, Air inlet temp and EGT. Also has a 0-60 timer and other features.
I was looking for boost and like having a coolant temp guage. Affordable and works as advertised
I'm anxious to see exactly what kind of boost its now pushing with Dinan S3.
more information here http://www.p3cars.com/catalog/f10/
Awesome! Can you confirm that dumping the control box back into the side panel the way they do in the video is does not result in rattles?
      09-22-2013, 07:25 PM   #24
tp550i
tp550i's Avatar
Drives: 2011 550i Sport
no rattles, the control box is plastic that only weighs about 1-2 oz. If rattles are a concern you could wrap it in bubble wrap.
F10 550i Space Gray | Dinan Stage 5 | Eisenmann Race | ACS springs | 20" Ferric Grey 312 - Michelin PSS
      10-30-2013, 10:04 AM   #25
Dhu
Drives: 2011 550
Any updates on analog vs P3 readings?
_______________________________________________
Dinan Stage 5 550i, Dinan springs, Dinan Exhaust, Shockware
      11-09-2013, 03:06 PM   #26
spadae22
Drives: 2013 BWM 550XI Sport
My 2013 DINAN Stage 2 only shows 10.9 WOT in third gear using the P3 vent gauge. I am installing the boost tap with analog gauge to see what is really going on. Anyone else have issues like this?
      07-01-2015, 02:46 PM   #27
DinoNac
Drives: 535 xDrive N55
Originally Posted by ClassM View Post
That's pretty sick bro, how much is it? I need one now!
I just posted mine for sale, it is for the F10 N55 535.
