2010 2011 BMW 5 Series Forum F10 BMW Transmission Fluid & Differential Fluid Change question. 2011 BMW 535i xdrive |
03-05-2019, 09:51 AM | #1 |
Rep 58
Hey guys,
My 2011 BMW 535i xdrive with 77,200 miles, seems to be slipping gears from the first gear to second, would you guys recommend changing my transmission fluid and differential fluid? Or what do you think might be the problem and also how much does it cost for both fluid changes? I know BMW claims that BMW transmission fluid is "lifetime" but we all know it isnt lol i just don't want to do more harm than good by changing. What are you thoughts on this? |
03-05-2019, 05:46 PM | #2 |
Rep 1,299
You can try drain and refill on the trans: https://www.fcpeuro.com/products/bmw...-24118612901kt
252 for the kit. You can get this kit, it will be cheaper than going to stealership. I think bmw trans oil from stealership is around 150 or so bucks per bottle. |
03-05-2019, 06:29 PM | #3 |
Rep 1,873
I have one of these same kits on the shelf waiting to go. I'm excited to get it changed. Not so excited to perform the procedure itself but hopefully I'll love the results.
03-05-2019, 06:33 PM | #4 |
Rep 1,299
03-06-2019, 07:15 AM | #5 |
Rep 598
Wife's car hit 80K and I brought the FCP Euro kit to my independent BMW shop for them to properly refill and reset adaptations.
While in there also changed front, rear diff, and transfer case fluid. Car drives smoother especially morning cold start 1-2 shift. |
03-06-2019, 01:43 PM | #6 |
Rep 965
How much did that labor cost?
07-23-2019, 08:27 PM | #8 |
Rep 2
Thought I'd chime in since I had my tranny fluid/filter changed today. Car had 70k miles on it with no shift issues. After reading countless posts on the topic, I just wanted to change the fluid for peace of mind.
My local indy ordered the ZF pan and 7 quarts of lifeguard 8. Price came out a little lower than the kit found on fcpeuro. After $180 labor, the total service cost $445. Fluid came out pretty dark and there was quite a bit of metal shavings in the pan. He reset the adaptations, so it was shifting kinda funky otw home. It was smooth to begin with, so I can't say that it got any smoother. |
07-23-2019, 08:58 PM | #9 | |
Rep 916
Instgram @burninja
07-23-2019, 10:04 PM | #10 |
Rep 1,873
For what it's worth, I've seen it stated in various places that transmission adaptations are NOT to be reset. Unlike with most systems in the car, the transmission adaptations which are reset by that procedure are WEAR adaptations, not driver/fluid/weather/whatever adaptations. They are there to account for clutch and brake wear. I believe the documentation for xHP mentions this. With various software you can read out the current adaptation values to determine wear in different areas of your transmission.
xHP says that in an extreme case, if you reset adaptations some cars will no longer be able to move until some adaptations are manually programmed back in to get close the values needed for that particular transmission. (Note, I said EXTREME cases). I left it alone and after my DIY pan/fluid replacement shifts were instantly smoother the next time I drove. YMMV, of course. |
BurrNinja431.50 |
07-23-2019, 10:20 PM | #11 | |
Rep 590
07-24-2019, 07:08 AM | #12 | |
Rep 1,873
From memory, steps and stuff needed:
The only thing I had to buy was the 1/4" click torque wrench. Procedures are found in ISTA+ and online from ZF. Videos are on Youtube and FCPEuro showing other people (with hoists) doing the change. Here's a page from ZF themselves all about it: https://www.zf.com/unitedkingdom/en_...hange_oil.html YMMV. I'm not responsible for any problems or injuries. Be smart and work within your capabilities. Don't take any chances when working under your car. Etc...etc... disclaimers. Do lots of reading and research before attempting. |
07-24-2019, 05:43 PM | #13 | |
Rep 2
I'm no tech, but it seems like the internet recommends a change between 60k and 80k, based on ZFs intervals. Some say anything above is risky, but at the same time, I heard from a few shops that they recommend changing fluid at 100k. My guy told me to come back at 100k to change ONLY the fluid then fluid+filter at 130k. Who knows when I'll retire the car. |
BurrNinja431.50 |
07-25-2019, 05:59 AM | #14 |
Rep 1,146
Drives: F10 550i
Garage List 2020 BMW M340i [0.00]
2019 RAM 3500 [0.00] 2020 BMW X3 [0.00] 2016 BMW 550i [0.00] 2000 Ford F450 7.3l ... [0.00] |
There seems to be a lot of old mechanics tales when it comes to transmission fluid changes. Basically transmission fluid is a petrochemical oil. Like all oils overtime it breaks down and the additives are used up. For maximum life of the part you should change the fluid for. This same transmission is used in a lot of vehicles including trucks which do recommend changing the oil
The issue that some folks run into... is automatics have clutches that wear and create particles that sometimes come out of suspension in the oil and arenÂ’t caught by the filter. Especially if the filter is full and operating in bypass. When you change the oil on this transmission there is some risk in dislodging the sediment and causing it to get stuck in tiny passages or reduce the flow of oil in places causing bad shifting. But if you in this position you were on borrowed time anyway on the transmission. All I can say is in my work truck fleet. On transmissions (different trans) in ford f450s diesels, ones that aren’t serviced die at around 170k miles. Ones that are serviced routinely last 250k+. So spending 400 in transmission fluid to gain another 70k miles, is a cheap investment, considering the cost of a transmission, loss of service and labor involved in a swap. Most people don’t keep their cars for more than 3-5 years and 36-60k miles. So for you passing the car on to the next person... transmission oil changes are a waste of money. Last edited by Thecastle; 07-25-2019 at 06:07 AM.. |
tet0010.00 |
07-28-2019, 04:19 PM | #15 |
Rep 36
Drives: 2014 F10 LCI 550i Luxury Line
Any OBD2 readers that display live transmission fluid temperature?
I have given up trying to use the bootleg ISTA software, and I have no idea how to purchase this software from BMW directly. The bootleg stuff errors out, and I've tried downloading it from multiple sites and installing it on two different WIN 10 Pro Core i5 laptops with no success. I'm old, I don't do programming, and I need something turn-key that will display the tranny fluid temp in real time.
Does anyone know of any reasonably priced OBD2 scanners that will display live readings of the transmission fluid temperature for F and G model BMWs? Presently, I need to change the fluid on my 2014 F10 550i with the ZF 8HP 8-speed, and in a year or so, I'll be needing to do the same thing on my 2018 G30 540iX. Thanks to anyone who knows of any readers/scanners that will display live trans fluid temps on 2011 and later F and G series Bimmers.
Current stable:
2002 Nissan Pathfinder SE 4WD 5MT 2004 Mazda 6S Wagon 5MT 2014 BMW 550i Luxury Line Former: 2011 BMW 535i 6MT / 2012 BMW 550i Sport 6MT / 2014 BMW 535i M-sport 6MT |
07-28-2019, 04:35 PM | #16 | |
Rep 590
07-28-2019, 05:53 PM | #17 | |
Rep 38
For a novice like me, bimmercode and bimmerlink along with an OBD adapter does the simple jobs for me. ISTA is a different level for me. |
ezaircon4jc4540.00 Skibum7.50 |
07-29-2019, 10:10 AM | #18 | |
Rep 36
Thanks for this idea rahdigga. Yes, since all I'm wanting at the moment is the ability to see live tranny fluid temps - I will give this a try!
Current stable:
07-29-2019, 11:18 AM | #19 | ||
Rep 590
07-29-2019, 07:08 PM | #20 |
Rep 14,521
So know DIY's with photos or YouTube video on this? Mines due
07-30-2019, 07:15 AM | #21 | |
Rep 1,873
FCPEuro has a page too https://blog.fcpeuro.com/how-to-serv...p-transmission |
lsturbointeg9165.00 |
08-25-2020, 04:07 PM | #22 | |
Rep 659
Tags |
2011, bmw 535i xdrive, f10, transmission fluid |
