2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes F10 M5 Brakes on 528/535/550 ???
      11-16-2023, 10:17 AM   #155
SocomCA
Drives: BMW M6
Originally Posted by mikekilpatrick View Post
Also an interesting -point when I did the M5 retrofit too my 2013 550. The caliper HOUSING is IDENTICAL between an M5 and a 550. The only difference is the brake pad holder. SO you can leave your calipers on your car and just swap them out with a different pad housing. Or, you can go with this setup from Tronic who can approach both ways. Replacing Caliper or using the original caliper with different adapter.
NOW, what I DID run into is when I install M5 calipers on the rear of the car, I found the adapter BOLTS did not clear the lower suspension arm by about 3-5 mm. SO I had to grind away about 4mm x 20mm of material from the lower suspension arm where the caliper mounts. There is plenty of meat there and i did not go so deep that I was under the bolt flange head, so no structural risk, just an observation that some of us need some additional modification.
I have a write up under mikekilpatrick that discuss this issue during install
But, in summary, THIS ADAPTER KITS ROCKS! BEST QUALITY of engineering and Tronic KNOWS HIS STUFF! VERY smart guy and I would go to him for ANY kind of metal adapter needs!
Mike
Hey Mike, do you know if the 20inch m343 m5 rims will clear the m5 caliper on a 550? Seems like a straight forward answer but i want to make sure because the lci 550 doesnt allow the m343 wheel to mount without a spacer due to the differences in a lci caliper
      11-16-2023, 10:42 AM   #156
SocomCA
Drives: BMW M6
My research has shown:
All parts available from www.getbmwparts.com Ask for Jason
Front Brakes:
Left Caliper 34117845747
Right Caliper 34117845748
Left Rotor 34112284101
Right Rotor 34112284102 Pads set 34112284869
Brake hoses 34322284318 each (2 needed, one per side)
Custom Caliper Bracket
Rear:
Rear caliper left 34217845815
Rear caliper right 34217845816
Rear pads set 34212284389
Rear brake lines 34322284319 each x 2
Left Rotor 34212284103
Right Rotor 34212284104 Rear Custom Caliper Mount
MUST have at least 20 inch rims for Rotor clearance...
Install, bleed and drive. HIGHLY suggested you do front and back at same time to eliminate issues with ABS.
Now, the only thing to consider is the Electronic Parking brake on the rear, which I need to find out is adaptable to new M5 Rotors and Calipers.
https://www.drive2.ru/l/5698330/
https://www.drive2.ru/o/b/2498650/
Will post pics of adapters once they arrive and will build a DIY document on the install.
Did you ever make that document for installing the m5 brake calipers and rotors system? If so, can you please share it
      11-16-2023, 12:28 PM   #157
mikekilpatrick
mikekilpatrick's Avatar
Drives: 2013 BMW F10 550 Xdrive Msport
Well i have 20 x 9 Dinan (BBS) rims on the car with no issues. Mine is an XI so i have to have all 4 rims running the same size for AWD. If you can compare the 343 rim size to a bbs 20 x9 you should see if it will fit.
      11-16-2023, 12:33 PM   #158
mikekilpatrick
yes i posted it here: https://f10.5post.com/forums/showthread.php?t=1220017
      11-16-2023, 10:49 PM   #159
HI_F10
Drives: 2011 535i
I have done the conversion. installation was pretty stright forward. No fitment issues.
ordered rotors, pads and sensors from FCP
Tronik adapters
My set up is:
Front 20x9.5 245/35 et 20
Rears 20x10.5 285/30 et 26
      11-20-2023, 04:13 AM   #160
Hornet-01
Hornet-01's Avatar
Russia
122
Drives: BMW 550 xdrive
2011 550ix  [9.50]
wheels
hi, tell me your opinion. I want to put these wheels on my green one, I tried it on the gray one
      11-20-2023, 04:16 AM   #161
mikekilpatrick
Personally, I LOVE THOSE rims! I had a similar rim on my car a while back before I went to the Dinan BBS rims, which I since had painted OEM BMW silver.
I like the way it shows off the Drilled rotors on the car. Nice Choice
      02-27-2024, 12:27 PM   #162
SocomCA
Drives: BMW M6
Hey Mike,
Do you know if the master cyclinder needs to be upgraded post m5 caliper and brake retrofit?
Its part# 34336799903 which isnt interchangeable with the 550 according to realoem. I wonder if its a direct fit
      02-27-2024, 02:06 PM   #163
addy27
Drives: F10 550i
I believe you can also FDL code your DSC/ABS module to know it has the bigger brake kit. My DSC is preLCI so I may not have the most uptodate parameters but you can see the screenshot and select based on your brake size :
      02-27-2024, 05:03 PM   #164
B-Buster
Netherlands
24
Drives: F10 535i, E63 650i
Originally Posted by SocomCA View Post
Hey Mike,
You can if you change one brakeline. Did that myself together with the G11 M Performance brakes.
