2010 2011 BMW 5 Series Forum F10 My new 2012 535i 0-60MPH |
07-20-2012, 12:04 PM | #4 |
Rep 645
07-20-2012, 02:40 PM | #5 |
Rep 11
So by starting in M2 and kicking back to M1, you avoid the M1 wheel-spin, that makes you loose time and then when it changes to M1 from M2, you get all the torque without any wheel spin. There, is the second saved. That's clever.
07-20-2012, 06:18 PM | #7 |
Rep 11
So if this car is stock, with this "trick" a product to re program the computer like juice box is not needed. Juice box only gives you for the N55 about 50 hp. I believe if I am not wrong, you need about an extra 100 hp to come down one second in a 0-60 run.
07-20-2012, 07:25 PM | #8 |
Rep 8,800
doubt this is legit or accurate and no making the car downshift isn't going to make it quicker. Slower in fact.
Alan
07-20-2012, 08:51 PM | #10 |
Rep 11
but you have to depress the pedal all the way until you activate a switch that will make the transmission downshift. if you put it in M2 and dont depress that switch the car will continue in M2.
07-21-2012, 09:34 AM | #12 |
WR-FAM
17
Rep 86
The bimmers from burger motor, some of the fastest tuned bmw's in the world, launch from second gear. I have also tried this on my 135i with jb3 and it works just as well as it avoids the wheelspin that is caused by launching from first gear. Look at my 135i 3.99s 0-60 from the same channel where I posted the 535i 0-60
07-21-2012, 04:31 PM | #13 |
Rep 441
im trying this tonight on a side road that is closed!
Past: 2011 E92 //M3 SSII DCT
Previous: 2012 F10 550i Carbon Black M Sport Present: 2017 430 Gran Coupe |
07-22-2012, 08:59 AM | #15 |
Rep 358
I would also be curious to see how good are the recovery times:
– 40-100 km/h (25-65 mph) – 80-120 km/h (50-75 mph) Any chance of filming that or would you be afraid to be humiliated by the diesels? Is there any website where we can see how all the 5 Series engines stack up, including the diesels? |
07-22-2012, 08:53 PM | #16 |
Rep 11
You can see the information that you want in You Tube. Look up:
Top Gear BMW 5 Series Diesel vs. Petrol (this is the old model before 2011) There are many videos there. I dont know, but is very possible that a diesel has much more torque and with its lower rpm's, has better pick up. I believe that in America we do not have 2012 535D. I know there are 335's and x5"s diesel. |
07-22-2012, 09:26 PM | #17 |
Rep 11
Here is some info from a car magazine about the recovery time 45-65:
2011 BMW 535i 2010 Mercedes-Benz E350 (CGI BlueEfficiency) POWERTRAIN/CHASSIS Drivetrain layout Front-engine, RWD Front-engine, RWD Engine type Turbocharged I-6 alum block/head 90° V-6, alum block/heads Valvetrain DOHC, 4 valves/cyl DOHC, 4 valves/cyl Displacement 181.1 cu in/2979cc 213.5 cu in/3498cc Compression ratio 10.2:1 10.7:1 Power (SAE net) 300 hp @ 5800 rpm 268 hp @ 6000 rpm (288 hp @ 6400 rpm) Torque (SAE net) 300 lb-ft @ 1200 rpm 258 lb-ft @ 2400 rpm (269 hp @ 3000 rpm) Redline 7000 rpm 6300 rpm (6500 rpm) Weight to power 13.7 lb/hp 15.0 lb/hp Transmission 8-speed automatic 7-speed automatic Axle/final-drive ratios 3.08:1/2.05:1 3.07:1/2.24:1 Suspension, front; rear Multilink, coil springs, adj shocks, adj anti-roll bar; multilink, coil springs, adj shocks, adj anti-roll bar Struts, coil springs, anti-roll bar; multi-link, coil springs, anti-roll bar Steering ratio 17.0:1 17.0:1 Turns lock-to-lock 2.0 2.7 Brakes, f;r 14.7-in vented disc; 14.6-in vented disc, ABS 13.5-in vented drilled disc; 11.8-in vented disc, ABS Wheels, f;r 8.0 x 18-in, cast aluminum 8.5 x 18-in; 9.0 x 18-in, cast alum Tires, f;r 245/45R-18 96Y Dunlop SP SportMaxx GT 245/40R18 97V; 265/35R18 97V, Continental ContiProContact DIMENSIONS Wheelbase 116.9 in 113.1 in Track, f/r 63.0/64.1 in 62.2/63.0 in Length x width x height 193.1 x 73.2 x 57.6 in 191.7 x 75.9 x 57.6 in Turning circle 39.2 ft 36.2 ft Curb weight 4100 lb (mfr) 4013 lb (4050 lb, mfr) Weight dist., f/r 50/50% 51/49% Seating capacity 5 5 Headroom, f/r 40.5/38.3 in 37.9/38.2 in Legroom, f/r 41.4/36.1 in 41.3/35.8 in Shoulder room, f/r 58.3/56.2 in 57.8/56.9 in Cargo volume 18.4 cu ft 15.9 cu ft TEST DATA Acceleration to mph 0-30 2.1 sec 2.2 (2.3) sec 0-40 3.1 3.5 (3.4) 0-50 4.2 4.8 (4.7) 0-60 5.6 6.6 (6.3) 0-70 7.2 8.5 (8.3) 0-80 9.0 10.7 (10.3) 0-90 11.2 13.6 (13.0) 0-100 13.8 16.7 (16.3) 0-110 17.6 20.3 (19.7) 0-120 21.6 25.6 (24.3) Passing, 45-65 mph 2.7 3.4 (3.2) Quarter mile 14.1 sec @ 101.0 mph 14.9 sec @ 94.5 mph (14.8 sec @ 95.2 mph) Braking, 60-0 mph 109 ft 123 ft (113 ft) Top-gear revs @ 60 mph 1900 rpm 1850 rpm CONSUMER INFO Base price $50,000 (est) $49,475 Price as tested $64,000 (est) $59,965 ($64,845*) Stability/traction control Yes/yes Yes/yes Airbags Dual front, front side, front knee, f/r curtain Dual front, fr side, fr pelvic, f/r curtain, driver knee Basic warranty 4 yrs/50,000 miles 4 yrs/50,000 miles Powertrain warranty 4 yrs/50,000 miles 4 yrs/50,000 miles Roadside assistance 4 yrs/unlimited mile Unlimited Fuel capacity 18.5 gal 21.1 gal EPA city/hwy econ Not yet rated 18/26 mpg CO2 emissions - 0.93 lb/mile Recommended fuel Unleaded premium Unleaded premium *Priced as if an American E350 Read more: http://www.motortrend.com/roadtests/...#ixzz21PNotUK5 |
07-26-2012, 09:31 AM | #19 | |
Rep 19
07-28-2012, 04:48 AM | #20 |
Rep 358
Tags |
0-60, 535i, bimmer, bmw, fast |
