2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Doing meth on 550xi
      04-16-2014, 01:52 PM   #1
badblack550xi
badblack550xi's Avatar
Doing meth on 550xi
With in next few weeks i will be testing meth injection on my car it is the same set up terry runs on his M5. Meth kit added around 25-30whp over the previous race gas mix!
2011 550i RWD 60-130 7.35
      04-18-2014, 11:48 AM   #2
CloudVIII
CloudVIII's Avatar
Drives: AW LCI F80///M3
I'm in!
      05-13-2014, 07:25 PM   #3
NeoNz
335 Newbie
NeoNz's Avatar
Drives: 2011 335i xDrive
nice i can't wait to see!!
2011 BMW 335i xDrive, 12.2 @ 111 (e90 N55 XDrive Record)- Sold
Stage 2, Map 7/e85 mix, JB Intake, Vishnu Catted DP, ETS FMIC, CPe Chargepipe
1994 Toyota Supra, Baltic Blue, 6-speed, mods... FOR SALE
1200rwhp/875rwtq, 3.4L Stroker
      06-01-2014, 03:47 PM   #4
E92TTKING
E92TTKING's Avatar
Greece
250
Drives: e92
Definitely interested how this goes
      06-01-2014, 09:23 PM   #5
DriveWFO
DriveWFO's Avatar
46
Drives: F10, F15
badblack, have you looked into get some port work done on your heads? I would bet there is a lot more left in those stock heads. I've been trying to find the stock intake and exhaust flow numbers, but haven't come across that data. Heck, I bet some simple bowl work and a good 5-angle valve job would yield noticeable gains.
      06-02-2014, 11:49 AM   #6
badblack550xi
yeah i was thinking to look in to this the 750 Alpina has bigger heads than stock and it's n63.. someone told me it should be a direct fit.
      06-03-2014, 03:32 PM   #7
DriveWFO
DriveWFO's Avatar
46
Drives: F10, F15
That would be interesting to hear about. I've drag raced and built engines for about 10 years, so I've always followed along with any threads pertaining to it.
      06-04-2014, 02:40 PM   #8
badblack550xi
i wonder how much simple bowl work and a good 5-angle valve job would cost me.. then i can compare to price vs the Alpina heads which are $2500 used + installation..
      07-02-2014, 11:16 AM   #9
badblack550xi
meth kit will be here Friday
      07-02-2014, 11:25 AM   #10
gclions
gclions's Avatar
78
Drives: 2011 550i
Can't wait to see how it goes, as a community we gotta break 500 whp soon.
Good luck with the install!
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
      07-02-2014, 11:26 AM   #11
badblack550xi
i could be there already lol
      07-02-2014, 11:34 AM   #12
gclions
gclions's Avatar
78
Drives: 2011 550i
Nice, I wouldn't doubt it on race gas and aggressive settings.
You ditched your downpipes right? Or were going to catless?
I wonder if the AR downpipes choke down too much, they go from at least three inches through a reducer to the stock 550 exhaust. Any idea if the M5 downpipes will bolt up? From the looks of things they are a full 3 inch downpipe, though O2 sensor placement may not work.
Now we just need these things to breath better, after that we twiddle our thumbs until someone cracks the ECU. I've e-mailed a few companies that claim they have, but no answer back when asking for proof.
I gotta think sometime within the next year someone legitimately cracks these things.
      07-02-2014, 12:05 PM   #13
badblack550xi
still have my downpipes i cut them at theend to keep the 3 inch and then ran it to my 3inch custom piping... they might be restrictive... but i cant go catless because terry no longer produces CAN tool to clear codes.... i make my own high flow K&n filters now to help the car breathe...
      07-02-2014, 12:15 PM   #14
gclions
gclions's Avatar
78
Drives: 2011 550i
Nicely done on cutting the ends off. A full 3 inch exhaust along with your filters should allow that beast to inhale and exhale a little better.
Is anyone helping you with the install of the meth kit? Or are you going to follow the M5 instructions and tackle it by yourself?
My only request, take LOTS of pictures!
      07-02-2014, 01:22 PM   #15
naamanf
Drives: '14 550i '10 MDX '79 TA OH-58D
Off topic but will the BMS CAN tool for the 335 work on the F10?
335d M-Sport/Everything + Individual, 550i M-Sport ED APR 2014
      07-02-2014, 02:14 PM   #16
badblack550xi
yes
      07-02-2014, 02:15 PM   #17
badblack550xi
going to follow the M5 guide probbaly have a shop with meth experience do it... i needd it ready by next friday.
      07-03-2014, 10:25 AM   #18
badblack550xi
So i decided to make my meth kit with some other parts besides what terry provides to make it easier on me. I will post my progress here for others that want to do it.
Big thanks to Alex from TnT racewerks for guiding me in the right direction with this.
Here is the 1st problem.. the piping going in to turbos after intercoolers is rubber on 550 while its hard plastic on M5 means i have to fabricate custom pipes with meth bungs.
      07-03-2014, 01:03 PM   #19
gclions
gclions's Avatar
78
Drives: 2011 550i
Easy day dude, I don't even think they need to be that fancy.
The stainless steel v-band piece inside the rubber hose closest to the turbo flange is at least 1 inch long.
I would start by measuring the inside diameter of the v-band flange. Take that measurement to a reputable shop and have them make a 2 inch long section of stainless tubing of the same diameter, and weld a bung towards one end of that piece, have them make two of them.
So now you should have two pieces 2 inch long with bungs welded in each.
Unscrew the v-band flange clamp, remove the band.
Cut off the hose clamp holding the flange to the hose end.
Remove the v-band flange from the hose end.
Weld the fabricated pieces to the v-band flanges with the bung closest to the v-band end.
Cut the hoses to a shorter length to allow the assembly to line up.
Hose clamp the new pieces into each hose.
Name:  flange adapter.jpg
Good thing about something simple like this is the piece can be loosened and rotated to the position you need. Something like this would work, just a thought.
      07-03-2014, 02:02 PM   #20
badblack550xi
Attachment 1053009
Attachment 1053023
good idea gonna pass up by my fabrication guy.
      07-04-2014, 11:46 AM   #21
badblack550xi
It's all going to happen Tuesday!
      07-04-2014, 06:54 PM   #22
dvs0690
Whooo Whooo!!!!
dvs0690's Avatar
Drives: 72' Pinto, 73' Gremlin
hey bad black, any specific reason why you would run meth before the intercooler? Ive always seen them ran after the intercooler.
72' Ford Pinto - Turbocharged, Supercharged, NOS, Headers, Iceman cai, 5" exhaust tips, tornado gas saver, apc trunk wing, Underglow kit, cut stock springs, vtec badges, hid's in halogen housings, unpainted retrofitted civic buddyclub bodykit, vinyl graphics, chrome front fender vents, altezza taillights, autometer tachometer, fire extinguisher on passanger a-pillar, lambo doors, whistle tips
