2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Just installed JB stage 1...questions
      11-20-2012, 10:06 PM   #1
VWtoBMW
VWtoBMW's Avatar
Drives: 2021 X5
I just installed the JB stage 1 tune on my n55.
Does it actually adapt over time? From a rolling stop, I find it slow before I feel any surge of power. I had the same tune on my n55 335 and it just felt very different.
I and waiting for the stage 2 upgrade to arrive but was just curious.
2018 540d xDrive Carbon Black Metallic on Cognac leather. Spec'd out to the max
2017 Mercedes C43 AMG Coupe. Black on black
      11-20-2012, 10:22 PM   #2
Alan l.
Alan l.'s Avatar
5427
Drives: 2020 F95 X5M Competition
It does need time to adapt but you should of felt some increase right off the bat.
Alan
      11-20-2012, 11:15 PM   #3
iamkit
Drives: 535xi
It actually took like 3 days before I actually noticed the difference.
Kit
      11-21-2012, 12:42 AM   #4
Klecha man
Klecha man's Avatar
Drives: 2012 535
I has stage one installed for a few weeks and was not impressed at all with the gains. I ended up returning it since I thought the risk of potentially voiding the warrant does not justify the alight gain in power. I've been waiting and hoping for some other company to come up with a flash tune.
      11-21-2012, 03:25 AM   #5
SirNicholas
SirNicholas's Avatar
Drives: f10 535i
Where did you get it from that they took it back?
      11-21-2012, 11:34 AM   #6
bulldog_yyc
bulldog_yyc's Avatar
130
Drives: GT3RS
what boost setting are you running? what fuel?
      11-21-2012, 12:23 PM   #7
VWtoBMW
VWtoBMW's Avatar
Drives: 2021 X5
I am running 91. Not a lot of places have 94 around here though I can get it.
As for boost, no idea. How do I check that? I do have the USB cable... can I go in and increase it? If so, what is the highest level that will not blow up my turbos or slowly kill them?
      11-21-2012, 12:41 PM   #8
Klecha man
Klecha man's Avatar
Drives: 2012 535
I got it from http://www.bavauto.com/
I've been on the fence to try Stage 2 so I'm still waiting to see what the other guys have to say about it. Alan thinks it's about the same performance between Stage 1 & 2.
      11-21-2012, 03:41 PM   #9
SirNicholas
Drives: f10 535i
Some people have said that although the numbers might be similar on a dyno, stage 2 is better at reducing the turbo lag.
      11-21-2012, 03:57 PM   #10
bulldog_yyc
130
Drives: GT3RS
you need to download the interface and hook up the usb cable to your laptop.
best to look at the thread on N55 stage 1 on the BMS website for guidance around boost settings/octane.
      11-21-2012, 06:59 PM   #11
VWtoBMW
VWtoBMW's Avatar
Drives: 2021 X5
I had a chance to give the car a good run today. The turbo lag is horrible. When I press the accelerator, not a lot happens then it surges. Stage one on my N55 335 E92 never did that.
I hope the stage 2 will make a big difference as it really sucks at the moment. Not happy !!!!
      11-23-2012, 08:31 AM   #12
RambleJ
RambleJ's Avatar
Drives: F10 535i M-sport
Are you driving in comfort?? I never have the lag issue and trust me I know the power of the N54's I had 3 cars powered by one and all were tuned.
I for one never drive the car in comfort, the car just doesn't feel like a BMW in that setting. Try it in Sport or sport+ and if you still have lag try resetting your tranny adaptation.
      11-23-2012, 08:33 AM   #13
Alan l.
Alan l.'s Avatar
5427
^^ +100
I never noticed any delay/lag even when my 2013 F10 was stock. Certainly not now tuned.
Alan
      11-23-2012, 09:25 AM   #14
RambleJ
RambleJ's Avatar
Originally Posted by Alan l. View Post
^^ +100
Alan
Now I am just guessing here, but I take it you do not follow the "advisertised" break in advise either?
      11-23-2012, 11:43 AM   #15
bulldog_yyc
130
Drives: GT3RS
how is adaptation reset?
      11-23-2012, 02:07 PM   #16
RambleJ
RambleJ's Avatar
Push the ignition button without your foot on the brake to wake up the car. Then hold down the gas pedal all the way down for 30 seconds. Let go and then start the car like normal. This should reset the transimission adaptation that the car has learned from your previous driving style.
      11-23-2012, 02:14 PM   #17
Alan l.
Alan l.'s Avatar
5427
Half and half. I let it stretch its legs every now and then. Now I give the car atleast one full throttle run once a day when I do drive it.
Alan
      11-23-2012, 02:30 PM   #18
bulldog_yyc
130
Drives: GT3RS
thanks bud
      11-23-2012, 03:45 PM   #19
VWtoBMW
VWtoBMW's Avatar
Drives: 2021 X5
Usually drive in comfort sometimes sport. I'll try the tranny reset and wait patiently until my stage2 upgrade comes in.
      03-26-2015, 05:39 PM   #20
Zer0Cool92
Drives: blue metallic
Any update on tranny reset?
      03-26-2015, 05:55 PM   #21
FenixMike
Drives: 2014 BMW M5 Competition
should be 3-3.5 PSI if you havent touched it. As far as hurting the turbo, its maxed out from the factory at higher RPMs, cranking it up will only make the boost spike at low RPM hit harder, maxing the turbo out wont hurt, but exceeding the amount of boost for a given octane will cause detonation, or the vehicle pulling timing to try and save itself.
      05-15-2018, 10:23 AM   #22
Dzbeslic
Dzbeslic's Avatar
Drives: 2013 BMW F10 535xi
Hey, i have a question. Where did you put a box?
If under covel, how did you run wires through to it?
I couldn't find an opening at all!!!
Help
