04-19-2021, 05:41 PM | #1 |
Rep 21
RWD springs on xdrive
Hello,
I had a broken rear spring on my xdrive 550, and decided to replace with RWD springs to get a bit of a drop. Rear is perfect, but the font is about 3/4" too low. I thought they would all drop the same amount. Any ideas on how the front could be raised to match the rear? Spacers of some kind? |
04-19-2021, 05:51 PM | #2 |
Rep 2,591
Get xDrive springs for the front, or just some lowering springs. There's no way to raise it with the current springs.
2015 BMW 535xi
kevinb51112.00 |
04-19-2021, 06:02 PM | #3 |
Rep 21
Thanks for the reply. I was afraid of that. The rear sat great, but the front was too high with the xdrive springs still in, so I swapped them out and now they are too low. Was such a big job, the thought of putting the xdrive springs back in again, kills me
04-19-2021, 07:08 PM | #4 |
Rep 2,591
IMO proper lowering springs are better than using RWD springs on a xDrive. Can lead to some wonky handling as they weren't designed for the xDrive's weight.
2015 BMW 535xi
04-22-2021, 09:10 PM | #5 | |
Rep 76
04-25-2021, 06:27 AM | #6 |
Rep 21
I'll add some pics this morning. It rides better than it did with the xdrive springs. It's basically just a cosmetic thing for me. I don't like the front and back not matching and I feel the front looks just a bit too low. Front also hits the wheel well on larger bumps. Back is perfect
04-25-2021, 06:34 AM | #7 |
Rep 21
Here is how it's looking
WinstonE92xi64.50 |
04-26-2021, 01:37 AM | #8 | |
Rep 2,591
2015 BMW 535xi
04-26-2021, 07:50 AM | #9 |
Rep 21
Agreed. I'm going to put the stock xdrive springs back in the front. The rear didn't have much of a drop when I installed the RWD ones, so will probably leave those. Interestingly enough, when I was looking up front xdrive springs with EDC, it's the same part number for both the 550i and 550ix. By that theory, the ones I just installed should be the same, but they clearly are not. The ones I installed came off a 550i with EDC.
moks_garage0.00 |
10-15-2021, 02:33 PM | #10 | |
Rep 7
