2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications JB4 Stage 2 installed! A Must have for all F10 535i!
      05-19-2020, 09:08 PM   #89
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
Originally Posted by David_Vasha View Post
Would you say it's safe to go with a tune such as mhd stage 2+? I essentially want to get the most power without having to upgrade major things such as fuel pump, turbos, etc.
Well if you want to run MHD Stage 2+ you need exhaust, dp, CP, intake, new colder plugs and IC. If you have FBO than you're good to go without having to upgrade fuel pump and bigger turbos. I would highly suggest browsing the MHD threads here for more info from the guys who have already done this
      05-19-2020, 09:12 PM   #90
David_Vasha
David_Vasha's Avatar
Drives: 2011 535i XDrive
Thanks, I was planning on going FBO but was wondering if there was any recurring reliability issues when doing so.
      05-20-2020, 11:17 PM   #91
dzz
Drives: 2015 BMW 535xi, MHD Stage 2+
2015 BMW  [0.00]
MHD Stage 2+ needs upgraded charge pipe (stage 1 requirement), IC upgrade and higher throughput downpipe (stage 2+ requirement). If you get quality parts there will be no issues. Charge pipe and IC are usually not cause of any problems, some downpipes may throw an error code or check engine light. I have AR hi-flow downpipe and there are no error codes and no issues. I should be able to pass emissions.
I thought that MHD alone is great, but my car was really transformed after I've installed XHP trans tune.
Turbo and fuel pump upgrades will get you to about 550hp on N55, maybe even more, I've seen people getting over 600hp with turbo, fuel pump upgrade and custom tune. At that point, the question is, should you save the money and invest in used M3/M4/M5 and get much more power from the get go?
      05-21-2020, 02:12 AM   #92
MOBF10
MOBF10's Avatar
171
Drives: 2018 M3 Comp
Did you have any issues running MHD with the xph tune together?
      05-21-2020, 11:34 AM   #93
dzz
2015 BMW  [0.00]
No issues, just goodness. They are made to work together, MHD has an option to select XHP as a trans tune and so far both work great together.
MOBF10171.00
      05-21-2020, 01:28 PM   #94
MOBF10
MOBF10's Avatar
171
Gonna get it then. Thanks.
      05-21-2020, 09:37 PM   #95
dzz
2015 BMW  [0.00]
When you flash you trans with XHP, flash it with stage 3 at least. Here are supported stages for my car:
535i xDrive Sedan Stage 1
- Added Gear-Display in D-Mode
- Removed Torque Limiters in 3rd and 6th Gear
- Raised Line Pressure in high torque situations (> 442 ftlb)
535i xDrive Sedan Stage 2
- Added Gear Display in D-Mode
- Removed 3rd and 6th Gear Torque Limit
- Raised Line-Pressure mapping for high-input torque
- Reconfigured DEC Logic, with similar logic as in M-Cars (access to more shifting-modes)
- Even faster shifting in M/Sport+, absolutely instant paddle response
- Recalibrated Shift-Points in D & S Mode to improve throttle response
- No automatic upshifting in M/Sport+ setting
- Transmission keeps the current set mode when DSC is turned off
- Launch Control enabled (update of DSC, DME eventually necessary as well on 2012 cars)
- Retains full ECO - Mode functionality including Coasting
535i xDrive Sedan Stage 3
- Very strong blips on downshifts
- Launch Control optimized (update of DSC & DME eventually necessary as well on 2012/2013 cars)
535i xDrive Sedan Stage 4
- Identical to Stage 3 map, but sports a true Race-Map in S/Sport+. Shifpoints are setup in a way you can leave the transmission in full Auto-Mode on Circuit.
Have fun!!!
      05-23-2020, 03:33 PM   #96
David_Vasha
Have fun!!!
Do you have the Xdrive function turned off by xdelete when you run xhp stage 3 with an engine tune? I've heard that the Xdrive components such as the transfer case can wear down and break when pushing jt like this. I don't know maybe I'm wrong on this. Someone enlighten me please
      05-23-2020, 05:30 PM   #97
dzz
2015 BMW  [0.00]
I haven't used Xdelete because it can potentially introduce new set of problems, but I researched it a bit. My concern was premature clutch wear and this was the response I got from Xdelete support team:
"There is no increased wear on the clutch pack, as long as you follow the recommendations of the manual about the different modes listed in chapter 4, page 13 and the workload, starting chapter 5, page 15.
https://www.xdelete.app/fileadmin/user_upload/xdelete/xdelete_manual.pdf"
If you have information about increased wear of transfer case components, please let me know. All tunes are pushing the boundaries of the hardware they are made for, so I wouldn't be surprised if there is potential issue with transfer case components. To their credit MHD and XHP support their tunes working together so there is interoperability which is supposed to reduce increased wear of related components.
      05-25-2020, 09:16 AM   #98
dzz
2015 BMW  [0.00]
Also, before you install XHP, you should probably reset throttle body adaptation and drive the car for a little bit so you can see the how it performs before trans flash.
I've found this on another thread:
1) hit start button once to turn on power (Don't start the engine)
2) then press the accelerator down to the floor for 5 sec
3) then hit start button once to turn off power
4) then remove foot from accelerator
5) then wait for 2 minutes (I waited 30 sec and it seems to work)
4) then start the engine like normal and try it out!
      11-17-2020, 11:11 PM   #99
T-Bone18
Drives: 2014 535i xDrive
Would you guys say that MHD + xhpFlashtool is a better combo than Bootmod3 ?
      11-18-2020, 12:10 PM   #100
ziekxq
Drives: 2011 535i xDrive
I am pushing close to 130k miles on the car now with past 29-32k miles on pure stage 2 + MHd custom tune + xHP Stage 3. Finger crossed so far no issues.
      03-17-2021, 01:32 AM   #101
malahhaor
Drives: F10 535I xD, F30 328i xD
Have fun!!!
Hey bud. Thanks for the info.
Do you have any instructions on how you got those customizations done?
Is that all in trans tune or some of it from BimmerCode/e-sys config type a thing?
Edit: never mind, did some more research... all part of tune. sorry.
F10 535I xD, 957 GTS, 991.1 C2 MT
F30 328i xD, 2006 Carrera 4, 2007 S550, 2006 CLS500, 2004 S500, 2004 CLK500, 1999 Lexus GS300, 2001 C320, 2002 C230K Coupe
1998 VTR - 1000, 1986 GSX-R 750
      03-17-2021, 09:43 AM   #102
dzz
2015 BMW  [0.00]
Have fun!!!
Yes, if get XHP, it is pretty much self explanatory inside the app
