2010 2011 BMW 5 Series Forum F10 New owner - 520d M Sport - a few questions |
09-27-2014, 09:21 AM | #1 |
Rep 54
Hi,
I've now owned a 2012 520d M Sport for a week, very happy with the car. I was wondering about a few things, and hope someone can help.
Many thanks! Vlad. |
09-27-2014, 10:03 AM | #2 |
Rep 29,202
1. Yes, only issue might be TPMS sensors.
2. No, but I'm not familiar with UK insurance. 4. They are two separate computers. And the trip milage in the dash is also separate.
09-27-2014, 11:04 AM | #3 |
Rep 1,597
3 - Yes and I hate them like that because they rust and look ugly against shiny clean wheels. I have mine sprayed to prevent this, doesn't cost much to get done.
09-28-2014, 03:44 AM | #4 |
Rep 1,207
Off question: Why do you want to replace the Run-Flats?
09-29-2014, 04:11 AM | #5 |
Rep 54
Hi, thanks for the replies.
gspannu, I don't really want/need to per se, I was just asking to find out if it's an option to replace them with non-run-flats. There's a lot I need to learn about BMWs as this is my first one! Regarding insurance, is it an issue swapping for the smaller wheels? In anyone's experience, does it increase/decrease the premium? These TPMS sensors, I'm trying to find info on them, but not being very successful. Where exactly are they and how do they work? Again, will swapping for the 17" wheels (genuine BWM with 225/55 run-flat tyres) cause any issues with these sensors? Yesterday, I adjusted the pressures in my tyres, and tried to follow the instructions for re-initialising these sensors, but I'm not sure I did it properly. The instructions say to drive off after starting the procedure. I did this, but is the car supposed to inform you after some time if the procedure completed successfully? Thanks for all the help! Vlad. |
09-29-2014, 04:35 AM | #6 |
Rep 8,081
You don't have TPMS sensors, the system uses the ABS wheel-speed sensors to detect wheels turning at a different speed if a puncture causes the overall diameter to change. It's a pit crap really but you won't have any problems. I change my 18" wheels to 17" winter wheels without issue.
Ian
09-30-2014, 01:35 AM | #8 | |
Rep 1,074
Drives: 2014 520D SE
Garage List 2014 BMW 520D SE [0.00]
2012 Audi A7 [0.00] 2013 Fiat 500 1.2 L ... [0.00] 2008 BMW 335D SE To ... [0.00] 2012 Mercedes-Benz ... [0.00] |
I was quite surprised to find my 2014 520D does have TPMS so have to assume it is now standard cross the range although looking at the pressures displayed on screen, it's not the most accurate thing in the world. |
09-30-2014, 02:19 AM | #9 |
Rep 8,081
If individual TPMS sensors are now standard then I can only assume that was done with the LCI update; both F10s I have use the ABS sensors. I've just ordered an F31 so I'll see if that has individual sensors when it turns up.
Ian
09-30-2014, 02:43 AM | #10 |
Rep 1,207
F10 started to have TPMS sensors since about Oct 2013 onwards (LCI started in July 2013, so a few months later).
It is now standard, it used to be a paid option earlier...
09-30-2014, 02:50 AM | #11 | |
Rep 267
M140i LCI-2 is the 16th BMW since 1977 ....
320i *2, 323i, 520i *2, 540i, 535i, 840i, E36 M5, 328i, 530i, 320d, 535d, M135i, M140i * 2 |
09-30-2014, 02:53 AM | #12 | |
Rep 8,081
My winter wheel set does not have TPMS but I suspect my inbound F31 may very well do.
Ian
09-30-2014, 11:17 AM | #14 |
Rep 45
There are two systems to monitor the tyres:
1. Using the ABS sensors which detects a change in tyre size, this is the standard monitoring system for us in the UK. This can be vague and cannot be solely relied upon, however still better than nothing. 2. The option of Tyre Pressure Monitor (TPM), (£255 option) that will show in iDrive the exact tyre pressures (and temperatures) for each wheel. Our american friends have this as standard on their BMWs, I think theres some legal aspect to it over there. Hope that helps. |
09-30-2014, 11:25 AM | #15 | |
Rep 1,074
My car has ZERO options on it. It is as stock as stock gets Looking in the brochure it does offer up the Tyre pressure monitoring (option 2VB) for £255 as you say but trust me, my stock 520D has this as standard as I am able to dial into iDrive and monitor tyre pressures and temperatures so I am not mistaken. A quick check with others in the office (we ordered 6 of these via 6 different dealers over the space of a couple of weeks) and they all have it |
09-30-2014, 01:13 PM | #17 |
Rep 72
This is from a BMW press release:
"Available in future as a standard feature: Tyre pressure indicator for each individual tyre. Starting in spring, drivers of a BMW will be warned of a loss of tyre pressure more precisely than ever before. A tyre pressure indicator will be offered as a standard equipment feature on all new vehicles of the brand with the exception of the BMW X6. Sensors on all four tyres facilitate an exact and individual monitoring of the pressure in each individual tyre. The tyre pressure currently at hand will be shown in the Control Display or the instrument cluster, respectively, depending on the model and the equipment options customers have chosen. In the event of a loss of tyre pressure, the driver will be made aware of a possible danger well in advance." A link to the full info: https://www.press.bmwgroup.com/globa...&id=T0164771EN |
09-30-2014, 07:24 PM | #18 | |
Rep 1,207
10-01-2014, 02:25 AM | #19 |
Rep 45
Atleast a definitive way of knowing if you have the TPMS rather than the ABS one is to check the iDrive. Maybe some could chime in if they can see it on a BMW vin decoder for another certain way of knowing if you have it or not.
10-01-2014, 02:42 AM | #20 | |
Rep 1,074
[Equipment Section Subheadline Label]
10-01-2014, 05:46 AM | #21 |
Rep 5,085
Found this on the national tyre website as a fyi
TPMS legislation New EU legislation requires all new models of passenger cars sold in the EU to have a TPMS system installed from November 2012, and every new car from 2014. New vehicles fitted with TPMS and first registered from 1st January 2012 will have their TPMS system tested as part of the first MOT test the vehicle has carried out. The legislation has been driven by environmental concerns as part of the EU’s commitment to reducing CO2 emissions, as well as safer motoring. |
