2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes 18" wheels owners, what tires pressure?
      05-13-2012, 05:12 PM   #1
The X Men
Drives: 2013 X3 35i
To all the 18" wheels owners out there ,what tires pressure are you guys running? The door jam saids 35 front and 39 rear, is anyone running higher or lower tires pressure? Also, do you think the front tires will wear differently from the back since there is 4 PSI difference.
      05-14-2012, 05:19 AM   #2
inny
Cyprus
Drives: F10
2011 BMW F10  [0.00]
1995 BMW E34  [0.00]
2007 BMW E60  [0.00]
2.2Bar all around (M-Sport). Thats 32PSI
      05-14-2012, 05:53 AM   #3
HighlandPete
Drives: BMW F11 535i Touring
Sounds about right to me, OEM recommendation is typically best balance for wear and handling. Be aware, RFTs at low pressures are likely to wear much faster on the shoulders, so don't be tempted to run low pressures for a 'softer' ride. It doesn't work.
Rears typically wear much faster on a RWD BMW anyway, regardless of pressure. Always been the way and if we don't, or can't rotate, we replace rears much more often.
HighlandPete
      05-14-2012, 06:42 AM   #4
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
31 front, 33 rear, wear perfectly even across the tread, rears naturally more worn than the fronts, but still showing at least half life remaining after 16k miles.
      05-14-2012, 08:19 AM   #5
The X Men
Drives: 2013 X3 35i
That is much lower than the recommanded pressure, are you running the lower pressure for a sofer ride and better traction?
      05-14-2012, 01:39 PM   #6
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Recommended pressures as per door frame decal:
Front 245/45/18: 2.0-2.5 bar (29-36psi) light-heavy load
Rear 275/40/18: 2.2-2.7 bar (32-39psi) --------"---------
My pressures, as stated earlier: F 31psi, R 33psi, can't see anything "much lower than recommended" there.
      05-14-2012, 06:05 PM   #7
The X Men
Drives: 2013 X3 35i
The US label just say 35 front and 39 rear, no min pressure recommandation.
      05-14-2012, 11:49 PM   #8
inny
Cyprus
Drives: F10
2011 BMW F10  [0.00]
1995 BMW E34  [0.00]
2007 BMW E60  [0.00]
Actually this is what the label says for my car. Of course it gives higher pressure for more load but to be honest I was always a bit confused about it. I am mostly driving alone.
Any other suggestions besides 2.2bar? Safe to go 2.5?
      05-15-2012, 03:15 AM   #9
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
I suggest that you experiment within the recommended pressure range to find the ride and handling characteristics that suit you best.
It took me a while to establish my figures and, based on the fact that, after 16k miles, the wear is perfectly even across the tread, it would appear that I wasn't far off the mark.
Like you, I usually drive alone or with one front passenger and almost always lightly loaded. However, if I want to take a long trip with an increased load I adjust the pressures accordingly with a portable 12v compressor.
Most importantly, don't forget that accurate tyre pressures can only be maintained by using a reliable good quality gauge.
      05-15-2012, 03:48 AM   #10
HighlandPete
That is interesting Jon, but must say I'm surprised BMW are running the lower front figure. Particularly on the 535d. Then it is a quite a big wheel these days, that makes a difference. My old 540i needed 35psi up front, as does my 330d, both on 45 section tyres.
Most importantly, don't forget that accurate tyre pressures can only be maintained by using a reliable good quality gauge..
What you are saying is the best way to get it right anyway. I start with the lower 'light load' recommendation and work from there, get the balance of driving quality vs. best wear rate.
HighlandPete
      05-15-2012, 12:29 PM   #11
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
I run 35 front and 39 rear. Always go by what's indicated on the door jam if the tires came with the car.
      05-16-2012, 02:41 AM   #12
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
If you have 245/45/18 front and 275/40/18 rear, those pressures are for a fully laden car. Doesn't your door decal indicate a pressure range from light to full load?
Handling characteristics and tyre wear are affected by how heavy the car is and this is compensated for by the manufacturer's recommended range of adjustment.
UK cars have this range clearly indicated on the door frame decal.
      05-16-2012, 01:14 PM   #13
JNoSol
JNoSol's Avatar
Yes, my car does indicate 2 pressure recommendations. I usually keep them towards the high side, maybe 2psi less. The higher pressure recommendation not only for full load, but higher speed as well. If you drive above 80mph, you should alway air up towards the higher spec.
As for the full load or light, I rather air it for the full load spec. I never know when I'm taking a full car of people to lunch. It's not like I could go air up, then come back to get them.
      05-17-2012, 02:54 AM   #14
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
It all comes down to personal preference and if you're happy with running on the high side, then that's all that matters.
I keep mine towards the low side because I usually run lightly loaded and, after experimenting extensively within the range, I find it gives me the best ride and handling. Additionally, as I mentioned earlier, tyre wear is also a significant factor to consider and considering that mine are all perfectly even across the tread, it indicates that I've found what's right for me.
      05-27-2012, 11:22 PM   #15
RR80
RR80's Avatar
17
Drives: F10 535i
I run 34 all around~!
2003 E60 530i - PSS9 Coilover/M Kit/BBS GT-RS 19" wheels - retired
2006 E91 335i - Procede V5/Forge DV & FMIC/Bastuck quad exhaust/P1 Steering Wheel/Sachs Coilover/M kit/19" RS wheels - retired
2011 F10 535i - Stock
      03-25-2019, 03:16 PM   #16
Rajac
Drives: BMW 520 d M Sport
Anyone runs this configuration? 245/45 99Y R18 Front / 275/40 96 Y R18 Rear. I struggle with choosing the correct tyre pressure for this setup. Now I'm on 32 PSI Front/ 34 Rear.( Pirelli Cinturato P7 Runflats). Thanks in advance 👍🏻😁.
