2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BMW F10 Coding DIY (and other Fxx models)
      12-14-2014, 08:40 AM   #89
F10Thai
Thailand
Drives: 530e G30 / 528i F10
Hi, Shawn
I cannot find anything under JBBF as
Originally Posted by shawnsheridan View Post
JBBF => RLS_DEF_FLC_SCHWELLWERT_SATZ
JBBF = >RLS_FLC_SCHWELLWERT_SATZ
normal
empfindlich = sensitive
sehr_empfindlich = very sensitive
unempfindlich = insensitive
Is there any other way to adjust the sensitive of headlight sensor?
      12-14-2014, 09:00 AM   #90
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Originally Posted by F10Thai View Post
Hi, Shawn
normal
You could use an E-Wort, but what is the name of you JBBF CAFD?
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      12-19-2014, 12:50 AM   #91
ZAKSM3
ZAKSM3's Avatar
Germany
23
Drives: 16 M3, 15 X5 3.5d
2016 M3  [0.00]
2015 X5 35d  [5.00]
2011 528i
Does anyone know if it is possible to code the headlight washers on and off on a 2011 528i?
Thanks!
      12-19-2014, 04:52 AM   #92
shawnsheridan
Thanks!
JBBF => SCHEINWERFERREINIGUNG = nicht_aktiv
      12-19-2014, 05:16 AM   #93
ZAKSM3
ZAKSM3's Avatar
Germany
23
2016 M3  [0.00]
2015 X5 35d  [5.00]
Thank you! I hate those damn headlight washers!
      12-21-2014, 07:14 AM   #94
Captain Monte
Drives: 2011 550i sport
F10 coding tampa
I just recently purchased a f10 550i. I was wondering if anyone does coding in the Tampa Bay Area. This is my first bmw with Idrive, I've just read about changing many options and this peaked my interest. Any info would be great.
      12-21-2014, 07:23 AM   #95
Captain Monte
Tampa coding
I'm looking for someone in Tampa or around Tampa to do some coding. Any help would be great.
      01-23-2016, 04:23 PM   #96
Rieger
Drives: Bmw F10
H1 siren installed in my F11 and mirror with LED.
How to enable LED blinking without DWA?
      02-17-2016, 09:40 PM   #97
DaHeadlightGuy
Drives: 2013 DSB F10
Just picked up a 2012 535 Xdrive. having trouble finding the needed software to do coding. Seen some sites selling software for $50 and some for $15 just need. I was reading a older post and no one listed where to get software they kept it all in PM's
      02-18-2016, 05:07 AM   #98
shawnsheridan
PM sent.
      03-10-2016, 03:51 AM   #99
sunnytailor
sunnytailor's Avatar
9
Drives: 2018 X5 4.0d MSport
Hi All,
I have sucessfully coded a few things on my 640D GC 2013 but i am strugging with a few
I cant seem to get cluster set to white at all time and i cant get my mirror to fold on one click. i have used the following
SIDE MIRROR CLOSING W/ KEYFOB
FRM / 3020 / ASP_BEIKLAPPEN_BEI_KOMFORTSCHLIESSEN -> aktiv / Werte=01
CAS / 3003 / KOMFORTSCHLIESSUNG_FB -> activ / Werte=01
CAS / 3003 / KOMFORTSCHLIESSUNG_PA -> activ / Werte=01
White Cluster at night
KOMBI 3007 DIM_NACHT_EIN Werte: FF
thanks
      03-10-2016, 05:06 AM   #100
igorsvrub
Drives: X5, 40d
Originally Posted by sunnytailor View Post
Hi All,
thanks
Do not know if it helps...
I did coding on my f15 and side mirrors close with time delay(comfort access) about 2 seconds if I touch door handle but from key close by one touch.
      03-10-2016, 05:13 AM   #101
igorsvrub
Drives: X5, 40d
Just wondering if somebody did high frequency stop signals activation(when you push brake very hard it is blinking very frequently)?
      03-10-2016, 09:54 PM   #102
I did but I don't remember the specific code. I found most of the codes in an F30 forum. Here's what I used...
BEST_F10_CheatSheet_V3.0 (1) (1).pdf
BEST_F30_Coding_Reference_Guide_v1.7 (2).pdf
      03-13-2016, 01:59 AM   #103
igorsvrub
Drives: X5, 40d
Attachment 1379950
Attachment 1379951
Thanx, but cheat sheet from f30 is suitable for f10?
      03-13-2016, 09:36 PM   #104
Yes.... I've all my coding using those lists.
      03-15-2016, 06:04 AM   #105
sunnytailor
9
Thanks this worked. i coded it to 00 and it did the trick.
The only one im stuggling with now is DIM_NACHT_EIN will not keep to FF it keeps reverting to 0A so i cant get white cluster at all times. i need to work out what is triggering it to change back
      03-17-2016, 03:04 PM   #106
igorsvrub
Drives: X5, 40d
This I did not code, so have no clue...
      03-25-2016, 01:42 PM   #107
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Hi All,
thanks
Awesome! I was looking for the white cluster at night.
IG: @bmwdoubles
      04-26-2016, 09:56 AM   #108
Badiiinfluence
Badiiinfluence's Avatar
Drives: F10
Hi,
Im new to this forum and would like to code my 2013 f10. Anyone who can help me with the software and cheat sheet? I will greatly appreciate. Thanks
      04-26-2016, 10:26 AM   #109
shawnsheridan
Originally Posted by Badiiinfluence View Post
Hi,
You cannot send or receive PM's yet. Send me one when you can.
      05-21-2016, 05:02 PM   #110
tjwomer
Drives: 2013 535i
Trying to code my 2013 F10 and I can't get the target to show anything. I verified that my e-sys is pointed at C:\Data. I am using a Microsoft Surface so I am having to use a Ethernet adaptor to plug in the cable. I have gone over the directions step by step 3 times already and cannot figure out how to connect to the car.
