2010 2011 BMW 5 Series Forum F10 ?lowered and dealer's response for alignment? |
05-03-2016, 05:47 PM | #23 |
Rep 14,522
He could have said subframe?
05-04-2016, 02:25 PM | #24 |
Rep 14,522
So I'm going to play dummy here just because it's great to hear your guy's input and it should make sense to me but...when the tech says he was able to get it back within OEM specs regarding the alignment wouldn't the OEM specs be null because it's now lowered? I remember on my Accord and it was on coilovers I had to take it to a specialty shop for lowered vehicles and they aligned it old skool. He explained because it sits that low the vehicle cannot be aligned to OEM specs but it can be aligned to get camber, caster and toe at the height it's sitting. Which totally made sense to me. Or maybe in the BMW it's fine and I'm just not comprehending what he meant by BWM specs?
05-04-2016, 02:48 PM | #25 | |
USAF Pararescue Veteran
332
Rep 770
05-04-2016, 03:25 PM | #26 |
Rep 14,522
Appreciate the insight PJ! I know the tech said even tho I'm sitting that low he was able to align the car. I just thought I spent too much time over thinking. Like I mentioned he did say rear camber was 2 degrees way off and was able to pull it back to almost 0 or flat
05-04-2016, 03:47 PM | #27 | |
332
Rep 770
05-05-2016, 08:32 PM | #28 |
Rep 18,716
FYI, what kills the tire is the toe.
Camber is for tire surface that is in contact to the ground. 0 degree means you have full tire contact to the ground on a straight line. - degree means you will have less outer tire contact to the ground on straight line, but have more contact during a turn. + degree is the oposite of the - degree. While toe adjustment, will control more of the oversteer and understeer. There is more to it than just saying - camber will burn your tire fast.
05-05-2016, 11:46 PM | #29 |
ZEROdoubleZERO
228
Rep 659
05-05-2016, 11:48 PM | #30 | |
Rep 14,522
05-06-2016, 12:46 AM | #31 |
ZEROdoubleZERO
228
Rep 659
05-06-2016, 01:35 AM | #32 |
Rep 14,522
i see...i'll wait til tomorrow when there's daylight and i'll take some pictures
