2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding BMW F10 Coding DIY (and other Fxx models)
      07-21-2016, 01:35 PM   #155
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Originally Posted by paul223 View Post
Need latest data files please.
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      07-21-2016, 01:42 PM   #156
shawnsheridan
Originally Posted by Carlos528i View Post
Can anyone provide a link to the most recent GRACENOTE database?
Thanks
Carlos
Understand that Gracenote Database (GNDB) comes as either a CIC version, which is Global, or NBT version, for which there are 5 different regional versions.
Because you have a 2013 F10 in Marietta, GA, I'll assume you need NBT North America version. PM sent.
      07-21-2016, 07:48 PM   #157
Carlos528i
Drives: 2013 528i
2013 BMW 528i  [0.00]
That was easy... GNDB is now at ver.01/16
Thanks!
      08-11-2016, 08:24 AM   #158
tsameti
Drives: BMW F10 535i
Does car have the minimum hardware for LDW, as in KAFAS Camera?
What do you mean by minimum hardware?
I can see, there's a camera in the windscreen, is there anything else required for LDW?
      08-11-2016, 08:59 AM   #159
shawnsheridan
KAFAS Camera mainly, but system also has Steering Wheel Vibrator and Dash Switch to toggle On/Off.
Is Camera in Windscreen a KAFAS Camera or cheap FLA Camera used only for HBA? The only way it would be a KAFAS Camera is if car has LDW or SLI from factory, otherwise it will be FLA Camera.
      08-11-2016, 09:25 AM   #160
tsameti
It hasn't got switch button on the dash so I guess it wont work on my car.
It does have camera but not sure what it is capable of doing.
Thanks anyway.
      08-11-2016, 09:43 AM   #161
shawnsheridan
Thanks anyway.
Without factory LDW nor Speed Limit Info (SLI), then it is FLA High Beam Assist (HBA) Camera only, and can do nothing more.
      08-11-2016, 10:52 AM   #162
Bruno112
Croatia
20
Drives: 2014 F10 530d MSport
If you have kafas camera what would you can upgrade with just coding if it possible?
      08-11-2016, 10:56 AM   #163
shawnsheridan
KAFAS gets you capability of LDW, SLI, and HBA, so you already have at least LDW or SLI from factory.
LDW is codeable, but requires Steering Wheel Vibrator and Dash LDW Switch.
SLI is codeable, but requires a 7E FSC Code.
HBA is codeable, but requires Steering Wheel Stalk with HBA Switch.
      08-15-2016, 03:26 PM   #164
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2019 M2 Competition  [0.00]
2002 330ci  [0.00]
Who knows to coding for the automatic trunk lift? IE to turn it on and off? Thanks!
      08-15-2016, 05:44 PM   #165
shawnsheridan
Do you mean Trunk Open / Close from Footwell Button and Fob?
      08-15-2016, 07:02 PM   #166
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
I did some programing and the only thing that does not work the is the power tailgate. It does not open even if opened from the button on the the tailgate. Was working be for and no fault code in ISTA/P so it has to be something I did in E-SYS.
      08-15-2016, 07:08 PM   #167
shawnsheridan
Well, you can reset it by VO Coding module (right-click HKFM => Code).
Make sure you have Valet Mode switch disabled too.
NV GUNS57.50
      08-15-2016, 07:42 PM   #168
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
How do you disable the valet switch?
      08-15-2016, 07:51 PM   #169
shawnsheridan
The slide switch in the Center Armrest.
NV GUNS57.50
      08-15-2016, 07:52 PM   #170
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
Crap I totally forgot about that guy, thanks!
      08-15-2016, 07:53 PM   #171
shawnsheridan
If it was enabled, then it would explain trunk not working.
      08-16-2016, 05:38 PM   #172
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
Need a little more help. I tried right click on HKFM and I do not get the option to code, I dug a little deeper in rheingold and it say there the is no HKL coding present for the lift gate, it did not really give me a solution.
      08-16-2016, 05:56 PM   #173
shawnsheridan
Was FA Activated? If it was not, then you would not be able to Code it?
Does HKFM show to have a CAFD file when you look at it with E-Sys?
      08-16-2016, 06:15 PM   #174
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
Yes FA Was activated, it shows up with a CAFD in one of my back files but that is the one that deleted the CAFD. How so I add the CAFD back in.
      08-16-2016, 06:16 PM   #175
shawnsheridan
Deleted? What do you mean? What happened to HKFM's CAFD?
      08-16-2016, 06:17 PM   #176
NV GUNS
NV GUNS's Avatar
Drives: 19' M2C
2023 M550  [6.75]
2002 330ci  [0.00]
I don't know what happened to it. It's not there.
