2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum LCI 550i (N63TU) Oil Preference
      12-05-2019, 02:39 AM   #1
fakem5
Drives: 2009 E92 M3
Hi, I just got a used 2014 550i M Sport with the TU engine and I'm planning to do the oil change by myself. I'm curious as to what is the most preferred engine oil as these cars are known to run hot. Would a 40 oil not burn as much as a 30? Thanks.
      12-05-2019, 07:50 AM   #2
Sophisticated Redneck
Drives: 2012 BMW X5 50i
I Have an X5 with over 150,000 on the N63 in it. I only use Liqui Moly 2332 Leichtlauf High Tech 5W-40 and add 1.5 cans of the Mos2 additive to each oil change.
You will notice a much smoother running engine and it will burn less oil however if your valve guide seals are completely shot like mine were, your going to burn oil no matter what.
Highly recommend this oil for all N63's and S63's and all variants of it. I recently took the engine down to de-carbonize it and install new valve stem seals. Look at the cylinder bores and the cam journals, they look incredible for an engine in a 5300lb vehicle driven the way I drive with over 150K on it. Again highly recommend this oil especially with the Mos2 additive
Tags
550i, lci, n63tu
