2010 2011 BMW 5 Series Forum F10 LCI 550i (N63TU) Oil Preference |
12-05-2019, 02:39 AM | #1 |
Rep 14
Hi, I just got a used 2014 550i M Sport with the TU engine and I'm planning to do the oil change by myself. I'm curious as to what is the most preferred engine oil as these cars are known to run hot. Would a 40 oil not burn as much as a 30? Thanks.
12-05-2019, 07:50 AM | #2 | |
Rep 1,564
You will notice a much smoother running engine and it will burn less oil however if your valve guide seals are completely shot like mine were, your going to burn oil no matter what. Highly recommend this oil for all N63's and S63's and all variants of it. I recently took the engine down to de-carbonize it and install new valve stem seals. Look at the cylinder bores and the cam journals, they look incredible for an engine in a 5300lb vehicle driven the way I drive with over 150K on it. Again highly recommend this oil especially with the Mos2 additive |
philipm78581.00 FrannieMoral20176.00 |
Tags |
550i, lci, n63tu |
