05-08-2016, 09:14 PM | #1 |
Dream crusher
984
Rep 2,421
Need to change out my front brakes and was wondering if anyone had any tips or links they could share. I found this which seems like the answer. http://www.bimmerfest.com/forums/sho...d.php?t=845808
My question about that tutorial is he mentioned having the right c-clamp to make clearance for the brake pads to be removed from the rotor. On the caliper where his c-clamp is, there is a groove. Is that for a small c-clamp or tool to depress the pad against the piston?
IG: @bmwdoubles |
05-09-2016, 09:59 AM | #2 |
Rep 984
I just use a flat-head screwdriver (in between the pad and the rotor) to press outward against the pad. Much easier.
2009 X5d | 2007 E90 Track | 2002 M3 Track | 1991 535i Track
05-11-2016, 08:34 AM | #3 |
Rep 113
What pad are you going with, for my brake change I want to find a pad with a bit more bit the braakes on the f10 feel dull to me compared to other cars like the e90 and the w211 w221 mercedes
05-11-2016, 09:49 AM | #4 |
Rep 14,522
i know on the M5 board someone posted a thread regarding pads with less brake dust.
05-11-2016, 10:48 AM | #5 |
Dream crusher
984
Rep 2,421
The OEM brakes are my first choice. Trying to avoid squealing. My e90 was notorious for squeaking. If you want more bite I would guess a slotted rotor would be the answer, but I don't know which brand that would be. Someone would have to do a brake test stock vs slotted stopping distance. I believe our stock stopping distance is 60-0 109ft.
The next step up is retrofitting M5 brembo brakes calipers, pads and rotors.
IG: @bmwdoubles |
05-17-2016, 11:15 AM | #6 |
Rep 243
I ended up installing the PowerStop Evolution Ceramic pads from Rock Auto onto my stock rotors. The pedal feel didn't chance but the wheels stay clean and the brakes no longer squeak. I would recommend this to anyone who is sick of dirty wheels or high pitched squeaking.
Also, if you don't have the right sized c-clamp, you can pull the caliper against the rotor to drive the piston in. It doesn't take too much force. |
