2010 2011 BMW 5 Series Forum F10 HEADS UP! ANYONE need SLOTTED DRILLED ROTORS? Good Deal going on... |
09-07-2015, 02:48 AM | #1 |
Rep 1,407
So I have been searching around for slotted and drilled rotors and finally found a place that sells at a good price and right now they have a 30% off sale until 9/08!
Breakdown: 550i brakes full slotted and drilled WITH ceramic pads for $555.99 shipped! 535i SAME set-up for $401.99 shipped! 528i SAME set-up for $386.99 shipped! Use coupon code media31for an extra 5 bucks off! http://brakeperformance.com/ Pic of the set-up I bought. PLEASE note I do not work for these guys just giving members here a heads up! |
09-07-2015, 08:37 AM | #2 |
Rep 14,522
Wait..
That's for all 4 rotors? Just checked it out...that's a pretty good deal! Last edited by lsturbointeg; 09-07-2015 at 08:43 AM.. |
09-07-2015, 12:21 PM | #4 |
Rep 14,522
I hear ya! When my wheels come in I also wanted to upgrade the rotors just for pure aesthetics reasons! But my dealership would void my warranty because i already inquired so I have to wait
Definitely post some pictures when u do! R u installing them yourselves? How are u going to bypass the ebrake? |
09-07-2015, 02:05 PM | #7 |
Rep 1,407
Here's an entire diy on how to bypass the ebrake for the rears. The fronts are just like everything else.
http://f10.5post.com/forums/showpost...5&postcount=42 No programming of the brake pad sensors are far as I am aware of... |
09-07-2015, 02:06 PM | #8 |
Rep 140
Drives: Bimmer Beauty
09-07-2015, 03:36 PM | #9 |
Big Beaver Smile
2101
Rep 3,791
It looks like I'm the only one who HATES slotted and drilled rotors on a regular car (track cars benefit from them) They are a PITA when you wash your car, the water gets caught in the slots/holes , gets that little surface rust in minutes, no matter what you do to dry them, then they shoot "poo-water"around the inside of the rims. I've got 2 cars that came with them and I wish they didn't.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch |
09-07-2015, 05:53 PM | #10 | |
Rep 14,522
09-07-2015, 06:43 PM | #11 | ||
Rep 736
09-07-2015, 08:48 PM | #12 |
Rep 1,407
Bypass was a bad word to use. It just lets you get to the ebrake actuator mechanically instead of electronically.
09-08-2015, 12:50 AM | #13 |
I am groot
25
Rep 149
I just ordered rear cross drilled rotors and ceramic pads for my 550i. I'll be doing the install myself using the DYI thread posted. I can post some pics if someone is interested, just let me know what you want to see. My order will be shipping from Cali so I will assume they should be here by Thursday or Friday and after I get the rotor hats machined I will do the install.
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order |
09-08-2015, 12:52 AM | #14 | |
I am groot
25
Rep 149
2011 550i M SPORT
09-08-2015, 02:07 AM | #15 | |
Rep 1,407
09-08-2015, 12:23 PM | #16 | |
Rep 510
The slotted rotors are ok but it'll make dust and eat pads faster. The cross drilled rotors tend to crack and cause banding since most of the ones you see are cheaply made. http://forums.nasioc.com/forums/show....php?t=1340727 Both the slots and drill holes will have permanent rust if you don't paint it with high temp paint before installing. Sometimes, these rotors will actually worsen your braking power. I highly recommend not trying this if you live in the North East because it's more problems than it's worth. Unless, of course, it's your garage queen. Please do not take these rotors to the track either. It's not safe. The real stuff is very expensive but you probably already know this. The best mod, in the F10, to stop faster is replacing the oem runflats. |
09-08-2015, 03:34 PM | #17 | |
I am groot
25
Rep 149
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order Last edited by Autobuffoonery; 09-08-2015 at 03:46 PM.. |
09-08-2015, 04:02 PM | #18 |
I am groot
25
Rep 149
Also this thread does not apply to all cross drilled rotors, the rotors in the thread are way past their prime and should have been replaced long ago. The OP also states he bought them used from another member who crashed thier car, so how long were they in use? This was a typical bashing thread where users were to blame.
2011 550i M SPORT
CF kidney grills, rear diffuser, rear spoiler, bmw emblems, Megan Racing mufflers, H&R Sport Springs, Forgestar F14's Front 20x9/275/30r20 Rear 20x11 305/25r20, AQ3500d, Audio Control LC2, custom ascendant audio 12" chaos/mayhem's 4th order Last edited by Autobuffoonery; 09-08-2015 at 07:02 PM.. |
09-08-2015, 06:34 PM | #19 |
Rep 14,522
Thanks for the insight! Pure aesthetics for me but if these rotors are better than the other cheap rotors out there than cool! definitely post some pictures if I plan to do a DIY... the more DIY the merrier!
09-08-2015, 07:06 PM | #20 |
Rep 5,357
Have cross-drilled/slotted rotors on our LS with ceramic pads. Dust is almost imperceptible. I don't notice any lack of initial bite. I had Porterfield pads before and initial bite was horrendous. After a second of wondering if they were going to bite or not, they grabbed hard enough to feel like you were going through the windshield! They just needed a little heat.
When the brakes are on my dime I will be getting ceramic pads and (maybe) slotted rotors. |
09-08-2015, 07:08 PM | #21 |
I am groot
25
Rep 149
No problem mine are for pure aesthetics too, they just happen to be better than stock.
2011 550i M SPORT
09-09-2015, 12:31 AM | #22 | |
Rep 510
1. I've never heard anyone say stock rotors are bad or have seen recurring posts about broken rotors for the F10. Other previous BMWs, yes. Don't start with the "high carbon steel..." BS. They all claim that but they don't list the actual specs. 2. No kidding that ceramic pads don't have tiny metal particles. Why do you think one is called metallic and the other is ceramic. 3. I posted the link for people to see the cracked rotor. Just picked a random pic off google search. I can guarantee you this. You will find 100x bad stories about messed up slotted and drilled rotors than not. 4. Drilled rotors cannot be better than non cross drilled motor of the same material. Its structural integrity is compromised by drilling! duh!. That's why those drilled and slotted rotors built for racing is so expensive; they have to use much tougher materials to make it so it cost thousands. There's no such thing is +30% braking power over OEM. If you can prove that 30%, then I'll give you my life's savings and my 550. The bottleneck for braking in the F10 are the tires. Yeah $400 full set of rotors and brake pads that are superior than OEM rotors from BMW in every way? Are you insane? I'm not saying OEM stuff is good but you're on crack if you think some $400 aftermarket bundle is actually better. Change the tires and you'll see braking distance shrink by 20 ft or so at 70+. 5. I don't know how you can ceramic pads are easier on rotors. They are a harder compound and will wear your rotors out faster. Ask ANY real mechanic. It's also why they don't have as much dust. There's no such thing as a superior performance long lasting pad that creates less dust without creating more wear somewhere else. Physics simply won't allow it. 6. Under load, high heat, and constant stress, the semimetallic pads will win hands down. They are more consistent with less fade. Ceramic is garbage for the track or heavy duty. This is BASIC knowledge of brake pads. People, including me, buy ceramic pads for lower dust and less noise. That's appealing for daily drivers. 7. Rotor warping is not really about the rotor physically warping in nearly every case. Your claim of going 140 and slamming the brakes to test it is probably BS. If you know anything about judging braking performance, it's not about warping if you brake "many times at 140+". It's about FADING. 8.... You know what. I'm just going to stop there because I would have to write an entire essay if I keep going. The point is you are so wrong on most of what you say that it's quite alarming and I am sad to see people actually believe you. Like seriously, anybody can simply look up this stuff with a simple google search like this one http://www.autoanything.com/brakes/t...-metallic.aspx Here's what I can tell. You are probably not a real mechanic; or you are a really bad one upselling products to make an extra buck. Maybe you're just trying to sound cool on the internet. Whatever you do, please do not mislead people with false information. Like I said, buy them if you want aesthetics but don't count on better performance. I'm willing to bet if you buy this bundle and run it on the track, it will actually perform worse than the OEM brakes. If you run it hard on the track, it will eventually fade and/or crack, but it probably won't warp like this guy is trying to convince you. |
