2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Video: V1 Hardwire DIY Install F10 5
      09-20-2013, 06:58 PM   #1
cncmastr
cncmastr's Avatar
Drives: E30 M3 Cecotto, F85, G05, G07,
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2005 BMW X5 4.8is  [0.00]
2006 BMW M3  [10.00]
Hi guys,
I just posted a video here that shows how to hardwire (using the V1 hardwire kit) the radar detector in an F10 M5, should be the same for a non-M. I used green wire with the brown stripe on it to tap into. It was hard to access the ground bolt, but with a swivel accessory it is possible. I referenced this guide for help as well. - http://www.bimmerfest.com/forums/sho...d.php?t=515517
Thanks to William for letting me use his car.
      02-16-2014, 03:39 PM   #2
JCat27
Drives: 2013 535i
Just did mine the same way, super easy. Hardest part is removing the light/sunroof assembly...
      01-28-2017, 07:34 PM   #3
Just tried in my new-to-me '14 535i and no luck getting power from that wire. I even used a test light to no avail...
Ideas???
      01-29-2017, 05:31 AM   #4
cncmastr
cncmastr's Avatar
2018 X5 M  [0.00]
2020 M2 CS  [10.00]
2006 BMW M3  [10.00]
Ideas???
Make sure you are doing the ground wire correctly. The screw we use has a coating on it.
      01-29-2017, 02:37 PM   #5
I actually drilled a hole in that cross-member where the plastic screws live and installed a ground wire.
I just gave up and am now running the wiring like I did in our '12 535... Down the "A" pillar and into the fuse box.
      03-07-2020, 11:59 AM   #6
ramman434
Drives: F30 335i
2020 update: just completed this for my 2016 535; I had to do just like in the video, and put a half washer on top of the ground wire and the grounding screw in order for their to be a full connection.
For the wire giving power, in the video he instructs to use the green/brown wire. This DID NOT work for me at all. I ended up using the thicker red/brown wire, and BOOM, my Valentine started up no problem.
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21
'13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake
cncmastr1588.50
Tags
diy, hardwire, install, valentine one v1 radar detector
