2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum WHY Does "Auto Start/Stop" Default to ON ?
      01-24-2012, 01:21 PM   #67
Seattle135is
Drives: 2015 M4
2007 335i  [0.00]
2005 SL 55 AMg  [0.00]
2007 Porsche 997 Turbo  [0.00]
My '11 550 went in for a service - I got a '12 528 loaner with this feature - totally tripped me, but I suppose this will become the norm shortly. I always felt a feeling of relief when the car did start again...
2018 R8 V10+ - Ara Blue/Gray
2022 MS Plaid - Red/White (Daily)
2021 Alfa Stelvio - Red/Black
2013 135is - LeMans Blue/Gray
2003 M5 (56k miles) - CB/Black
      01-24-2012, 10:03 PM   #68
NYF32DRIVER
NYF32DRIVER's Avatar
Drives: 2016 428i X Drive
"Porsche Already Has It"
Originally Posted by E90Fleet View Post
The system cannot be coded to off by the dealer.
Its has to be on for the engines to get their EU gas mileage certifications and emissions ratings.
The dealer can switch it off for a short while for diagnosis reasons while hooked up to the dealer system, but it will go back to normal once the car is disconnected from the system
Expect to see it in more and more European cars.
Porsche already has it
Yes, they do but it can also be switched off PERMANENTLY.
2016 428i X Drive. Mineral Gray Metallic. Born 2/2016, Munich Factory.
Member BMW CCA Since 2008
      02-04-2012, 11:54 AM   #69
SickNick
Drives: 2009 328i xDrive
This is insane. I cannot believe they put this feature to be ON by default when you start the car. My car is manual and every time I look down I get confused and think I stalled. EVERY feature on a car should default to the previous setting. I bought the damn car and I want to determine which settings I want. I don't want the car doing that for me.
      02-04-2012, 01:20 PM   #70
NYF32DRIVER
Again: Yes, Porsche DOES have it but it CAN be switched/defaulted to OFF !!!!
      02-04-2012, 05:03 PM   #71
E90Fleet
South Africa
1312
Interesting
A journalist friend of mine said that the 2012 911 they drove at the world launch here in South Africa kept defaulting to on, just like the BMW system.
They kept having to press the deactivation button after each start
Maybe they were not informed properly hoe to permanently turn it off ?
Porsches ad for it
BMW if you are reading, I need a job, Please.
      02-09-2012, 01:36 PM   #72
NYF32DRIVER
Interesting...
Interesting
Porsches ad for it
Interesting...A co-workers Panamera Auto Stop/Start stays off since he turned it off.
      07-05-2012, 07:19 PM   #73
John Tishler
Drives: 2012 BMW 535i
Learn Why Auto Start/Stop defaults to ON
The reason BMW designed its Auto Start/Stop function to be in the default ON position every time you start your car, is because BMW engineers are having a hard time implementing designs that satisfy their customers. You can visit this site to to find out why. bmwautostop dot com
      07-05-2012, 09:53 PM   #74
sj_carr
Drives: 2021 540i MSport
I have a 2011 550i 6MT, and experienced Auto Stop/Start on a 2012 528i dealer loaner. Didn't like it too much, and was able to experiment on defeating it.
I'm surprised no one else commented: I found that if I moved the shifter to the left to select manual shift mode, then Auto Stop is defeated, even if you don't rock up or down to shift. I then found the gearbox would not select 8th gear on the highway, so I started driving the car in manual mode while in stop go, shifting back to full auto on the highway, and then back to manual mode for normal roads.
Since I'm used to MT, it didn't seem too much to use the shifter to defeat Auto Stop, even though pressing the button on the dash works with less user interaction.
      07-05-2012, 11:48 PM   #75
Tuesday
Frequent Flyer
Tuesday's Avatar
51
Drives: 535LCI
And now we just code the feature to remember your preference.
      07-06-2012, 12:07 AM   #76
jachien
Drives: '13 Audi S5
im looking into purchasing a 2012 535i actually and i was curious on a few things on this topic.
1) If the car is in drive and auto start/stop is activated (engine shuts off with foot on brake), what happens when you activate the electronic e-brake and let foot off brake?
2) If the car is in drive and auto start/stop is activated (engine shuts off with foot on brake), what happens when you open the door?
reason why I ask is just a concern if its possible that a driver can forget the auto start/stop feature shut off the car instead of the driver, and possibly start up again with the driver out the car. Can this potentially cause accidents?
      07-06-2012, 08:08 AM   #77
Alan l.
Alan l.'s Avatar
5437
Drives: 2020 F95 X5M Competition
Just have this coded to be turned off permanently. There are a bunch of DIY or local chaps that could help you accomplish this. Search the Coding section on this forum...
This will be one of the first things I'll have done to my F10 when i get it.
Alan
      07-06-2012, 08:14 AM   #78
BigKutta
BigKutta's Avatar
2019 330xi  [0.00]
2017 Audi Q7 3.0  [0.00]
2020 M2C  [0.00]
1) Are you planning to put the car in Park first of just activate the brake and let your foot off?
2) Are you planning to put the car in Park before you open the door and exit the vehicle?
If yes to both, then you are ok and the car will stay shut off. However, if the answer is no, then I have not tried these scenarios (and have no reason to)
      07-06-2012, 02:01 PM   #79
shiner
Drives: 535D MSport Touring
Without this feature the CO2 emissions would be much higher. That means UK company car tax - BMW's seconds largest market - would be unduly effected and they'd sell less.
When you press the start button - press the off for auto start/stop at the same time.
      07-18-2012, 12:41 AM   #80
Asiann
Got Seoul?
Drives: 2012 535i MSport
2012 BMW 535i  [0.00]
2008 750Li  [0.00]
2006 BMW  [0.00]
Just shift to manual or turn off the button when you start and it will not stop. Real simple.
Can you say Alooooha?
[SIGPIC][/SIGPIC]
