2010 2011 BMW 5 Series Forum F10 Water in rear door seals... Wtf? |
07-20-2016, 03:53 PM | #1 |
Rep 109
Took my 2013 to the dealership for water in the rear door seals....they are replacing them but said its normal. They checked another car and it had the same thing. Wtf? This can't be normal. At some point the doors will rust out
Has this happened to you? |
07-20-2016, 10:33 PM | #2 |
Rep 249
I've had my 2011 in the shop six times for water soaked rear floorboards. 5 times passenger side, 1 time on driver's side.
I can't believe a car this expensive has THIS problem. I've owned a 57 Bel Air with original door seals that could keep water outside the car. I've explained this to the dealer, who covered the cost all six times.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
07-21-2016, 07:55 AM | #4 |
Rep 109
This is my 5th BMW (e36 m3, e39 m5, e46 m3, x5) and the First with this issue. I think it's an f10 design flaw.... It's not my vapor barrier like the most common issue. My m5 is 15 years old and never had this issue
07-21-2016, 10:26 AM | #6 |
Rep 36
Last year I noticed water on the rear door sills of my 2012 f10 after a rain and the rear footwells soaked.
Dealer determined that the vapor barriers had failed and replaced them. PNs 51-48-7-366-707 and 51-48-7-366-708. I believe it's a common problem on f10. |
07-22-2016, 09:58 AM | #7 |
Rep 878
It seems this is a recurring problem with the 5 series. My E39 M5 had the same problem. It's usually the vapor barriers that come unglued. Take door panel off and re-install vapor barrier with some windshield sealant and you'll never experience the problem again.
-WJV
08-16-2016, 05:07 PM | #9 | |
Rep 15,858
For me, it's the integrity of the vapour barrier that is key, to prevent water getting onto the inner door rubber, where it can track into the car. |
08-17-2016, 04:59 PM | #10 |
Rep 219
Water dripping out of bottom of door is normal...might seem the seals are actually dripping water. If water is not getting to the inside, the seals are doing their job. The door liner/vapor barrier might play a small part in keeping water out, but not much should ever come in contact with the liner. Most of the water simply drips straight down to the bottom of the door where it is weeped to the outside. My F10 is my first BMW in a long time that does not leak water to the inside (probably because it is the newest). Most of the time, the culprit is the sunroof (clogged drain tubes, dirt in drainage channel, etc.). The water leaks down to the floor from the sunroof. Look for water stains on headliner eventually.
Also, I would not worry about door corrosion due the water dripping from the seals. The doors are well protected. |
08-19-2016, 10:11 AM | #11 |
Rep 337
My driver's side rear door does this... it's the only one of the four which is really weird.
2012 550i///M-Sport///Carbon Black Metallic///Oyster+Black Dakota///ZCV+ZLS+ZMP+ZPP+ZPS+ZSP+ZTP...M5 exhaust///iND Tricolor grilles///H&R Sport Springs///Turner Motorsport 12mm+15mm spacers
08-19-2016, 05:12 PM | #12 |
Rep 109
My actual door seals fill up with water...
You can slap the bottom rubber seal and water will come out. I can't imagine having water in those seals is normal My dealer told me it is. At some point the bottom of the doors will rust out |
09-05-2016, 11:40 AM | #14 |
USAF Pararescue Veteran
332
Rep 770
with the e60 it was fairly common in wetter climates that the water drains for the roof would get clogged easily and you would end up with water in the spare tire well in the trunk or inside. guys discovered that the drain exit was in the rear wheel well and found that cutting off the screen and the end of it prevented the clogging issue, not sure if that would help the f10 issue. the good thing about living in socal - the climate can be called anything but wet
09-05-2016, 03:30 PM | #15 | |
Rep 15,858
Found a wet door sill (rear door driver's side), after further investigation found water leaking from the vapour barrier. Fixed it and all is now dry. Side issue, the rubber door seal (fitted to the door) was also full of water. The vent/drain hole is in the rubber fold, at the bottom and I could pump out the water, by squeezing the rubber, which I did until it was virtually dry. I've never noticed water in any of the door rubbers before last week. I've just checked the door rubber this evening, as we've had lots of rain since fixing the vapour barrier, and there isn't any water in the rubber, it's completely dry. This is telling me there has to be some way for water to get inside the rubber seal, 'inside' the contact face. In my case (and may be other users) it was a leaking vapour barrier, the water getting into the fold and inside the door rubber, filling from the bottom vent (drain?) hole. For those who are sure their vapour barriers are sound, no water drips from under the door card(s), I can't fathom how water tracks to the rubber and the available hole unless there is some leakage to inside the rubber contact area. The hole is exposed to the inside, between the two door rubbers, when the door is shut. From looking closely at the door and sealing, the rubber can't fill from outside water, unless the door seal isn't making proper contact, or due to opening and closing doors in heavy rain. Puzzling. |
09-05-2016, 03:35 PM | #16 |
Rep 15,858
Why do you think the doors will rust out? From observation water in the door rubbers is only in contact with the surface paint finish. Unless the paint is damaged I can't see where the rust will start forming.
