2010 2011 BMW 5 Series Forum F10 AUC sensor: internal sensor fault |
10-19-2020, 11:12 PM | #1 |
Rep 56
Hello, 2011 535 xdrive
I have this fault code, but not sure where to look. Can someone point me in the right direction? Bunch of posts for other models, none I could find for the F10. Where to find this sensor? C90D60 AUC sensor: internal sensor fault Thanks |
10-20-2020, 11:13 AM | #2 |
Rep 1,264
Had this fault for over 2 years. Don't worry about it
10-20-2020, 03:53 PM | #4 | |
Rep 1,876
Unfortunately realoem pictures it, but not any of the surrounding area to give a clue: https://www.realoem.com/bmw/enUS/sho...diagId=64_1687 I'm guessing you know that it won't have anything to do with your CEL, but I'll say it just in case you don't. If newtis was still up it would be easy to link to a R&R page for it. |
10-20-2020, 04:03 PM | #5 | |
Rep 5,409
10-21-2020, 10:58 AM | #6 |
Rep 56
Yes, Thank You, I found it. Passenger side, under the cover next to firewall.
View post on imgur.com |
ezaircon4jc4575.50 StradaRedlands5033.50 |
03-15-2022, 08:59 PM | #7 |
Petrolhead
445
Rep 814
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
My car is throwing this code now. Part number comes up discontinued everywhere I look. Anyone know if it's still available under a different part number not listed in realoem? Or, are there any OE/OEM options? Finding it hard to believe it's not longer available when it was last used in 2018 production cars.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
LivNowPayL8r27.50 |
03-15-2022, 10:59 PM | #8 | |
Rep 1,363
https://www.ecstuning.com/Search/Sit...h/64116826346/ |
03-16-2022, 05:21 AM | #9 |
Rep 6
My car shows the same error.
But does anyone know the consequence? Is the AUC no longer detecting bad air and no longer switching automaticaly??? I can still activate the "A" mode. |
11-10-2022, 06:11 PM | #10 |
Rep 3,089
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.25]
2009 BMW 328i Touri ... [8.00] 2013 BMW X5 35i [7.80] 2011 BMW 528i [8.70] 2006 Mazda3 [5.50] |
Just found I have this code as well... joy. I read elsewhere of someone just sanding the contacts a little and got the code to go away.
10-25-2023, 07:13 PM | #11 |
Rep 36
10-25-2023, 07:16 PM | #12 |
Rep 3,089
10-25-2023, 07:24 PM | #13 | |
Rep 36
Replaced: Tension Strut Brakes & Bleed Battery Spark Plugs I'm guessing new battery is the culprit and all these codes are throwing each other off like a christmas light... |
10-25-2023, 07:31 PM | #14 | |
Rep 3,089
