2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Spacer Question
      04-01-2014, 11:01 PM   #1
Sunny 528i
Drives: 2012 528i
Spacer Question
Hey guys I'm looking into getting spacers for the front wheels. The rears are perfect.
My wheel setup is:
Front Size 20x8.5 tire 245/35/20
Offset 33
Rear Size 20x10 tire 285/30/20
Offset ET 35
Bolt Pattern 5x120
Hub Bore 72.6
Car is 2012 528i stock suspension, no sport or Xdrive. What do you guys recommend? I read 12mm up front will be perfect and flush but wanted to be sure.
Thanks
      04-01-2014, 11:58 PM   #2
MELLOWYELLOW06
MELLOWYELLOW06's Avatar
331
Drives: 2020 M8 & 2022 X& M50i
You can easily go with a 12. It will get you flush
      04-02-2014, 07:50 AM   #3
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
I am running 10mm spacers with an 8.5" wheel and 33 offset and find it to be flush for my taste. Don't think you can go wrong with either 10mm or 12mm, but you don't want your fronts to stick out more than your rears.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      04-02-2014, 08:01 AM   #4
Sunny 528i
Drives: 2012 528i
Awesome thanks guys! I think i'll go with 12mm. Any particular brand in mind? Whats the price point usually for a pair?
      04-02-2014, 12:41 PM   #5
bake
bake's Avatar
I have these and like them.
http://www.burgertuning.com/BMW_wheel_spacers.html
Bake
      04-02-2014, 01:35 PM   #6
VMRWheels
VMRWheels's Avatar
2038
2013 BMW M3  [10.00]
2015 BMW M4  [0.00]
2013 BMW F30  [0.00]
2014 BMW F22  [0.00]
2013 BMW F06  [0.00]
Check your gap, and then purchase the appropriate spacers.
      04-02-2014, 01:35 PM   #7
Sunny 528i
Drives: 2012 528i
Ok will do! thanks for all the help
      04-02-2014, 03:10 PM   #8
Dan1416
Dan1416's Avatar
39
Drives: 2013 528 x-drive
I have the same. No complaints
      04-11-2014, 04:19 PM   #9
polyadam
Drives: 2011 535i Xdrive sport
You guys put spacers on stock suspension without a drop?
      04-11-2014, 04:45 PM   #10
Dan1416
Dan1416's Avatar
39
I don't know about others but mine was lowered before I put my spacers on
      04-11-2014, 04:45 PM   #11
remmib
remmib's Avatar
Norway
1566
Drives: 2013 F10 520d M-Sport
I feel spacers are more "needed" when dropped, but sure you can but in spacers. I'd start with the rear.
      04-13-2014, 05:50 PM   #12
bake
bake's Avatar
Yes, I installed my spacers before I did my ACS springs and it made the car look 10x better. Was running spacers on stock suspension for about 8 months.
Bake
      04-17-2014, 09:04 PM   #13
Grumpy514
Grumpy514's Avatar
Drives: 2022 M3X
Take a look at mine.
http://f10.5post.com/forums/showthread.php?t=971951
