2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Changing rear reflectors
      07-31-2013, 05:28 PM   #1
Eki88
BxBadBoyy88
Eki88's Avatar
61
Drives: AW 2015 535 Xdrive
Can't seam to find the link for the DIY for this. I just got my painted rear reflectors and wanted to know if the entire rear bumper needed to come off in order to replace??
2013 AW 535Xi
      07-31-2013, 06:03 PM   #2
Eki88
BxBadBoyy88
Eki88's Avatar
61
Never mind. I got it. Fellas , if the 3m tape don't work for you, wrap some thick string around the side with the metal clip and pull gently it will pop out.
2013 AW 535Xi
      07-31-2013, 06:11 PM   #3
STOOF
Sunburned
STOOF's Avatar
Drives: '16 F83 M4 Convertible 6MT
2013 BMW 535i  [0.00]
i just used a small flat head screw driver carefully and it pops right out.
2016 M4 Convertible 6MT - SO/SO
2013 535i 6MT MSport - Retired
2011 Z4 SDrive35i 6MT- Retired
      07-31-2013, 06:28 PM   #4
Eki88
BxBadBoyy88
Eki88's Avatar
61
Love them painted.
2013 AW 535Xi
      08-04-2013, 08:15 PM   #5
Chinoxblu20
Drives: 2014 535xi 'White on White'
Where did u get the spoiler and who installed it? Was thinking same one but in CF!
      08-05-2013, 07:47 AM   #6
Eki88
BxBadBoyy88
Eki88's Avatar
61
eBay. But had it extended alittle and painted AW to match perfect at body shop. Really easy install did it myself with 3m tape.
2013 AW 535Xi
      08-09-2013, 12:11 PM   #7
HighConcept
Drives: F-Ten ///M
Purchase some plastic prying tools that seem thin and tapered at the ends and it becomes that much easier.
      08-28-2013, 02:21 PM   #8
aznmr6
Veteran
Drives: '15 Audi Q7 - back to BMW soon
Here is a nice slideshow which shows how to change the rear reflectors. The slides dont show it but there is a small metal clip located where they are prying which holds the reflector in place. Its comes out fairly easy.
http://www.autoevolution.com/bmw-blo...2747.html#sjmp
2008 E90 M3 - Jerez Black
2012 F10 550i xDrive - Carbon Black
2015 Audi Q7 - Will be back to BMW at lease end
      08-29-2013, 11:57 PM   #9
EV0LVE
EV0LVE's Avatar
42
Drives: F10 535i SG
the easiest way to remove it is to use a double sided tape and an L or T shape bracket. The bracket has to be slender to fit in fit between the indentation on the bumper. Stick the double sided tape on the bracket and stick to the reflector, pull it off and done. make sure pull straight as you may scratch the bumper if the reflector hits the surrounding indentation.
sorry no pics i'm too lazy to look for the bracket.
