2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum F10 M-Sport Package coming in October 2010 @ Paris. Previewed to members already.
      06-19-2010, 02:23 PM   #67
carl_d
carl_d's Avatar
Drives: E90 335i M-Sport N55 6SP Nov10
Originally Posted by vladberca View Post
^Same 20" rims from 7 M Pack?
Yes on the F10 pics, they look like the optional 10 spoke style 303M from F01 7 M-Sport but oddly smaller?
The the F11 pics have 14 spoke wheels?
2010 E90 335i M-Sport, 2005 E90 325i M-Sport, 2003 E60 520i, 2002 E46 330i Sport II, 2000 E46 325i Sport I, 1999 E46 318i, 1998 E46 323i SE, 1996 E36 323i SE, 1996 E34 518i, 1995 E36 320iA, 1994 E36 316i
      06-19-2010, 04:00 PM   #68
HighlandPete
Drives: BMW F11 535i Touring
"Adaptive Drive runs 10mm lower than standard suspension"
Originally Posted by carl_d View Post
Wow thats big news to me, Pete are you sure? Surely its the Springs that determine ride height not the Dampers?
I remember reading it a couple of times when researching Adaptive Drive and Variable Damping Control and thought "that's good, just about right".
Here's one BMW press release:
PRESS RELEASE
THE NEW 6th GENERATION BMW 5 SERIES UNVEILED IN MUNICH (United States Version)
The most sporting 5 Series Chassis to date.
The new 5 Series can be equipped with a Sport Package that adds Adaptive Drive, which contains several key features.
* Driving Dynamics Control, introduced on the 2009 BMW 7 Series and Z4 Roadster, allows the driver to set the ride/handling/drivetrain behavior of the car through a single rocker switch on the center console. Adjacent to the E-shift lever or manual shift lever is the Driving Dynamics Control selector (logically, on the driver's side). Driving Dynamics Control provides four standard settings that tailor vehicle behavior to different moods. The settings are Comfort, Normal, Sport and Sport+. Affected vehicle parameters include engine throttle response, transmission shift characteristics, power-steering assistance level, and Dynamic Traction Control mode (in the Sport+ setting).
* Dynamic Damping Control is an evolution of the Electronic Damping Control (EDC) that has been available on several BMW models. On the new 5 Series, Dynamic Damping Control (DDC) is combined with a slightly lowered (10mm) suspension. Dynamic Damping Control adjusts the shock absorbers to any level of firmness, quickly adapting to road conditions and the driver's demands. Suspension control is always optimum for current road conditions, vehicle speed, and load. The shocks default to the softest appropriate setting for the vehicle's speed, and when the vehicle encounters an irregular road surface, they adjust instantaneously to control ride motions, preserve ride comfort, and maintain adhesion to the road. The system is so fast that even at highway speeds the system can sense a pothole at a front wheel and adjust rear-wheel damping before it reaches the same pothole. Dynamic Damping Control is the first BMW system to vary the shock absorbers' jounce and rebound strokes (wheel moving upward and downward) both steplessly and independently; this capability results in a unique combination of desirable firmness (for handling) and excellent comfort on uneven road surfaces.
* Active Roll Stabilization. This high-tech system reduces body roll, popularly known as "lean," in cornering. It improves handling by virtue of better suspension geometry (wheel angles relative to vertical), but there is a psychological component as well: Drivers and passengers alike marvel at the "flat cornering" that results from ARS. When the vehicle enters a corner or curve, or begins an avoidance maneuver, "lateral acceleration" is generated. This is read by a sensor, which transmits a signal to the ECU. The ECU processes this signal and transmits it to the valve/sensor block. In turn, the valve/sensor block determines the hydraulic pressure applied to the anti-roll bars to control body roll.
HighlandPete
      06-19-2010, 04:54 PM   #69
carl_d
carl_d's Avatar
Originally Posted by Robin Hood View Post
My 535i on 704 sportssuspension stands noticable a bit(1cm?) lower than the dealer's VDC equipped 530d demo...
So I don't think so....
Cheers
Robin
Does this mean M-Sport is 10mm lower than DDC and a full 20mm lower than standard?
      06-19-2010, 05:46 PM   #70
Robin_NL
S0THPAW
Robin_NL's Avatar
8710
Drives: HS M2 Competition
Does this mean M-Sport is 10mm lover than DDC and a full 20mm lower than standard?
My car is just 10mm lower than standard.Only the 704 option as you already know. The M sport could be, but I don't know. Like my ex E90's with the M package were only 10mm lower than standard. Not 20mm.
      06-20-2010, 04:43 AM   #71
carl_d
carl_d's Avatar
Cheers
Robin
So which is it please? Is your car 10mm lower than the stanadard car or VDC/DCC car?
      06-20-2010, 06:53 AM   #72
bm323
Drives: 12.2 E92 M3 ZCP; 12.7 C63
HighlandPete
Interesting info
      07-02-2010, 06:46 AM   #73
carl_d
carl_d's Avatar
more info at this link http://f10.5post.com/forums/showthread.php?t=403526
      07-02-2010, 07:17 AM   #74
Robin_NL
S0THPAW
Robin_NL's Avatar
8710
Mine sits 10mm lower than the 530d demo which has the electronic dampers...
      07-02-2010, 09:56 AM   #75
rocco90
Drives: Airbus
535d?
Besides the M package which is stunning when the 535d is supposed to be released? Is that the one rumors are saying that it might meet the US dealerships next year?
