04-29-2013, 10:04 AM | #1 |
Rep 2,822
Drives: X5M F85
JB4 Stage 2 Install
According to the installation guide we should leave the Solonoid and the MAF unconnected from the harness to the car (leaving the connections stock) and only install the TMAP and the MAP connection on the driverside of the aibox. But then right below the steps are pictures of all 4 connections connected. Please clear this up for me. Thanks
535 F10, X3, F30, and X5 Stage 1 models: Installation is the same as above with the following differences: 1) You do not need to remove the cowl/HVAC assembly. 2) To access the MAP sensor, connector #2, you must loosen and pull up the airbox assembly a few inches. Remove the rubber grommets holding wire bundles, loose the worm clamp, and physically pull the airbox up off its rubber mounts high enough to reach the sensor below. 3) The Stage1 control box will be located under a plastic cover on the passenger side as shown. 4) ONLY connectors #1 and #2 are used. DO NOT connect solenoid & MAF connectors. Just tuck them out of the way. |
04-29-2013, 12:26 PM | #2 |
BMW Enthusiast
25
Rep 303
I installed my Stage 2 with all 4 connections and I don't have any problems. I think that the instructions you have is only for stage 1.
For the stage 2 just follow these instructions: http://www.n54tech.com/forums/showpo...16&postcount=3
2022 X5 sDrive 40i Carbon Black | Ivory White Vernasca Leather | Aluminum Tetragon Trim | ZMP | ZPP | ZLS | ZPK | 337 | 4NB | 3M2 | 4HB | 7M9 | Black Kidney Grills |
04-29-2013, 02:20 PM | #4 |
BMW Enthusiast
25
Rep 303
Terry updated the installation guide on 3/18/2013 and now it says that for the stage 1 you only need to connect the first two connectors.
Maybe is part of the new firmware http://burgertuning.com/instructions/n55_stage1.pdf
04-29-2013, 04:10 PM | #5 | |
Rep 2,822
Drives: X5M F85
04-29-2013, 04:31 PM | #6 |
Rep 2,822
Drives: X5M F85
04-29-2013, 08:26 PM | #8 |
Sunburned
238
Rep 1,097
Drives: '16 F83 M4 Convertible 6MT
I actually spoke to terry about this yesterday cause i was a little confused aswell.
Stage 2 uses all 4 connectors.
2016 M4 Convertible 6MT - SO/SO
2013 535i 6MT MSport - Retired 2011 Z4 SDrive35i 6MT- Retired |
05-01-2013, 08:35 AM | #10 |
Rep 494
Drives: BMW 2011 M3
yes, same here, when i ran stage 1 i had all four connected...
2011 M3 Coupe,Jerez Black,DCT,EDC,DSC 2010 X5 30i Black |
05-01-2013, 08:37 AM | #11 |
Rep 494
Drives: BMW 2011 M3
question, do you take off your JB4 when you take your car in for warranty service?
05-01-2013, 08:39 AM | #12 |
Rep 494
Drives: BMW 2011 M3
i hear you i also lost mine
05-01-2013, 09:37 AM | #13 |
Rep 2,014
05-01-2013, 11:19 AM | #14 |
Rep 494
Drives: BMW 2011 M3
thanks i was just getting tired of always having to do it. I know lazy...
05-01-2013, 05:21 PM | #16 |
Rep 494
Drives: BMW 2011 M3
I'm running 93 no problems
05-02-2013, 10:29 AM | #17 | |
Rep 432
Drives: F10 535i M-sport
08-20-2015, 08:52 PM | #18 |
Rep 582
I have a stage 2 jb4. Directions say to install all 3 connectors of wiring harness except the purple MAF connector? Installed it and don't feel like I've gained 60-80hp but engine runs fine. What could it be?
08-23-2015, 11:14 AM | #19 |
Rep 9
Yes I didn't connect the Purple wires, mine works great, which map are you running?
08-23-2015, 06:30 PM | #20 | |
Rep 582
