03-21-2017, 02:53 PM | #1 |
Rep 4,048
Brake pads and rotors
So I called up my indy tech because i have the rear brake pad message (down to 0 miles). he mentioned that they'd have to replace rotors and pads as thats always done. I'm not so sure why both must be replaced.
Would my 2012 528i tell me if my rotors were worn also, or is that something only the tech can visually inspect? Also, once my service indicator says 0 miles left on rear pads, how much do I really have? Thanks |
03-21-2017, 02:57 PM | #2 |
Rep 4,209
The rotors develop a wear pattern with the old pads. Just slapping new pads on means they need to conform to the old wear pattern, which takes longer and forces the pads to wear faster. And the odds of bad brake behavior, like chattering, noise, and warpage increase. The rotors are thin so you technically cant turn them.
03-21-2017, 03:42 PM | #3 |
507
Rep 3,469
There's no way to really tell how much the pads have left without measuring the pads themselves. It all depends on your driving/braking style. Definitely replace the pads and rotors at the same time. I suggest buying the parts yourself, from a site like fcpeuro.com the prices are competitive and they have a lifetime warranty on everything, yes, including brakes. You can actually ask them to send you new pads and rotors after your next set is worn, sounds crazy but its true.
I just replaced all the rotors and pads and fluid on my car buying from FCP. I saved over 50% on parts and labor going to an indy instead of the dealer. Well worth it. Also, when you replace the pads/rotors, you should also replace the pad wear sensor as well, about $12-18. |
Cayman9960.00 |
03-21-2017, 03:49 PM | #4 |
Rep 1,472
This thread might have some answers for you.
http://f10.5post.com/forums/showthread.php?t=1310679 While ago someone mentioned BMW dealership machined their rotors and only replaced pads, but in my personal experience no dealership will do this, BMW or other brands. These days most independent mechanics won't do it either. |
03-21-2017, 03:56 PM | #5 |
936
Rep 4,327
Drives: M340
On German cars, I always do rotors and pads at the same time.
In some Japanese and American cars, you can get away by turning the rotors. I would do both if I were you.
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
GrabacrOne177.50 |
03-22-2017, 06:19 AM | #6 |
Rep 14,521
Like TTG said i think most shops will just replace rotors nowadays but I remember back in the day turning rotors was a cheaper method.
03-22-2017, 07:42 AM | #7 | |
Rep 33
ocas233.50 |
03-22-2017, 09:04 AM | #8 |
Rep 2,825
first off, look inside your rim and check how much pad surface you actually have left.
what mileage are you at and how aggressively do you use the brakes? |
EL Jeffe 5612.50 |
03-23-2017, 08:27 AM | #9 |
Rep 4,048
Took her in because the actual sensor light came on, and since my son is learning to drive I just got them replaced. Surprisingly, they checked the thickness of the rotor and said I dont need a new set, and the current one could last me another set of pads. Ok, I'll take that
03-28-2017, 06:30 PM | #10 |
Rep 373
Probably late to the thread, but my 2 cents: It's true that for best friction you should swap rotors and pads, but this is in a very perfect world. Provided rotors still have the minimum thickness, are not warped or grooved it's perfectly OK to swap pads only (that's also what ISTA says). If you do change rotors however you must change pads no matter what the wear. The sensor only pertains to the pads - the rotors are visually inspected and measured with a micrometer - there's no automatic detection of wear there.
03-29-2017, 02:30 PM | #11 | |
Rep 4,048
Breach80.00 |
03-30-2017, 03:28 PM | #12 |
Rep 373
04-17-2017, 09:06 PM | #13 |
Rep 231
The i-drive calls the rear brake pads in 700 mil. I checked the rear brake pads and rotors. Both side pads are still about 4mm thick. From the service history I believed they were changed at 25k and now is getting 60k. I have owned car two years and about 23k. From the estimation, it should has another 5-10k to go.
Interesting think is the rear rotor thickness is still about 20mm (0.79"). I don't see in service history it has been changed, as lease not while I own it. The information I got for the thickness for 535i rear rotor is 20mm. My front rotors measured at about 30mm and 30.5mm! Is it possible that they don't wear at all? What is the minimum spec for F10's rotor thickness?
2011 535i xDrive Black/Black, Michelin PS AS 4
2014 435i RWD Convertible Service Manual: www.newtis.info Part: http://www.realoem.com |
04-18-2017, 07:19 AM | #14 |
Rep 14,521
i've got about 2900 miles to go before my rears brakes need to be changed accorinding to the computer. BMW quoted me around $900 parts and labor...does that sound about right?
04-18-2017, 08:35 AM | #15 |
Rep 33
I drove my car for about 1000 miles after the sensor warning came on, the dealer quoted me $700 for rear pad replacement but no rotor replacement. I bought my own pads online & googled how to replace them & even after buying over $100 worth of tools to do the job it ended up costing me $300.
04-18-2017, 08:45 AM | #16 | |
Rep 14,521
04-18-2017, 09:22 AM | #17 | |
Rep 33
I had to buy a breaker bar to help remove the lug nuts, a torque wrench, some grease, & 2 torx socket drivers. |
04-19-2017, 02:08 PM | #18 | |
Dream crusher
984
Rep 2,421
http://f10.5post.com/forums/showthread.php?t=1266532
IG: @bmwdoubles |
04-19-2017, 03:46 PM | #19 |
Rep 14,521
I have a month before my warranty expires next month so I'm going to put 2700 miles on it before it expires that way I can get the rear brakes done
10-26-2017, 09:40 AM | #20 |
Rep 4,048
So lately I've been getting this front end vibration when braking from certain speeds. Called my indy mechanic and he said its usually the front rotors. Before I take it in I'd like to understand my options if its truly the rotors once they inspect.
My service indicator says I have about 15k miles left on my front pads, so it seems that I have to replace the front rotors, I'll also have to replace the pads, right? Is there an alternative to replacing the rotors? Can they be turned, etc.? I'm trying to determine alternatives to throwing away a good set of pads in the process. Also, I have a service indicator to change brake fluid? How much is a reasonable price to pay to an indy BMW shop for this? Thanks guys for the input |
10-26-2017, 11:02 AM | #21 |
Rep 266
10-26-2017, 11:03 AM | #22 | |
Rep 4,209
I have to replace my rear pads pretty soon so I'm just going to do it all at once. |
